PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. 2007 NON Turbo Oil Filter Housing Removal
  2. trans case, flywheel, clutch torque spec?
  3. PCV Hose or Crankcase Breather Hose
  4. Working on a neglected 2007 Mini Cooper S with various issues. Need some help.
  5. Stuttering and EML
  6. Urgent Help Needed!
  7. Unusual problem in stop and go traffic
  8. New key but car wont start
  9. Missing boost
  10. Looking for the intake valve walnut blasting setup (NJ/NYC area)
  11. Help! PS? Pump? Pulley?
  12. Replacing oil housing gasket on base r56 (no turbo)
  13. Fob Stuck Mini Thinks It’s In Reverse
  14. Throttle Body excessively dirty
  15. Check Engine Light - MINI says unrepairable
  16. Catalytic Converter Recommendations
  17. Re Programming ABS module
  18. Mirror's not working
  19. Engine vibration upon moderate acceleration.
  20. zenon bulb spacing in the head light, not enough room to remove bulb
  21. 2012 R56 Red Oil Light for brief moment
  22. 09 fjcw missing and backfiring under heavy load
  23. R56 Will Crank but Will Not Start(Sorta)
  24. Cold start problem like no other, ticking noise while accelerating?
  25. 2009 CAB Short Issue
  26. 2010 clubman s won't start... just put in New battery
  27. Broken 2011 Justa
  28. 2010 Mini Cooper S 70,000+ miles
  29. Spark Plugs and Oil/Filter Change
  30. Comfort Access help
  31. FOB/key/hood latch
  32. R56 N18 crank seal leak/replacement. How often?
  33. My Mini is currently a very large paper weight. HELP
  34. Paddle Shifter Problem
  35. Front crankshaft seal tool
  36. Oil change via dipstick?
  37. High idle on start up when cold
  38. R56 hatchback cooling system has me stumped
  39. Post Tensioner, Valve Cover, Vacuum Pump Service “engine noise”
  40. Maintenance recomendation for a r56 2007 n14 130k
  41. Brake Fluid Leak Passenger Side - Cooper S
  42. 2010 R56 Cranks over but will not start
  43. Terrified: AAA Car Care Plus says I need an Engine Replacement?
  44. Engine light/rough running
  45. New thermostat problems.
  46. Wind noise
  47. R56 won't start, only crank once
  48. Weird headlight short
  49. Contemplating on fixing some issues - front strut mounts?
  50. Engine cuts power briefly and randomly
  51. What is this thing? (VANOS actuator)
  52. wastegate actuator mounting damaged, what's my options?
  53. Sounds like spark is jumping
  54. Rear engine and drivers side oil leak R55/N18
  55. OE Ignition coils or Bosch for R56 Base
  56. R56 N12 Engine Oil Leak - pic attached
  57. 144K used 2011 Cooper S tuneup. Should I replace the coil packs?
