ABS Module
Old Mar 30, 2008 | 01:01 PM
lionhearts's Avatar
lionhearts
ABS Module
I have a 2003 Cooper. I'm suspecting that either the ABS Module or the Speed Sensor is out. ABS is the top suspect. What I'm trying figure out is what model of Ate ABS module is in my Cooper whether it's a Mark 60 or 20 or etc...
Does anyone know?
If curious of the symptoms:
ABS, Brake, Service Engine and Tire Pressure Light all on.
ABS doesn't seem to engage.
Cruise Control won't engage.
There seems to be more body roll on sharp turns.
Old May 16, 2008 | 10:45 AM
Hammar's Avatar
Hammar
ABS Unit
I´m sorry, but you have to change the ABS Unit.
Old May 17, 2008 | 03:00 PM
techtipz's Avatar
techtipz
Do you know what codes are in the ABS module? You could need just a wheel speed sensor. When a speed sensor goes bad (usually the left front with R50/R53) you cruise will not work because it does not know how fast one wheel is spinning.
wildwestrider
11
Jan 29, 2016 05:06 PM
GAT
Oct 4, 2015 07:27 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Sep 25, 2015 12:32 PM
