Re Programming ABS module
I recently replaced the ABS module and have been trying to re-flash it to my vin number. long story short I'm tired of trying to figure out how to make it work and I'm ready to pay someone to do it for me.
What I'm wondering if anyone has a shop they would recommend that would do this. I live in the Seattle area
Thanks for the help
Thanks for the help
Sorry for the slow response, my wife just had girl over the holidays so its been a little crazy.
So I tried using NCSexpert with a computer that ran windows 10 and for some reason I couldn't get the program to run. could be a computer issue as its a piece of junk.
Installed the program on a windows 7 computer and it worked fine but my Ross-Tech USB to OBDII cord wont install the driver on that computer.
All in All I think I'm just going to call around and see if someone will flash the Module for me
appreciate that help
Congratulations
vagcom wont work with ncsexpert. You need the k+dcan usb-obd cable. The flashing takes 10 minutes if not less.
Also, you have to turn windows defender off otherwise ncs wont work.
Once you open up ncs, turn the ignition on (dont start the car), select the module (DSC or ABS) and just run through the commands one by one. You cam skip yhe commands emding with "lesen". Once done turn the ignition off for 15 seconds then back on. The lights should turn off then.
I will make a video once i do the same on my countryman
