Error Codes
Old Jun 27, 2018 | 01:06 PM
Nate Sparks's Avatar
Nate Sparks
Error Codes
I have a 2008 Cooper S Turbo. R56 and just changed the oil cover and gasket with pvc and the valve cover gasket and thermostat and lines. Getting these codes now P1497. Intake air leak. Valve cover gasket leak
P112b low engine coolant, faulty thermostat,
p0128 Mini not running warm enough, any ideas?
Old Jun 27, 2018 | 08:08 PM
seandallen's Avatar
seandallen
I would bet you have a leak in your water pump or the water line connecting it and your thermostat. A little wild-*** on the guess, but pretty safe bet for a 2008 S.
Old Jun 29, 2018 | 07:57 AM
MiniToBe's Avatar
MiniToBe
did you bleed the system?
Old Dec 30, 2018 | 08:00 PM
Bnourai's Avatar
Bnourai
For the last few days my 2009 S, has been running under 145 in temp on Sat check engine came on and P112B puped up, less than 3mo ago I replaced my thermostat and the sensor too. On Sunday never went over 128.
ben
Old Jan 5, 2019 | 04:22 AM
Bnourai's Avatar
Bnourai
Got fixed under warranty, thermostat was stuck open.
soul embrace
Dec 4, 2007 10:53 AM
Drama_Llama
Aug 25, 2007 11:49 AM
findude
Jan 24, 2007 10:47 AM
digi-mike
MTH Discussion (Archive)
Nov 8, 2006 11:22 PM
ktpang
Aug 24, 2004 03:04 AM
