PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. o2 sensors for 11 mini base convert
  2. Black smoke when accelerating
  3. Smoke from exhaust
  4. Will P030x codes automatically reset?
  5. Ignition coil for boot
  6. turbo problems
  7. Hello all, new to this---questrion
  8. 2007 Squealing noise at idle.
  9. Hose from Transmission
  10. More Codes P0012 P0015 P0300 P0301 Help!
  11. I'm Stumped (Poor MPG)
  12. White Smoke
  13. Need More Help-Axle shaft
  14. R56 JCW No Compression Cyl #2
  15. Walnut Blasting????
  16. R5x LCI R6x Turbo extended warranth 10yr 120k miles
  17. Sudden heavy coolant leak (photos)
  18. Mystery vacuum line.. anyone know where this goes?
  19. Clutch adjustment
  20. Replaced water pump now car won't run.. need some super quick help
  21. What grease to use?
  22. 2009 MC Justa - Timing Chain Replacement or Tensioner Bolt Replacement
  23. Valve cover question
  24. '07 PCV Upstream ?
  25. Oil cooler housing gaskets or something else?
  26. Timing Chain Replacement - Expected Cost
  27. Clutch Recommendation for R56 2010 MCS
  28. Death rattle sound from timing on a R56 N12 engine. HELP!
  29. Low oil levels
  30. OBD2 codes vs. BMW / Mini Codes?
  31. Engine Light Misfire
  32. rough idle after adding oil additive
  33. 2009 R56 - Non S - Whistling Noise when accelerated applied
  34. 2009 R56 Cooper non-S - oil leaking part - what does this do?
  35. What is this thing?
  36. Auto Trans Fill Plug
  37. Just gotta Justa 2009
  38. Trip odometer and clock reset
  39. 2007 Mini Hatch (not s) P128B. No P0597. Thermostat?
  40. Help! Axle Stuck in Hub and Trans
  41. emmissions diagnostic check through 60 miles
  42. Oil leak only while driving
  43. Dealer installed new plugs and coils under warranty. Car feels less powerful. Help!
  44. 2013 unknown manual drivetrain issue
  45. Oil leak near oil filter
  46. Engine running hot?
  47. How do you compress the brake piston???
  48. 2013 R56 S Oil Filter Housing Leaking Coolant
  49. Aftermarket muffler 2013 Base Mini available?
  50. Oil Fouled Spark Plug -- non iridium suggestions?
  51. P0015 VANOS? Exhaust or Intake?
  52. Headlight Part Number
  53. R56 need help
  54. On Board Diagnostic Codes from secret menu (**NOT** OBD Trouble Codes) and CCID-029
  55. 2009 r55s cranks but no start
  56. power lock issues / windows down - solved
  57. Cleared Timing Codes, Now No Issues???
  58. Sporadic Boost Loss Issue
  59. Engine Knock 2007 Non S
  60. Leaking fluid identification help
  61. Change chain tensioner just because? Denso Valvetronic?
  62. 2013 MCS mystery oil leak (47k miles)
