Oil consumption problem....
Old Jul 5, 2018 | 04:49 AM
Theodor's Avatar
Theodor
Hello, I have a justa ( base r56 120 hp) with 60.000 miles.
My mini burn about 550ml/1000miles.
I did a compression test and I see 200psi at all cylinders!!!! I think it’s too much. (No head job in the past)
My mechanic check the timing and he said that is ok!
We also check the pcv valve and is ok.
I have no leaks! No engine light!
If I have a long idle, I can see smoke from exhaust.
Motul 8100 xcess 5w-40
Im wondering where is the problem?
Old Jul 5, 2018 | 11:11 PM
Theodor's Avatar
Theodor
Anybody?
Old Jul 6, 2018 | 03:16 AM
cristo's Avatar
cristo
Alliance Member
1 liter every 1800 miles is not too bad and many do that, but if there is blue smoke from
the exhaust after a long idle, perhaps some oil is getting by a valve guide seal.
Still, probably not a big deal at this point.
Old Jul 6, 2018 | 03:18 AM
mustangcruise's Avatar
mustangcruise
Have you tried a leak down test? I had a terrible oil consumption problem and found out the rings were bad. Like yours, no CEL, no leaks, and no timing issue.
Old Jul 6, 2018 | 03:44 AM
Theodor's Avatar
Theodor
@cristo, I don’t think its valve guides seals because at the morning after all night, when I start the engine there isn’t any smoke from exhaust.
@mustangcruise I tried a second compression test, with hot engine and I found the compression is 160psi. So the problem is rings, probably and something else.
The first compression was wrong, probably from oil into the cylinders.
trentan125
Mar 16, 2017 09:16 AM
ladzio
Nov 16, 2015 03:32 AM
timski
Mar 8, 2015 11:17 AM
bmwr606
20
Aug 4, 2012 02:33 PM
aceofspades86
Jun 7, 2011 07:19 PM
