PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. 2008 cooper s engine reduced power light
  2. New Member, MINI having issues (CEL, loss of power, etc!)
  3. O2 sensor operation
  4. Torque spec for upper timing chain guide and valve cover?
  5. Turbo / Vacuum / Wastegate / Pressure Converter issues
  6. Weird Occurence with Breaks?!
  7. Rough idle.
  8. Brake fluid bleeding with ABS/scan tool
  9. Key Drama! Helppppp!
  10. Key FOB Personal Profile copying?
  11. Flickering Lights
  12. Sad day
  13. R55 No start help
  14. 2007 Problems
  15. Sloppiness in manual shifter
  16. Mini R56 white smoke
  17. loss of power, cel, but no codes
  18. 2008 R56 PCV valve replacement
  19. Exterior door handles getting sticky residue
  20. Mini Cooper 2010
  21. New owner - 2012 Mini R56 -- N16 Engine with issues
  22. Stumped with limp mode code
  23. Where to find a list of N14/N18 potential issues?
  24. Clutch bled yet still spins while engaged...HELP
  25. R56 Surging in 1st gear until warm
  26. 2009 Clubman Key Fob and Keyless Entry Issues
  27. Valvetronic questions
  28. Noisy Injectors?
  29. Need Help Identifying Sensor - A/C related?
  30. New Starter Squeek at Startup
  31. 2008 Clubman Oil Consumption
  32. Rearview Mirror Remote Receiver Damage...or Fob Battery?
  33. Cylinder head cup plug
  34. White smoke after ~10 minutes of idling
  35. Help diagnose a potential death rattle (video)
  36. Valve seals or full head job?
  37. Help! Valve cover bolts
  38. HPFP Continental Part #13517592429 descr and reilability
  39. Should I replace growling gearbox with used?
  40. Engine misfires at 4500 rpm >90 mph
  41. Oil consumption problem....
  42. Red brake light and mini on lift but no code
  43. Going to replace valvew cover gasket. What else should I do?
  44. Trifecta?!
  45. 2013 MCS Noob Question...
  46. spark plugs for 09 Mini R56 N12
  47. Steering Wheel noise
  48. increased gas consumption on an R56
  49. After replacing spark plugs & coil packs now rough idle
  50. High RPMs no power though
  51. Hood release cord broken??
  52. 09 R55 Steering noise
  53. Tripod CV joint slipped out while replacing strut
  54. Cyl head rebuilt engine running very rough
  55. R56 S Non-Comfort Access Key Battery Replacement
  56. Electrical...HALP!
  57. 2009 JCW N14 won't prime or turn over.