  58. Code P1497, trouble finding leak
  59. Rebuilding an HPFP? I mean, I have four of them. Don't laugh at me! :)
  60. Turbo died
  61. Rear latch issues
  62. PCV and Idle issues
  63. fuel shutoff after injector replacement
  64. Intermittent noise from the drivers side engine compartment when cold
  65. N14/N18 High Pressure Fuel Pump teardown and refresh
  66. Do PCV mods really fix carbon buildup?
  67. Bad spark plugs?
  68. Huh?
  69. P0015, P0014 Help!!
  70. Crazy noise, like nothing I’ve seen before
  71. Cc-id 128
  72. Misfire, Lack of Acceleration and Rough Idle
  73. Alternator failure (non oem replacement)
  74. Should I be able to hear/feel the fuel pump?
  75. Low oil and cold weather questions
  76. Issues with Locking
  77. Strut mounts cleaning and greasing
  78. Best way to get rid of misfiring r56
  79. Oil Pressure Control Valve Codes
  80. Coil question
  81. Timing Chain tensioner hell....p
  82. Importance of Camshaft Solenoid?
  83. Installed New Timing Chain 2007 R56 - My Observations
  84. Engine Fan Won’t Stop Running!!
  85. Is the Hpfp extended warranty?
  86. Transmission Range Switch confusion....
  87. sharing my problems/solutions
  88. Southeast Rebuild Shop
  89. Engine Light puzzle
  90. R55 oil filter leak/coolant leak 2012 clubman
  91. Both horns inop - relay clicks, does the click mean the relay is good?
  92. 2013 Mini Cooper Reduced Engine Power
  93. Preventative maintenance on MCS 2013
  94. Boost deviation
  95. Rebuilt head. Runs good but still has codes
  96. 2008 R56 Throwing Codes P2187, P2195, & P2097
  97. 2008 R56 Throwing Codes P2187, P2195, & P2097
  98. Windshield Replacement
  99. Melted Coil Pack and Damaged ECU?
  100. Thermostat housing recall?
  101. All Revved Up!
  102. Did I do that?
  103. indicators not turning off after turn
  104. One man bleeding machine!
  105. P0087 Code - Cold start-up
  106. Blown engine after oil change...now transmission issues. Help!!
  107. Mini Cooper R56 Auto Transmission Fluid Change
  108. hello everyone new clubman s..well "wife" is owner lol
  109. misfire cylinder 3 2011 clubman s
  110. misfire
  111. Fob and delay of lights + trunk open
  112. Question about lifters
  113. Clutch Master
  114. Front Crank Seal
  115. N12 clutch kit replacement advice
  116. High Pressure Fuel Pump or something else?
  117. ABS Trifecta Warning Lights
  118. 2009 R56/N12 -rough idle/warm - can VANOS be bad w/o a code?
  119. R56 Door Sill Plate Lifting
  120. P0112B code keeps coming back.
  121. Hood release broke
  122. N14 valve cover replacement
  123. Unplugged BOV Diverter Valve Harness
  124. Just a heads up for garages to work out of..
  125. Combination Switch Help!!!!!
  126. Strange TPMS Codes...
  127. Driver heated seat inop
  128. Car turns over but won't start.
  129. Headlight Bulbs - possible replacement
  130. No start mystery solved
  131. mini cooper s access needed to change oil filter housing leak
  132. Help!!! Replaced t-stat, clip fell, removed intake, now won't start!!!
  133. trans fluid change on a manual
  134. Roll up Window - URGENT!!!
  135. TPM transmitter rear location?
  136. Trying to understand N16 heavy soot on tailpipe
  137. 2010 R56 Base - motor problems
  138. Another FRM issue
  139. Intermittent interior heat and yellow coolant temp warning light
  140. rear shock replacement
  141. Thermostat NOW Oil Light
  142. Need a little advice
  143. R56 oil leak - already think I’ve hit most of the usual suspects
  144. TRansmission fluid change
  145. Rad not turning on
  146. Can't Solve P0303 "Cylinder 3 Misfire Detected"
  147. What are these wires to?
  148. Heater delay
  149. How to shut off passenger seat light
  150. r56 6MT woes...
  151. Coolant leak 2012 mini r60
  152. recurring P0303 code
  153. Help in assessing compression and leakdown test results
  154. Caution symbol
  155. Headlight Issue
  156. new guy with bad temp
  157. R56 2007 shifter trouble
  158. R56 non-s engine knocking sound
  159. 2007 R56 MCS Oil Leak
  160. P1497 Engine Light
  161. Indicator light need help
  162. 2010 Mini Exposed flywheel - Is that normal?