  63. Squeaking Noise Wont Stop After Water Pump Replacement
  64. Auto Shifter Won’t Move *Not interlock issue*
  65. Anyone can help identifies what this part is for?
  66. Driving down the interstate, all was well then Mini stammered and began sputtering.
  67. Plug on pcv (valve cover) what is it for?
  68. Rear strut replacement tips - NON OEM Strut Alignment Required?
  69. Clutch not disengaging - Pedal still has resistance.
  70. Turbo oil feed line
  71. '09 R55 JCW valve muncher
  72. Oil filter housing gasket repaired now P0300 CEL
  73. R56 N12 Engine Destructo
  74. P0015 P0012 Hesitation Stalling Oil Leak
  75. Anyone knows where these gaskets/o-rings go?
  76. R56 MCS Blown Computer Saga
  77. Can I put a non-sport strut on my MCS?
  78. 08 Auto Trans Issues
  79. 09 mini S convertible round fob&start/stop button
  80. Oil usage
  81. Cylinder 3 blew up without warning. I have questions
  82. Thermostat Issues: To fix or not to fix (for now)
  83. N18 Tensioner Torque
  84. Engine won't start - Valve cover replacement
  85. active spoiler
  86. Replaced my Fuel Filter and now my car wont start
  87. P115D and P1497 plus random misfires
  88. Valve cover leaking on top? - Just started
  89. HELP cooling fan not running 2009
  90. Engine stutter
  91. New timing chain making noise
  92. Are these Ebay gasket kits any good?
  93. Clogged or partially clogged fuel filter?
  94. R56 Hesitation
  95. 2010 r56s intermittent random misfire
  96. Engine leak ?
  97. There is no combustion!!!!
  98. Chain tensioner
  99. Loads of black smoke, rough idle - intercooler fault?
  100. My 2nd gen basket case
  101. Timing Chain Broke 09 Mini Velocity Damage
  102. Cyl head removal. Missing steps in Bentley?
  103. 2007 Mini S hatch back heater control problems
  104. Warning light
  105. 2007 mc s cranks no start! Help!
  106. Any easy way to split the engine case?
  107. Mechanic recommended in NorCal
  108. turbo motor from a 2012 R55 Sinto a 2011 R56 S HALP PLEASE
  109. ABS DSC BRAKE indicators
  110. can't find replacement headlight assembly
  111. Funny/weird experience.
  112. blower motor squeek
  113. Anyone had a oil consumption test?
  114. Mini cooper crank but does not start
  115. Error code: 287D -- Intake camshaft actuator
  116. 2010 MCS (74K miles, auto) - Stock boost?
  117. R56 Won’t Start
  118. Cooper S won't start after car is warmed up
  119. SRS Code Clear Tool?
  120. 2012 Cooper S "Customization" not Working.
