R56 Rough Idle
Old Feb 11, 2018 | 08:08 AM
nomar116's Avatar
nomar116
R56 Rough Idle
My 2009 MCS has a great MINI service history until I bought it about 2 years ago. The car just went above 130k miles, the last 40k or so I have owned it and done all the service myself. Lately, the car has developed a bit of a stumble / rough idle. It might be a miss but I'm not 100%. This happens most of the time at idle, the few times it doesn't happen I can't really explain yet. The car pulls great under throttle.
I have been regular with the oil. I have a craven dipstick to help with that. I have not done any ignition work nor do I know if the car has had any carbon deposits removed.
It just bought an F56 and I'm planning to sell this car. I would like to get her purring smooth for the next owner, but I would also like to avoid anything too major.
Anything obvious stand out that might cause this?
Old Feb 11, 2018 | 11:55 AM
Sleepy289's Avatar
Sleepy289
Given the mileage, wondering if one of the coils is going bad - do you experience rough idle under wet conditions (like after it rains/snow) but not under dry conditions? Any CEL or DTC codes that is indicating a misfire in any of the cylinders?
Old Feb 11, 2018 | 02:53 PM
nomar116's Avatar
nomar116
It doesn't really rain or snow too much here in California so I can't honestly say about how it does in the rain. The issue happens when it is dry. Also, there is nothing set on the dash for CEL or DTC but I haven't pulled codes. Not sure if I have the ability to pull them.
Old Feb 11, 2018 | 05:50 PM
AZdsrt's Avatar
AZdsrt
Given the mileage and you don't know the history, bet it's carbon buildup on the intake valves. Only way to know, take off the intake and take a peek..
Old Feb 12, 2018 | 10:46 AM
nkfry's Avatar
nkfry
Could be any number of things:
Carbon buildup
VANOS solenoid
Thermostat (I wouldn't jump to this if you don't have a CEL light)
Spark plugs
Compression issues (unlikely if the car runs happily)
HPFP starting to fail
etc
etc
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Feb 12, 2018 | 08:20 PM
shanksamillion's Avatar
shanksamillion
I'd first replace your plugs if you've never had this done. This is very easy to do. Then clean up those intake valves. They get gunked up pretty quick. If it's still idling rough you'll have to work through the other items mentioned. I'm facing a problem myself right now. I've got a bad misfire problem now. Almost sounds like a bad timing issue. The problem for me happened while driving on freeway. I'm gonna try another thread because I've got a lot of questions. Good luck man.
fixthedoor
R55 :: Clubman Talk (2008+)
Sep 14, 2016 07:03 AM
Mark Arnold
Jan 30, 2012 10:53 AM
Kwasi-moto
Dec 27, 2011 02:34 AM
Nj05mcs
Nov 5, 2011 03:30 PM
Ted Stevenson
Apr 2, 2011 05:55 AM
