PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. 4th cylinder problems
  2. Serpentine Belt Alignment Issues
  3. Cold Weather Lack of heat
  4. 09 R55 won't start P0503 code
  5. Oil CHange killing Coils?
  6. Car not starting! Turns over but won't fire! Please help!
  7. Windows auto up not working
  8. turning but not firing
  9. Rough idle, p0303 code, oil in cylinder tube
  10. P10d1 engine code
  11. New twist on the rough idle problems?
  12. HELP No power to fuel pump 2011 r56 s coupe
  13. HELP- Can’t change gears (first post)
  14. Went through huge puddle, now no electronic assisted steering
  15. R55S With P052B Code
  16. College student, need help with heater and clutch
  17. Replacement of timing chain
  18. Stupid mini
  19. Mystery Noise! Oil overfill? Turbo?
  20. Advice to fix shifter free play?
  21. Starter replacement
  22. R56 Passenger Seat Occupant Pad
  23. 2012 S R56 Diminished value.
  24. Turbo Oil Line
  25. Vibrating engine
  26. Mini = Uncle Buck Smoke Show
  27. Heat only blows when driving, cold when idle, fan speed slows
  28. Warning Chime Stopped Working 2013 Mini Cooper
  29. JCW High Pitch Squealing Noise
  30. 2010 Camden Transmission problem after engine swap
  31. 2014 r58 p304
  32. Hard to warm up cabin
  33. Things to replace while doing timing chain
  34. R56-R61 Oil Pans
  35. 2011 R56S N18 Timing Chain Instll (No crank lock hole)
  36. bi-xenon headlight replacement.
  37. Which valves to purchase?
  38. Misfire with o2 sensor code
  39. Misfire codes and oxygen sensor code
  40. R56 burning oil smell when climbing mountain
  41. 2013 R55 base random misfire and at 1, 3, and 4.
  42. How to destroy your CAS Module
  43. Febi Timing chain kit?
  44. 2011 R56.... Need Help with possible causes of blown head gasket N18
  45. Mini Mixture control injector code 2BC5
  46. Electrical Problems
  47. Smoke after long idle and low vacuum at idle
  48. The Possible End of The Line
  49. 2011 MC S Wont Start After New Battery
  50. Please help with these codes 08 S 123k miles Pics attached
  51. Oil filter housing leaks coolant? $1700
  52. Strange issue
  53. What are Valves made of and can I clean them?
  54. Automatic transmission with no forward gears
  55. Rear main seal on auto n18 r56
  56. 09 R56 no start
  57. Coolant leak? and A/C not working
  58. 08 s cranks but no start... tried everything.
