PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36
  1. Mini might be dead :(
  2. Turbo Bought the Farm
  3. Yellow Brake and Traction Control combo lights - what's wrong?
  4. Squeak After Shutting Car Off
  5. Bouncy Idle
  6. No Power/No access with FOB or Real Key
  7. Stall? WTF!?
  8. Engine replacement on day one at 90 miles. What would you do?
  9. Vacuum Pump Failure - What is the Reasons(s)
  10. Rain Sensors seem to be wrong
  11. Is this the "rattle of death.."
  12. 2012 MCS Sport button light stuck on
  13. Creaky Headliner/Sunroof Trim
  14. Lost all radio functionality
  15. Odd electrical/electronic problem
  16. Oil not draining
  17. Service icon not in owner's manual
  18. Cost for full SIM110207 Service (cold clatter)
  19. Noise just during take off/at start
  20. Electrical Problem. NEED HELP!!
  21. R56 cooper s - 5.000 miles - possible death rattle ? Please help
  22. Blown Transmission
  23. Dangling Wire Near Passenger Rear Wheel
  24. Leakage and spots.
  25. Battery and Warranty work question
  26. Is it OK to reveal the name of a dealer that does a great job or a poor job?
  27. possible pcv failure?
  28. Hi can someone id this warning for me?
  29. MCS Clutch Dead at 34k: Replace with MCS OEM, JCW or OS Giken GT clutch?
  30. My Broken 2012 Cooper S
  31. Help! Replaced tensioner, now chain bad
  32. Headrest interchangeability: mini-mini, VW-mini?
  33. Clutch issue
  34. Good repair place in So Cal? Don't wanna pay the big bux at Long Beach Mini
  35. 2011 Oil Leak
  36. Crackly Door. Seals?
  37. How are these "revised" timing chain parts still failing?
  38. Secret Compartment is Stuck - How the heck do I get it open?
  39. Oil change nightmare
  40. Computers gone Crazy!
  41. Clicking noise from front wheels
  42. Sunroof vent position problem
  43. 2011 Mini Cooper Cigarette lighter ring light up at all???
  44. 2 days in and issues!!!!!!
  45. $571 for a New Battery?!
  46. Engine Malfunction Light on 2007 MINI Cooper S
  47. What are these codes?
  48. Transmission issue
  49. 2011 MCS - Knocking while accelerating in sport mode
  50. 2008 Mini S leaking radiator fluid
  51. Mini Cooper S R56 07
  52. Loose Vents
  53. Is my rear wiper missing a few pieces?
  54. Cd player not working :/
  55. '08 convertible rear trim issue
  56. Death rattle? Or something else?
  57. 07 Starting issues!!!@!
  58. 2011 Mini Cooper S Rough Starts
  59. 2007 MCS manual shifter linkage falling apart
  60. Rear Sunroof Pivot Supports Broken
  61. Dealer CAN'T reproduce my idle and clutch problems! So typical.
  62. Can you normally hear the timing chain?
  63. Sudden, seemingly unrelated electrical gremlins.
  64. 07' R56S Transmission issues.
  65. US 2007 Mini Stock Radio CD used in OZ
  66. A/C Heater Blower Intermittently Worked.. Then now stopped working at all.
  67. Interesting thread on cold start/idling issues from Mini Owners Lounge
  68. Electric steering wheel lock malfunctioning
  69. Need a new clutch
  70. valve cover replacement? Plugged PCV valve?
  71. Losing small amts of oil and coolant
  72. 07 Coooper Engine Failure Frost plug let go
  73. Clutch Click on Master Cylinder
  74. P0128 and P173B Fault Codes
  75. Dash lights fading
  76. Engine failure due to loose frost plug
  77. Cruise Not Disengaging Easily on 08 "S"
  78. Radiator hose free from clamps and hanging low!
  79. Cooling Headscratcher
  80. why does this happen only in Oklahoma and Kansas
  81. clutch fail...
  82. speedometer stuck
  83. p1497 cel and cannot locate vacuum leak
  84. Warranty
  85. 2007 MCS Engine Failure - Follow on Twitter!
  86. My TPM won't reset.
  87. Help me diagnose this noise.....
  88. Check engine light on but no code
  89. Interesting occurance, Top gear roll on...
  90. Warranty Issues with dealer
  91. Leaking Coolant - Far from a Delaer. Advice
  92. Advice please: wiring switches in 2009 Cooper
  93. A Little Advice Pease About My Water Pump
  94. Odd noise when I press in the clutch, pressurized air?
  95. Oil catch can / carbon build up solution
  96. Mini Cooper Stripe Decal Maintenance
  97. Carbon Build-Up
  98. Carbon Build-Up
  99. Warning Light????
  100. Bank 1 Oxygen Sensor Voltage?
  101. MINI Failure
  102. engine swap questions
  103. Something leaking from bonnet
  104. How to Reset all Radio / Nav / BT settings?
  105. AC issue due to lowering???
  106. Grinding sound + white smoke?
  107. Check Engine Light
  108. PCV hose leaking oil onto valve cover
  109. MCS Problem!!!
  110. Engine/radiator smoking?
  111. Under what conditions will Mini perform the TSB for the tensioner rattle?
  112. Putting a JCW Clutch in a...
  113. Worried new Mini owner
  114. Hesitation (bog) Issue
  115. Intermittent CEL
  116. Auto Shifting Noise
  117. Radio doesn't turn on all the time
  118. Does your MCS makes more noise when turns on A/C
  119. Do i have a promlem.
  120. Do these service records look bad?
  121. 2 CEL's
  122. A/C blower only runs at ~30% speed?
  123. Just Hit 15K / What to Expect at Service?
  124. Battery Life
  125. Whistling flywheel?
  126. Timing Chain problem fixed? As of When?
  127. MINI Troubles
  128. Reset airbag warning light?
  129. 2011 MCS more problems! NOW: clutch and gear shifting noisy..
