half engine light
Old Oct 5, 2017 | 05:34 PM
minifromhell's Avatar
minifromhell
half engine light
Just left the shop after having the thermostat housing replaced. Car seemed a little sluggish but I was re-adjusting from driving my friends Miata (that broke down on me on my way to work this morning} Next...half engine light came on. Soon after, the car seemed to be running fine and I made it home. Out of curiosity I restarted the car and the light did not come back on. Anyone? Anyone?
Old Oct 5, 2017 | 09:52 PM
MannyJimenez's Avatar
MannyJimenez
Do you have an OBD2 adapter/reader? Without a code there isn’t much we can tell you
Old Oct 6, 2017 | 03:52 PM
gjxj's Avatar
gjxj
fyi the yellow-half-engine indicates limp mode. if it repeats limp it back to the shop, maybe they left a sensor disconnected or something.
I'd be checking the fluid level as well.
Old Oct 7, 2017 | 04:15 AM
mustangcruise's Avatar
mustangcruise
I would also check the vacuum lines. With the work that was going on in the same area as the lines, one of them could have been disconnected by accident.
Old Oct 9, 2017 | 11:44 AM
Jeffair10's Avatar
Jeffair10
The half engine light came on for my 09 Clubman S, briefly. That was the beginning of a pesky problem that was finally tracked to be a faulty ignition relay. Even the MINI shop computer set up didn't find a code for it.
Old Oct 10, 2017 | 08:48 PM
Cngizbleevng's Avatar
Cngizbleevng
Along that same line, mine came on due to a vacuum leak. Had to replace a couple hoses.
RedCountryS
22
Nov 15, 2020 04:34 PM
AJoelj84
Dec 24, 2017 09:58 AM
MasterShaftner
Sep 1, 2017 07:23 PM
vincedprince
Apr 24, 2017 11:46 AM
RedCountryS
R60/R61 Stock Problems/Issues
Jan 1, 2017 08:11 AM