  59. N14 Valve Cover Dowels
  60. 2009 JCW cabin fan issue
  61. The trim on my r56 hatch fell off.
  62. potental battery problem
  63. Do you have to pull throttle body on a Non S r56 to change tensioner ?
  64. No Top End Power?
  65. Could this mean Blown head gasket, White milky oil under oil cap
  66. 2B5C Mass Air Plausibilty - Fixed- Walnut Blast
  67. Serious lighting issue
  68. HELP! R56 sounds like WRX, Power loss
  69. Oil Pan: Silicone gasket vs fel-pro gasket
  70. Problems with engine
  71. 2008 R55 Cooper S - Multiple Problems - Advice needed
  72. Cold (no)Start - no codes
  73. Inner CV Band GONE
  74. Cold weather suspension knocking.
  75. Boost leak?
  76. Clutch covered, flywheel not?
  77. P0108 MAP Sensor (I think)
  78. New Fuel Injectors
  79. Catalytic converter replacement?!
  80. Coolant leak on Passenger side
  81. Rattle / Knock from Rear Sunroof
  82. No start after brake flush/maint light reset
  83. R56 N12 (non-turbo) Timing Chain replaced P0014 & P0015 codes
  84. Multiple misfires on cold start
  85. Cooper S Clubman- Gremlins Galore!
  86. Overhead switch panel loose
  87. Knocking sounds,I checked timing dont think its that made video
  88. Melted spark plug end
  89. I think I broke it. :(
  90. Timing chain rebuild questions, like replace anything else while in there ?
  91. Cold weather alert chimes, will not STFU!
  92. Fuel rail pressure sensor....Don't buy a rail!
  93. WTB or Rent Fuel Injection Tool Set
  94. Should I do an auto trans flush mcs 2011
  95. In need of help
  96. 2011 S N18 Engine: Eccentric Shaft motor Issue
  97. Front Brake Service
  98. squeeky window when going up?
  99. hose dilemma
  100. wiring connection dilemma
  101. Hpfp reading low when braking???
  102. 2012 Coupe no start, but power
  103. New to me 2011 mcs @ 111k p052b code vanos issue?
  104. Removed CAT and found these? What are they?
  105. Fault code P1338, proper description and common causes?
  106. Looking for a thread on a sticky wicket -- no, a sticky throttle on R56 with the N14
  107. Sunroof switch loose
  108. Rear rattling noise
  109. R56 non S , cold start problem
  110. HPFP help
  111. Low/no oil on dipstick?
  112. 2010 Mini Cooper base vanos issue
  113. Hood Latch issues
  114. Are the flywheel bolts torque-to-yield (one use) or OK to reuse with Loctite
  115. EWS issues? crank but no start r56 jcw tunning kit
  116. Crank No Start Issue Finally Found
  117. '09 clubmas S TPMS light
  118. 2011 S N18 Engine: Oil Sensor short to ground
  119. Engine stuttering slightly when accelerating HARD
  120. Fuel Rail Pressure gauge tester
  121. Interior lights and radio turn themselves on when car is parked
  122. Missing Valve Cover Dowel
  123. Valve cover in vaccuum
  124. Knock/rattle on re-assembly-VANOS or chain?
  125. Fan “on” often after thermostat chx
  126. 2009 JCW chattering/rattling after timing chain remplacement
  127. P0697 code after valve cover eplacment
  128. Unknown Part Identification Help!
  129. 2013 N18 headlight internals loose
  130. p173b
  131. R56 p1638, p2b32, p2b2b
  132. No start
  133. Foxwell Scanners (also sold under Schwaben name)
  134. R56 S won't start
  135. '11 Cubman S, studder/pop at start 20 secs, 1/2 power codes B202C P062E B202E B202B P
  136. Another starting/battery/alternator/starter issue
  137. Where can I get the plastic fitting that goes into bottom of coolant reservoir?
  138. Odd headlight issue....
  139. Cost Estimate for WaterPump / Accessory Belt replacement? Mechanic Rec in Boston?
  140. A/C Compressor harness diagram
  141. Limp Mode/Won't Start
  142. Removing the lower control arm HELP
  143. Vacuum Pump Ceased-- Recommendations?
  144. Need help with epoxy/glue
  145. Concerning Engine Buzzing in new to me N18 R56s
  146. 2010 mini r56 N14, high pressure fuel pump
  147. 2012 R56 Rough running
  148. Cold Start issue- Help Please
  149. Valve Stem Height
  150. Turbo failure?
  151. mini r56 adaption issue
  152. High Mileage Maintenance Must
  153. Code P2885
  154. High pitched whirring sound
  155. Which N14 Vacuum Pump
  156. Help with terrible idle n14
  157. Help! 08 clubman oil cap stipped
  158. Anyone ran into this problem?
  159. engine problems ?
  160. Changed thermostat housing now car is in limp mode
  161. instrument cluster dead along with alot of other things!!!!!!!
  162. DIY battery replacement help w IBS equip Mini's
  163. O2 sensor
  164. Off/on Brake light
  165. Rapid "machine gun" noise burst A/C
  166. Intermittent ticking at idle
  167. Need some help no power to coil pack
  168. mini s valve time actuator full of oil?
