09 R55 won't start P0503 code
Old Jan 28, 2019 | 03:33 PM
sflowe's Avatar
sflowe
My 09 Clubman 2 wouldn't start this morning. No problems until now. My code reader read 4 codes p0340, p0343, p15E8 and P0503. On the second read, all cleared except P0503. I'm not sure where to start.
Old Jan 30, 2019 | 01:53 PM
guspi76's Avatar
guspi76
Remove valve cover and inspect the timing chain and it's guides. Looks like you skipped a tooth or two. There should be tension on the chain... If not, you could have bent some valves. Do not crank the engine until you inspect these components....Good luck.
Old Jan 31, 2019 | 04:29 AM
sflowe's Avatar
sflowe
Thank you! Someone told me that from the code it threw, that it could also be the spark plugs. Do you think I should start with the timing chain first and then the spark plugs?
Old Jan 31, 2019 | 06:53 AM
guspi76's Avatar
guspi76
Yes, it takes like 10 mins to pull the valve cover and check the timing chain. It’ll be obvious. The plastic guides should look intact. Look into Pelican Parts for pictures of what it should look like. They have a How to step by step on the timing chain.
Old Jan 31, 2019 | 08:14 AM
sflowe's Avatar
sflowe
Thank you so much! I appreciate your help.
squawSkiBum
2nd Gen FAQs
Oct 21, 2019 06:58 AM
Scarecrow Soze
Jan 9, 2019 11:00 AM
SX-70
Jan 6, 2019 12:00 PM
mscarano
Dec 9, 2018 05:05 AM
squawSkiBum
Nov 14, 2018 11:20 PM
