Newbie - justa with 1/2 engine light, now dead battery
Hi everyone.
I'm going to just jump right in and ask. So I have a 2011 base model mini. I have had it fur several years now and have had no issues with it until recently. So I was heading to work and was climbing a hill on the hwy and on the display an engine emblem popped up and half of it was solid and the other half not.so I turned around and brought it back home.as soon as I turned around and headed back down hill the emblem went away and it seemed normal. So I pull into driveway and shut my car off and the fan continued to run for 5 or so minutes. I checked all fluids and I was a little over quart of water but oil was fine.I. have had it parked since because I did not want to damage it anymore. I went out to start it and the battery was dead. It cranked over a few times and the fan kicked on and drained the battery rest of the way. Can you tell me if I need a relay, sensor, or fan assembly?
Please provide some basic information:
Model - R56?
How many miles?
When and what was the last maintenance done on the car?
Have you tried jump starting the car?
Any spots or puddles of fluid underneath?
Get it jumpstarted and head to a local auto parts store to get the battery checked and the codes read. Then post the information here. If you still have the original battery then it probably needs a new one. The 1/2 engine light could be due to low coolant, or some other problem, can't tell without the trouble codes.
Model - R56?
How many miles?
If the battery is near end of life, it will do all sorts of weird stuff. I'm on my 3rd with my 2009 and both times the last 2 went, my instrument cluster decided to have a seizure of alarms. Door locks, radio, turn signals didn't work, etc...
If it's original, it's probably due for replacement. If the store said it was good, did they load test it? A simple voltage test could still indicate good when it's not.
Model - R56?
How many miles?
Model - R56?
How many miles?
Wendi
My initial suspicion is a combination of an old battery and a bad temperature sensor.
Get the codes read - this is via the OBD2 connector under the dash, not the keyfob. The diagnostic codes should show what the problem is.
Thank you guys for all the help. And the welcome to club. I have a friend who is going to bring over his code reader to figure it out. I will buy a new battery because I had noticed in the prior months that it did not seem as strong of turnover when started. I was leaning towards a relay or sensor because of fan coming on without even turning car on. I will let you know the outcome, because I'm missing my mini.
Wendy
Pr
Wendy
Wendy
Wendy
myskylab
Oct 31, 2015 07:28 PM
rodney_kranz
Dec 20, 2013 04:32 AM
