Oil drain plug leaking
Old Oct 29, 2017 | 03:45 AM
Shane Jones's Avatar
Shane Jones
i have a 2008 clubman. I just done an oil change. I noticed the drain plug had been way over tightened. Anyhow now I have a drip. I replaced the crush washer when changing oil. Will a new plug help? If not any other solutions?
thnk you
Shane
Old Oct 30, 2017 | 08:22 AM
crazy4trains's Avatar
crazy4trains
Sometimes the crush washer can have a defect or a crack causing a leak. Try replacing with a new crush washer first.
Old Oct 30, 2017 | 08:34 AM
R56devotion's Avatar
R56devotion
Get a new drain plug and crush ring from dealer. The overtightening could have marred the surface of the pan and created an inability to seal. Knock the spurs down with a file. I always have a spare in the glovebox in case I have a service problem when traveling.
Old Oct 30, 2017 | 01:26 PM
Shane Jones
Old Oct 30, 2017 | 01:32 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
If all else fails you can buy a Fumoto or similar drain plug and use some sealant to keep it from leaking. Then you don't have to remove it.
Old Oct 30, 2017 | 01:46 PM
ashchuckton's Avatar
ashchuckton
Try a new drain plug & crush washer. DON'T use a Fumoto valve on your car. On your engine it will be pointing straight down waiting to be ripped off.
Old Oct 30, 2017 | 01:52 PM
UW Mitch's Avatar
UW Mitch
Fumoto works great on R53 - it's pointing rearward. If it's pointing downward in later models, would be a bad idea.
I love my Fumoto on my R53 and my F250 (where it points downward but protected and I don't go offroading).
Old Oct 30, 2017 | 02:47 PM
Capt_bj's Avatar
Capt_bj
Fumoto comments 110% correct .. good for GEN1 ... BAD for GEN2
if a new metal seal continues to leak, consider a fibre one .... any decent autopart store can provide a seal in the same size in fibre and it will work just fine. Being a lil softer, you MIGHT get the drip stopped. To try will only cost about a buck.
The bung on my 79 dripped when I bought it, so I started using a fibre seal (not included in the Mini design) and have had no drips or other problems (in this area) since.
Old Oct 30, 2017 | 04:04 PM
R56devotion
A proper size copper crush washer is soft enough to conform to mating surface. PLEASE do not use a fiber one- trouble waiting to happen. A new plug will have fresh threads and a new sealing ring will do the job.
An easy fix for YOU!!
Old Nov 3, 2017 | 09:22 AM
patpatpat's Avatar
patpatpat
You can also get a topsider fluid extractor. You can extract the oil via dipstick and not touch the drain plug for your oil changes.
Old Nov 3, 2017 | 12:05 PM
bugeye1031's Avatar
bugeye1031
Moderator
Topsider Recommendation?
Have you used a topsider that you would recommend? Tried a MityVac 7201 and it sucked out about a quart before it gave up....returned it.
Old Nov 6, 2017 | 05:48 AM
patpatpat's Avatar
patpatpat
The brand is Topsider. Pretty much all steel construction. The one I got is blue and you can screw off the hand pump and suction hose and cap them when done for easy recycling