  169. Footwell Module Lights and Unidentified Connector
  170. Timing confusion?
  171. PCV repair question
  172. Gas in spark plug well
  173. New to me mini ,,idles rough got codes..
  174. R56 N18 drinking it(oil)
  175. 2007 Base R56 Electrical issues and Codes P110F & P1551
  176. Low compression in one cylinder, going to try to install rings
  177. ABS issue with one wheel speed channel
  178. engine light stays on
  179. Rattle noise and recall for timing belt question
  180. Fault Code 27BA
  181. Alternating misfires
  182. 07 Cooper S N14 Turbo Won't Start!
  183. Battery light warning
  184. Fuse Box Electronics replaced and now Battery light comes on
  185. 2008 Mini Cooper S no start
  186. DM computer
  187. Misfire n12 justa cylinder 2
  188. Starts, Revs, then Dies
  189. How screwed am I? Q about low compression in one cylinder
  190. No start issues: startup sequence
  191. Mass Air Flow Plausibility Code -Leak Found-Picture
  192. p1434 and ccid 031
  193. 2009 boiling over issues
  194. Solid Yellow Engine Light, Odd codes
  195. N14 mechanical vacuum pump delete
  196. Flasher Problem
  197. Fault Code 2EE2, cant find any information
  198. Replaced High Pressure Fuel Pump-Now Shows P0001 DTC
  199. Citroen parts
  200. 2010 R56 MFI Stuttering & Misfiring
  201. Mini Cooper S R57 engine turn off while driving
  202. 2007 Mini S R56 Code Question
  203. R56 base cranck but no start(good battery)
  204. exhaust manifold harmonics
  205. Cleaning throttle body - need to replace gaskets?
  206. 09 clubman windshield wipers not working.
  207. Oil pressure at ide nightmare - Tried just about everything!!!
  208. Same engine auto vs manual?
  209. Smokey
  210. Raleigh NC area independent shop question
  211. 283d error code - vanos adaptation stop
  212. Water leak under the rear carpet (soaking)
  213. anyone know the P/N for the downpipe brackets or have a spare to sell me?
  214. 2013 R56 missing fuses and diagram descriptions. Harm in replacing?
  215. Mini r56 engine noise issue
  216. Dead Windshield Wipers
  217. Any answers on specific recalls for early R56S'
  218. Changed my Thermostat.....
  219. Help troubleshooting downstream oxygen sensor heating element
  220. Suspension collapsed/snapped - help me buy the right part
  221. Turbo leaking coolant
  222. Coolant leak help
  223. N14 Tools and Parts
  224. Clubman Idles Fine but Upon Acceleration Stumbles and Not Driveable
  225. Red Parking Light stays on
  226. Car shutoff while driving
  227. N14 front main seal help.
  228. Engine reassembly question
  229. the story of the 2009 clubbie and the evil VANOS solenoid.
  230. 2009 Popping a CCID 031
  231. p115d need help
  232. Check engine light Mini R57 code: 12098
  233. Brakes randomly applying
  234. What's with the 1100 Mile Brake Service "reset". Changed all pads but can't reset.
  235. safety neutral switch or safety start switch
  236. New Throttle Body, now turbo won't come on...?!?!
  237. My JCW Isn't Starting
  238. Road Trip...Limped Home...
  239. R56 Base difficult cold start.
  240. TPMS problems
  241. Tranny install
  242. Rear Intake VANOS replacement for P0012 - Tips and Tricks
  243. Problems at higher acceleration
  244. Clutch Issues
  245. 2011 Cooper S Countryman All4
  246. 2009 S Rear brake pad wear sensor part
  247. Chewie Flywheel Noises After Just Three Weeks?
  248. How to inspect / refill torque converter off car
  249. High pressure fuel pump replacement
  250. Question on towing
