Importance of Camshaft Solenoid?
Old Dec 12, 2017 | 01:17 PM
Frixos's Avatar
Frixos
All,
The engine light for my 2009 R56 came on, and I brought it in to my Mini shop. He said the code had to do with the Camshaft Adjuster Solenoid and the solution was to replace it (he recommended just doing both).
I haven't noticed any problems with the car besides the engine light, and I asked him what'd happen if I didn't replace them. He said nothing - no damage will happen to the car if I don't replace them.
I'm all about saving money, but would you say he's right? I have already replaced the camshaft timing chain 30k miles ago (at 110k now).
Old Dec 14, 2017 | 02:01 PM
nkfry's Avatar
nkfry
The car will run poorly, rough idle, hard starts, low power, misfires, all sorts of stuff.
If you want a cheap option you can try pulling the solenoids and cleaning them out, but that usually only buys you a few months, I'm not sold on "if you're replacing one just replace the other", they're not the cheapest.
If you've got a fault for a VANOS solenoid start with cleaning it, if the fault persists replace it.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 14, 2017 | 02:29 PM
Frixos's Avatar
Frixos
Thanks!
I was looking at this article:
http://www.pelicanparts.com/techarti..._Replacing.htm
It doesn't seem too complicated. What are the things that could go wrong?
Old Dec 15, 2017 | 06:22 AM
nkfry's Avatar
nkfry
Originally Posted by Frixos
Thanks!
You'll make a small mess with the oil that leaks out of the ports; other than that it's a very straight forward job.
Phone:586-792-6464
Old Dec 16, 2017 | 06:25 PM
Frixos's Avatar
Frixos
thanks! I’ll go ahead and do it myself.
when the article speaks of a fastener, do you know what I need?
Old Dec 16, 2017 | 08:56 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
www.realoem.com for part number, probably the bolt or screw to attach to engine is "fastener".
Old Dec 18, 2017 | 06:42 AM
nkfry's Avatar
nkfry
The bolt holding them in will either be a T30 or a 10mm cap head.
Phone:586-792-6464
Old Dec 18, 2017 | 09:02 AM
Entmejia's Avatar
Entmejia
Replaced both solenoids and sensors on my 2010 R56 a few weeks ago. Car runs much better. Some things to watch for:
- Some say can't reuse attachment bolts, I reused mine with blue thread locker
- Limited access on firewall side solenoid, best to remove the air intake tube
- Difficult to grasp solenoid bolt while unscrewing, which means the bolt could fall into the engine compartment. Mine did, and luckily got stuck on the drive belt pulley. Had to magnetize a long screwdriver to get it out - could have been a disaster. I would put a rag under the screw to catch it if it falls while removing.
- Kept getting CELs after replacing parts. Took it to the Mini dealer and they reset the adaptations, not expensive but worth knowing.
Good luck hope it works out for you.
TheMadDane
Aug 6, 2009 12:37 PM
donjulio
Dec 13, 2007 10:20 PM
dwdyer
Oct 12, 2007 03:01 PM
bean
Driver's School
67
May 2, 2007 06:24 AM