  130. CAI rubber boot tearing — anyone else seen this?
  131. Warranty Works!
  132. P2188 CEL not going away
  133. fan running after car is shut off
  134. R56 non start
  135. Throttle Response
  136. battery question
  137. Clutch burned up after Valet Parking
  138. Coolant problems please help, drizzling out of the car
  139. 2011 mini question
  140. Carbon Build Up On Intake Values (Help!!)
  141. What does this mean?
  142. At idle, engine making gentle fart sounds.... WTF !??!?
  143. Help! My mini broke down in Myrtle Beach
  144. Really, I can't find the A/C drain line... help
  145. help with clamp part number
  146. Courtesy Overfill on Coolant
  147. Engine bounce in stop-n-go traffic? Torque Arm Insert?
  148. Extended Warranty or Not?
  149. Indicator Lamp CC Message / OBD2 Scan Tool Code
  150. Driving lights fogged...
  151. Upgrading Software Version - Dealer Refused
  152. r56 Battery Replacement Help
  153. Report Problems to Dept. of Transportation
  154. 2010 Cooper S Speaker Buzz
  155. My MINI logo on the steering wheel is looking ugly!!
  156. Brake Lights Staying On
  157. Another Mini wake up call about poor quality
  158. Fob won't unlock, all warnings on upon ignition...
  159. gurgle gurgle gurgle!
  160. Snap, crackle, pop! The music of my MINI...
  161. squeal/ chirp when ignition turns off (video)
  162. A/C Compressor
  163. opinions
  164. Service Prices...
  165. thumping noise in 'trunk' area of new mini
  166. Help! MCS Oil Consumption progressively getting worse
  167. Timing Chain/Tensioner Problems
  168. Oil light with only 1.5k miles?
  169. Not holding full boost
  170. Vanity (visor) mirror broken
  171. busted piston ring at 50529 miles!?!
  172. Check engine light on, fan runs all the time
  173. Stupid codes...
  174. For those who have had timing chain tensioner issues.
  175. 2nd water pump failed @ 6500 miles
  176. Starting problem after several days
  177. Unexpected Service light
  178. Cargo light problem
  179. Headlight/High Beam Problem
  180. Radiator dented
  181. A/C fan stops working intermittently
  182. Whining noise in the front
  183. 2011 Silver Mini Convertible - Paint
  184. Help with 2009 Clubman S Carbon Issue
  185. Grinded the gears...
  186. Trunk lid grab strip
  187. Lost my power steering
  188. Is It Because I'm A Girl?
  189. Airbag light / seatbelt light
  190. Maintenance Service Extension
  191. Engine Failure in 2011 Countryman
  192. Strange suspension inconsistency
  193. Morning whistle ??
  194. 2010 MCS ISSUES- Stalling, crackling, Radio Shuttoff, hatch....
  195. Deceleration Rattle Emanating from Dash
  196. Rough ride
  197. power steering fluid appearance
  198. Will it take more than 2 days to replace high pressure fuel pump?
  199. cc-id 142 TPM no reset option
  200. 2011 MCS with 2K miles squealing engine noise - water pump?
  201. Club door beltline trim problem
  202. Should I be Worried?
  203. how long to face fuel injection problem?
  204. Sun Roof Decal Problems
  205. Buzzing noise when accelerating (Cooper S 2009)
  206. Anyone know what the O2 sensor voltage amount should be?
  207. Hot weather = leaks
  208. A/C blower motor going bad?
  209. Does Anyone Have Info On A Full Engine Gasket Kit?!?
  210. Any had the hood paint peal?
  211. Exterior bulb warning on brand new mini
  212. Bluetooth disappeared all of a sudden!
  213. Noise
  214. Climate control panel inop in '11 Cooper S
  215. ABS Pickup Ring
  216. Under hood grease leakage
  217. Service light, brake light and engine light
  218. A few engine issues in my '11 Hardtop
  219. loosing powe & oil consumption
  220. Speedometer
  221. Problems, Problems, Problems
  222. 2nd Bad Clutch on 11 MCS in 3600 miles
  223. Run Flat Tire Warning Signal
  224. Windshield
  225. MINI caught fire!
  226. Engine Light
  227. Engine Light
  228. Ticking noise
  229. Accidently overfilled my oil...
  230. 2011 MCS owners, does your......
  231. sand in airbox
  232. Key fob battery recharge and convenience package
  233. Service indicator has read "1100 miles" for 4-5 months
  234. 09 Cooper Knocking at idle when warm: Help!
  235. Engine not sounding quite right upon start up
  236. Alternator belt help needed
  237. Did the dealer destroy my engine?
  238. OCC void factory warranty
  239. WON'T START --help
  240. Key Fobs and the Convenience Package
  241. Mini On A Lift! Help!
  242. 2011 Manual Transmission Clunk
  243. New Turbo @ Less Than 30K Miles? Really??
  244. Alternator Drive Belt - est. cost of replacement?
  245. engine noise- not the timing chain rattle
  246. Accellorator Lag
  247. Baby's 1st check engine light :(
  248. OMG Sunroof opened by itself and rain pored in
  249. 11' Cooper S C-Pillar Flapping Noise
  250. Screw down the front defroster!
