Oil seepage
Old Nov 9, 2017 | 07:56 AM
Brahmcts's Avatar
Brahmcts
Oil seepage
Hoping for a little insight as to possible causes for the oil shown in these pictures. The dealership I work for (non mini unfortunately) sold me the car 2 months ago and I still have a little of their warranty left.
Perhaps a few others on here have an idea as to what the issue is.
side note: I'm take terrible photos, sorry about that
As always thank you
Old Nov 9, 2017 | 07:59 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Best thing to do is clean it all up REALLY good, then keep an eye on it to find the leaking point.
Old Nov 9, 2017 | 08:55 AM
Brahmcts's Avatar
Brahmcts
Going to have it cleaned up and put back on the lift, crossing my fingers for something easy
Old Nov 9, 2017 | 10:10 AM
MtDew's Avatar
MtDew
Could be as simple as some spilled oil from replacing the oil filter. Could also be leaking gaskets from the oil cooler. Do as mentioned and clean the area.
Old Nov 9, 2017 | 10:46 AM
bugeye1031's Avatar
bugeye1031
Moderator
This is excellent advice.
I'm glad you cau-ght this before your warranty expired. The possibilities that I can think of -
1. Spillage from replacing oil filter - as mentioned above
2. Valve cover gasket
3. Vacuum pump O ring
4. Oil filter housing seals
5. Oil cooler seals
6. Turbo oil line (not likely)
7. Oil pan gasket (not likely based on the pictures)
Do some searches and you'll find lots of information. The oil filter housing and oil cooler seals seem like the most common leaks.
Best of luck, and keep us posted. Pictures are always appreciated!
Old Nov 9, 2017 | 10:49 AM
Brahmcts's Avatar
Brahmcts
I cleaned the underside and will put oil dye in to figure this out
Old Nov 13, 2017 | 10:36 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
I would guarantee that that leak is the oil filter housing to block seal. We see that leak all the time at the bottom of the housing. This kit will take car of everything you need to fix in that area ever. http://www.detroittuned.com/dt-turbo...ine-super-kit/
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Nov 13, 2017 | 10:40 AM
Brahmcts's Avatar
Brahmcts
Awaiting word from the shop, definitely going to check out that link you sent me.
Cheers!