  58. Touchy Accelerator Pedal
  59. 2007 Mini Cooper s r56 n14 rough idling won’t accelerate past 4K rpm
  60. Error Codes
  61. R56 - Bad ball joint?
  62. Fighting a p0302. Pulling my last 4 hairs out
  63. 2009 Mini R56 Transmission jerks and over revs
  64. Headlight Issues
  65. 2014 Mini Cooper s won’t start
  66. So i have an issue
  67. How to reset the passenger air bag light!
  68. Life expectancy of timing chain repair
  69. Powerflex front lower control bushings installed with Teflon
  70. P0172 sputtering
  71. Old temp sensor
  72. N12 Engine issues
  73. Camber Plates Required?!
  74. new brake pad wear sensor does not clear warning light
  75. New member - 2010 Clubbie problems
  76. When are the valvecover spark plug sleeves inserted?
  77. Scavenge Air Line Failure
  78. 2009 mini r56 n12 (non-s) timing chain kit upgrade/aftermarket
  79. Faint popping on accel / decel (maybe suspension???)
  80. Do you need to use gasket sealer with a valve cover gasket?
  81. Sluggish acceleration from a stop
  82. Timing Possibly Off? - Camshaft Tool Isn't Sitting Right
  83. Safe to run two diff o2 sensors?
  84. Stumbling at Altitude
  85. CEL won't go off, codes cleared
  86. low power, hard start, poor fuel economy
  87. Can the front lower control arms be removed with out lowering the subframe?
  88. N14S after Catch Can, Pressure Relief Valve on the head is spewing
  89. Engine was just replaced and...maybe my starter is dead??
  90. Camshaft Locking Tool
  91. Should I flush transmission fluid in AISIN 6 speed with 153,000 miles???
  92. 2008 Mini Base fouling plugs
  93. Lost Power to Low Pressure Fuel Pump.
  94. Can a low battery charge be related to engine misfires?
  95. 2007 Cooper Passenger Occupancy Sensor
  96. Should I be freaking out?
  97. R60 Brake Reset Issue (Front)
  98. Wastegate problems
  99. White Smoke out of Exhaust! Help
  100. Taboo buzzer during hot engine shutoff
  101. New Guy, New to me Car, Old problem....
  102. 2007 mini R56
  103. Driver's Side Tail Lights Not Working
  104. P0012, P000a
  105. Take a look at my wastegate play, would ya?
  106. Valve seals or something else?
  107. N16 Timing Chain Replacement - Is it worth it
  108. OIl pressure warning R56 n14 engine
  109. Chain tensioner swap, cam lock needed?
  110. Some AC Related help please
  111. Gas Tank Size??
  112. Coolant leak in middle under car?
  113. media blaster: walnut Blaster
  114. What is this vacuum line?
  115. Identifying Varta battery date
  116. Limp Mode W/ Odd Codes??
  117. MINI USA turbocharger extended warranty N18
  118. Possible valve cover failure?
  119. R56 smoking at idle, limp mode, low boost
  120. R56 Alternator replace without Service Mode
  121. Cooling low fan... Old problem, slightly different
  122. Injectors for N14
  123. R56 JCW ... lesson... always pull the oil pan
  124. Coolant Temp Sensor Electrical Clip
  125. Red brake light & red car lift light
  126. N18 JCW, engine tries to stall, then picks back up?
  127. cc id 031
  128. EVAP DTC's a little help please
  129. Red steering light on
  130. 2013 R56 N16 Sudden oil light, 1/2 power light, lots of noise
  131. metallic sound when deaccelerating
  132. Stumble at idle
  133. Code P0128
  134. 2008 R56 Starting and Tail lights problems
  135. R56 S idle issues and running rich
  136. Half power, no cel
  137. Half power, no cel
  138. Ac recharge
  139. My 2007 NINI S will not start
  140. ECT sensor
  141. Compressor surge on my R56S
  142. Stalling on cold start problem...
  143. 2010 clubman s random multiple misfire
  144. Warning lights... Need help.
  145. New oil for R56 generations
  146. Instrument cluster intermittently flashes on/off
  147. car got very wet inside from rain
  148. Engine starts but no dash lights
  149. Couple issues- Vacuum or Exhaust leak?
  150. Door handle stopped working
  151. Timing chain tool
  152. Newby that went to half power
  153. Oil Pump Question
  154. Check Engine Light won't clear
  155. R56 engine light - code P0128
  156. R56 2007 MCS Water Pump leak
  157. Need Some Of Your Expertise - code 2885
  158. need thread specs for top automatic trans plug
  159. What Part is This? Or replacement suggestions ...
  160. R56 Cooper S Engine Knock/pop, oil pressure loss
  161. Vacuum
  162. How Do I Remove the Shift Cables (Ball Joint) for a Short Shifter Install?
  163. Sorry, the P0300 again.
  164. Oil Change after Walnut Blasting?
  165. 07 r56 base model cooling fan issue
  166. Timing Chain Tensioner
  167. IHKS codes
  168. 2k Rattling in Paceman and Goodwill
  169. Soda blasting?
  170. Weird N18 cold start noises
  171. Can't remove final stage unit on 2010
  172. code 5DB5
  173. No power if bogged when leaving from a stop
  174. Boost drop? Other issues
  175. N18 Death Rattle :-(
  176. Misaligned dashboard?
  177. Leaking coolant - preventative maintenance while in there?
  178. DRL behaviour, Is this normal?
  179. Mini Cooper cylinder number and firing order
  180. Transmission issues! Please help
  181. Mini s problems
  182. Steering problem
  183. Clutch problem please help!
  184. Low boost - wastegate actuator question
  185. R60 N16 Cam Shaft Lock Tool - Which One?
  186. Vinyl Stripe Adhesive Removal
  187. Water Pump OR Fan?
  188. Engine rebuilt. New engine codes
  189. leaking coolant
  190. R56 code P0014,P0015,P0016
  191. 2009 Justa Valve Cover Logo or No Logo?
  192. Comfort Access Question
  193. 2010 blown head gasket
  194. 2011 Countryman s whinning at startup
  195. Hesitation with 2013 "justa" mini cooper R56.
  196. Newbie - justa with 1/2 engine light, now dead battery
  197. New Pool of Oil Near Vacuum Pump and Filter Housing
  198. Need help 2007 N14 cooper S top end rattle
  199. hi I need 2009 mini cooper high presure fuel pump price rebuild or new?
  200. AC Not blowing cold.
  201. Pressure Control Deviation 2885
  202. P013A code for 09 mini base
  203. Block surface tolerance
  204. My Battle Against P0015, Round 2, Front Exhaust VANOS Solenoid Replacement
  205. Any thoughts on my dilemma?
  206. N14 Valve Cover: OEM vs eBay
  207. Need a little help with some codes my Mini is throwing.
  208. common N14 engine problems.
  209. How to fix the rear window sunroof?
  210. Ignition coil upgrade
  211. AC cooling problem
  212. P2096 issues.
  213. Oxygen sensor (below CAT) heating element resistance?
  214. Paddle shifters not working
  215. Possible DME Connection or HPFP issue
  216. 2009 R55 Timing Chain Rattle
  217. Ever wondered what’s inside a Throttle Body?
  218. Engine Shakes - What's the Cause?
  219. Warranty Extension Thermostat Housing & Therm'
  220. Rear caliper pistons
  221. Airbag Seat Belt Light
  222. Airbag Seat Belt Light
  223. P0301 Cylinder 1 misfire
  224. Water pump tube clip
  225. Bonnet Release STUCK!
  226. Throttle body problems? R55 jcw 2009
  227. Still getting P0015! DIY done to date ...
  228. Major problem: Rough ilde + white exhaust
  229. Oil can light
  230. Help oil feed line bolt snapped stuck in block
  231. Disappearing coolant and random misfires.
  232. Turbo clicking
  233. carbon build up
  234. R55 S - Transmission Whine/ Lack of Fluid - Thermostat related?
  235. 2011 base catalytic converter removal procedures?
  236. R57 N16 Stalls when engine warm, no CEL.
  237. TIMING CHAIN need to be replaced?
  238. Steering Rack?
  239. 2010 Clubman overheating?
  240. Brake light, engine light and a red car light
  241. Leak-down Test Intricacies
  242. 08 R56 Stalling
  243. 2009 Cooper S - Major Engine Problem - Advice?
  244. Few issues with '09 Cooper S - Run rough, lurches
  245. 07 mini s auto slipping at 3000rpm
  246. MCS R56 misfire questions
  247. No go turbo
  248. Oil leak
  249. 09 MCS - Oil Leak Suggestions
  250. Family Member 2009 Mini Cooper S issues
