Soda blasting?
Old May 16, 2018 | 08:53 PM
renchjeep's Avatar
renchjeep
Soda blasting?
Has anyone tried using a soda blaster to remove deposits from intake valves on an N18? My Snap-On dealer sold me a soda blaster for about 140.00 a couple weeks ago, said it would do the same as walnut blasting, and the "soda" material will dissolve if any is left in the combustion chamber after the cleaning. No, this is not "soda" like you would drink, more like a fine white powder. In a bag. Kinda looks like a bag of cocaine, but what would I know about that? LOL. I have not even pulled my intake to inspect the valves, nor do I have any issues. Just thinking that at almost 90k miles, maybe time for a cleaning? Back to my original question....anyone tried soda-blasting intake valves? If so, what were the results? Thanks in advance....
Old May 17, 2018 | 04:09 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Thinking that is basically baking soda that is a mild base not acid. Would think that would work.
Old May 17, 2018 | 08:06 AM
MiniToBe's Avatar
MiniToBe
subscribed...
the dealer should give you some sort of instruction how to use it. not just sell sell sell!
Old May 17, 2018 | 11:16 AM
MCS02's Avatar
MCS02
MINI Alliance Ambassador
I have tried soda in my blasting cabinet. It works but not as fast as other mediums. It is less abrasive.
Sorry I know thats not much help.
Old May 17, 2018 | 12:14 PM
DneprDave's Avatar
DneprDave
Sodium carbonate, baking soda is an abrasive, it will dissolve in water, but do you want to spray water, mixed with baking soda, into your engine? I wouldn't.
Crushed walnut shells are flammable, Ph neutral and will burn off, if any happen to get into the cylinder, that is why they use crushed walnut shell to decarbonize the intake valves.
Old May 18, 2018 | 10:09 AM
thefarside's Avatar
thefarside
Soda blasting media should work fine. It may have a shorter shelf life than walnut shells.
If you do use it for valve cleaning, please provide some feedback here. I've considered using it myself.
Old May 18, 2018 | 03:08 PM
sawicki's Avatar
sawicki
If you end up using the soda I'd think doing an oil change after would be a good idea.
ja ME s
Detailing 101
Feb 27, 2006 01:22 PM
ToeKneeC67
May 23, 2003 10:15 AM
