Valve seals or something else?
Old Jun 7, 2018 | 06:35 AM
Theodor's Avatar
Theodor
Hello. I have a problem with non s mini r56 2008 with 90.000 km. I have it from 75.000km.
I change oil&filter every 7.500km.
The previous owner changed every 15.000km
Yesterday with 33 degrees Celsius outside , after a long idle at traffic, when I press the throttle, I see smoke from exhaust. On the motorway there is no smoke as I can see. Even I stop and press throttle I don’t see smoke. Only after long idle.
The coolant level is ok and without oil in . The oil are clean and the consumption is about 300+ml/1000km with motul 8100 xcess 5w-40.
When I using mobil1 new life 0w-40 at winter, the consumption was 250ml/1000km.
I want to ask which is the most likely problem?
Valve seals ?
Valve guides ?
Head gasket ?
Piston rings?
Or something else?
One mechanic said valve seals, another head gasket, another rings!
Im confused, please help me!
I can’t change all without a reason
Old Jun 7, 2018 | 07:04 AM
MiniToBe's Avatar
MiniToBe
take a look at the PCV, it might be leaking just enough to notice the smoke after long idle.
Old Jun 7, 2018 | 07:05 AM
Theodor's Avatar
Theodor
how can I check if pcv is ok?
Thanks for the reply
Old Jun 7, 2018 | 07:13 AM
MiniToBe's Avatar
MiniToBe
you could remove the pipe coming off of the cover upper left corner and inspect for excessive oil.
Old Jun 7, 2018 | 07:52 AM
Theodor's Avatar
Theodor
how can I judge if it has a lot of oil?
how should it be normal?
Old Jun 7, 2018 | 07:56 AM
MiniToBe's Avatar
MiniToBe
I guess to a dripping point or just enough that you think is seeping all the way to the intake manifold to get burned.
Old Jun 7, 2018 | 08:31 AM
Theodor's Avatar
Theodor
Ok, let’s say pvc have problem ... why I see smoke only after long idle, and only if the engine is really hot?
Old Jun 7, 2018 | 08:51 AM
MiniToBe's Avatar
MiniToBe
perhaps because the oil and vapors have been collected to the point when you open the throttle, you have more of that sucked in and burned vs in quick stop and go traffic.
I'm trying to point to a cheaper part to eliminate since the list you have is quite pricey and time consuming.
Old Jun 7, 2018 | 08:59 AM
Theodor's Avatar
Theodor
Thanks for your advice.
I wonder if was stuck open .... the idle was stay smooth?
Old Jun 7, 2018 | 12:09 PM
Theodor's Avatar
Theodor
With which oil you have less oil consumption?
Old Jun 7, 2018 | 12:13 PM
MiniToBe's Avatar
MiniToBe
I always use 5W30. my past `13 Justa almost never needed extra oil. N14s do however.
Old Jun 7, 2018 | 12:15 PM
Theodor's Avatar
Theodor
How can you find out if the problem it is at valve seals or at valve guides ?
Old Jun 7, 2018 | 12:21 PM
MiniToBe's Avatar
MiniToBe
humm....I would probably open the valve cover and try to look at the valve seals to see if they are dry or starting to crack...the guides dont usually have an issue, I think!
Old Jun 7, 2018 | 12:23 PM
cristo's Avatar
cristo
Alliance Member
If it's an early 1980s VW Rabbit, it's probably the valve guide seals.
If it's a MINI, it probably isn't.
Old Jun 7, 2018 | 12:25 PM
Theodor's Avatar
Theodor
so you said that is only valve seals? Not the guides?
thanks for the reply
(my English is not good sorry)
Old Jun 7, 2018 | 01:01 PM
cristo's Avatar
cristo
Alliance Member
Valve guides have seals than can leak.
Old Jun 7, 2018 | 01:06 PM
Theodor's Avatar
Theodor
I think it’s a different part the seals from guides.
so In your opinion which is the problem ?
MrSurly
Aug 28, 2020 12:43 PM
renn90
Jun 26, 2018 08:44 AM
pnwR53S
Apr 9, 2018 08:14 AM
MazMini
Mar 1, 2018 02:36 PM
Lex2008
Aug 16, 2015 08:33 PM