  121. 2008 Mini Cooper s
  122. 2009 R56 - Car Won’t Start - Looking for Suggestions to Start Diagnostics
  123. Question on front end grease service?
  124. R56 radio dead but CD player ejects CDs
  125. Aftermarket or genuine parts...
  126. Evap System NOT READY
  127. Intake Manifold Stuck on head
  128. FRM Module brick, a bit of info.
  129. Key symbol
  130. Torque mount replacement?
  131. Fuel filter assembly fell apart
  132. Gas gauge reads inverse yep BACKWARDS
  133. Radiator failure 2014
  134. Frustrated - 2007 Justa turns over, won't start
  135. Potential vacuum pump failure?
  136. P013A code
  137. Stalling when Braking
  138. Sunroof......Pis-of-$$$$!!!
  139. Hood (bonnet) won't latch
  140. Emission Light 2013 Mini S
  141. Knock Sensor Codes P13AE and P13B8
  142. r55 Clubman S 1497 code
  143. Coolant system leading + Head Gasket
  144. CEL - Fan Running - Hard Start
  145. My 2011 countryman S yellow engine lights on and has no power under a load code p0304
  146. Auto Tranny Problems
  147. Turbo Charger on my Super S 2007 Mini
  148. Overheating but heat works
  149. Any thoughts on what else might be causing this?
  150. toggle switch panel night light
  151. 2008 MCS R56 Turbo Issue
  152. Tuner won't respond
  153. license plate lights not working
  154. Transmission issue
  155. R56 stumbling on acceleration
  156. 2013 license plate lights not working
  157. Noob and in desperate need of advice
  158. Start issues
  159. R56 Belt Tensioner (friction wheel) replacement
  160. 2011 MCS Convertable - Automatic 50k - P173B + P0128
  161. New guy, weird headlight issue
  162. Extended Warranty on 2012 Water Pumps
  163. Real weird braking issue on wife's 2010 clubbie.
  164. Two Starters in less than Two Months?
  165. 3rd Melted Valve Cover after Track session
  166. Fan running after shutdown
  167. Unusual Oil Problem
  168. Battery Swap Now Windows and Turn Signals Do Not Work
  169. UK member needing help : Low speed judder / pulsating through brake pedal
  170. Fuel Gauge Stuck On Full
  171. oil leaking under Eccentric Shaft Sensor
  172. P0303 Misfire
  173. Mass Air Flow Sensor
  174. Heat not blowing Hot!
  175. R56 Turbo Issues
  176. R56 Rough Idle
  177. Junction box Empty spot
  178. Secret Compartment, Upper Glove Box,FIX
  179. Unconnected plug?
  180. Plastic End Cap for chrome trim strip
  181. R56 cranks but won't start
  182. HPFP issues? Or just the fuel line?
  183. clunk from front suspension over uneven roads
  184. $900+ for hpfp part only! What the!!!
  185. Time for a new oil filler cap?
  186. vacuum Line or hose location for 2012 Cooper S
  187. footwell module howto
  188. Carbon Cleaning N18 JCW 2013 51K miles
  189. R57 turbo warranty extended??
  190. Brake Pad Wear Sensors?
  191. Oil sludge-ing in ~300 miles, tripping pressure sensor?
  192. ECM/DME Failure
  193. smoke on startup
  194. Clubman cranks but won't start
  195. Dead 'Key' Battery?
  196. What is this sound?
  197. Is the cold climate intake manifold a direct swap?
  198. Auto Transmission jerk, surge, stutter t low RPMs
  199. Inspection failed
  200. Automatic trans replacement
  201. Independent repair shop in San Diego
  202. How can I quickly restart after stalling?
  203. Leak at water pump: Replace pump? Or only the seal?
  204. Fuel pump or HPFP please help or injectors
  205. Replacing Oil Filter Stand Gasket. What else?!?
  206. Misfire on cylinders 1,2
  207. 2B5C code with funny idle freeze frame data included
  208. R56 Bad Starter?
  209. Vanos and transmission fault N12
  210. 2f07 Map Thermostat , mechanism. Already changed the thermostat.
  211. New 2011 MCS R56/N18 owner - Whistle noise.... -_-
  212. Vacuum Pump Replacemet
  213. Coolant leak but still holding pressure
  214. mini wont start
  215. Clunks on bumps
  216. Help! Advice 2008 75K Clubman major exhaust & engine
  217. Humming sound
  218. Turbo oil leak
  219. (UPDATE) Cylinder 1 and 4 Misfiring (UPDATE)
  220. Auto Trans fluid level problem
  221. Need some headlight bulb info
  222. Gaskets for Xenon Ballasts?
  223. Rear Tail Lights.!!!!
  224. Idle Issues
  225. Oil in coolant, overheating, bruning oil
  226. Engine malfunction reduce power mode - No CEL?
  227. Cylinder 1 and 4 Misfiring
  228. Repair Manual
  229. Thermostat Warranty Question
  230. 08 mini cooper clubman s misfire.
  231. 2B64 (P1497) Unmetered Air help
  232. 2008 Mini Cooper S will turn but not start after car battery replacement
  233. Dme cloning
  234. Vacuum Pump Lower Line
  235. Idle at Start Question
  236. Vanos
  237. Seatbelt/ airbag light 2011 MCS
  238. Cylinder misfire
  239. Vehicle Inspection Light
  240. Milky substance on oilcap
  241. limp mode with cc id 029 and cylinder 3 and 4 misfire
  242. Suspension issues
  243. No heat after low coolant
  244. Cel p052b
  245. 2007 Mini R56 won't start.
  246. Auxiliary Water Pump Hissing after being changed
  247. Limp Mode
  248. Battery warning light but multimeter shows 12V?
  249. R56 Turbo wastegate
  250. 2009 Clubman base HIGH oil consumption - PCV?