  163. Starter differences
  164. Oil seepage
  165. Foot Well Module!
  166. r56 powerfold mirror not indexing correctly
  167. Flashing lights both interior and exterior
  168. New Member -- Oil Pressure Issue
  169. R57 misfire #3; Runs great w/out intake cam sensor connected; HELP?!
  170. Volume Control Solenoid, is there an extended warranty service for this issue?
  171. 2008 Mini Cooper Auto Trans question
  172. 2007 no boost
  173. found part of the oil use on my R56
  174. Knock Sensor
  175. A/C Blows out of the wrong vent
  176. Hazards not working
  177. Outside temp question
  178. 2009 MINI Cooper EGS Fault
  179. Fault Code Help
  180. 2011 Cooper S Cold Start Question...
  181. Clicking Relay - Bad Ground?
  182. No start after fuel filter change: Help!
  183. Code 2885 Boost Deviation Plausibility Error Solution
  184. PO117 code issues, any advice?
  185. and another oil consumption question
  186. 2008 cooper CBS problems
  187. 07' MC Base torque specs?
  188. Need help finding a headliner clip - ECS? Anybody??
  189. P0141 & P3018 (aka 2A56 & 2A90) on 2007 One (non s) 1.4/MT
  190. Oil drain plug leaking
  191. 2009 Clubman Climate Control Random Venting
  192. Misfires and white residue from engine
  193. Shifter not centering
  194. Coolant leak
  195. 2013 Wiper Blades/Arms
  196. Clutch Question
  197. Headlight issues
  198. 2009 Cooper S R56 codes: P0503, P1497 and P0303
  199. Blower fan whine
  200. 2011 mini conv light for oil change
  201. Hey look another oil consumption thread....
  202. DSC Speed Sensor Location - HELP?!
  203. Unlocking VVT sprockets from cam?
  204. Automatic Temp Control Blower Motor Problem
  205. Engine light on after topping off coolant
  206. Orlando Mini
  207. Won't start and steering is unlocked after clutch job
  208. Control Arm bushing Leaking Fluid? 2011 r56 n18
  209. LOUD hissing, but from WHERE??
  210. Overheating
  211. Coolant boiling in overflow tank
  212. Ticking noise coming from motor
  213. 02 mini Cooper Starter suddenly wont crank.
  214. Complete Head Rebuild
  215. FOB rusted. Not able to release hatch back
  216. P053A PCV Heater Circuit Open
  217. Mini Cooper S trouble vacuum leak? Fuel Pump? (Video inside)
  218. battery specs
  219. Suspension Knocking/Rattle Over 80mph
  220. Codes 2EFF, 3F00, 2EE2
  221. Clutch on my 2007 Mini Cooper Super S is going out? Can I adjust clutch?
  222. Wifes R55 p0300 code cyl 2 & 4?
  223. Starting issues, engine light on
  224. CV axles?
  225. Battery issues? Help!
  226. Engine rattle
  227. VANOS Solenoid Replacement / Reset DME Adaptations
  228. Cat temps soaring!
  229. Fuel pressure 1100 psi at idle?
  230. sunroof scrolling tint issue
  231. P0141 Engine Code Associated With Empty Tank
  232. Tapping noise from accesory belt
  233. r56 MCS manual wont turn on with clutch pedal depressed
  234. Higher Engine temp after new larger Intercooler cracking coolant hose.
  235. Reduced Engine Power and no boost
  236. throttle body on R56
  237. Auto Start Stop isn't working
  238. 2010 Clubman S No Compression, Rebuild Questions
  239. The BEST bov for mini R56
  240. Stalling and rough idle in my 09 clubman
  241. Gen 2 clutch problems
  242. In need of help with clutch problems R56 coupe hatch s turbo
  243. Cooper d turbo problems
  244. Do I need any ECU tuning after timing chain replacement?
  245. 09 Clubman S, persistent limp mode uphill
  246. R56: Acceleration falters badly at 2000 rpm
  247. Mini R56: Acceleration falters badly at 2000 rpm
  248. Where can I find wiring diagrams for my 09 sport?
  249. half engine light
  250. Strut replacement for 2010 Mini Hatch
