View Full Version : Stock Problems/Issues
- Hose ID Help
- Shaking
- Gear Shifts Have Gotten Really Stiff, Among Other Symptoms
- Cooper s Cam issues..
- Brown fluid leak from above fuel tank
- Brake error light
- Black soot all over back of car after stage 2?
- Car does not track straight from dead stop
- R56 Coolant reservoir overfull?
- Temperature Warning & No Heat
- DIY (Video) Sea Foaming R56 (N14)
- Best way to remove transmission 2007 mini
- Air Conditioning Problem (Solved)
- Key-remote
- 3 Button Fob Battery Replacement?
- Engine Coolant Temperature Sensor code: P0173B
- what gasket after the head machined
- 2013 R56 S Injectors Seals + Problem in the burning room (mainfold)
- Sporadic Temp Warnings (Red & Yellow) after Thermostat Housing and Reservoir replaced
- N12 Nightmare cylinders 1&4 misfire after head gasket replacement
- Engine Slap when Letting go of the accelerator
- Mini S manual won't go into 3rd gear
- Mini Cooper Clubman Oil down
- No start r56
- 2009 Mini Cooper S limp mode after thermostat replacement
- Clutch not grabbing, like it's stuck in neutral
- Smoke coming from exhaust after idling r56 cooper s
- Smoke from exhaust after idling r56 cooper s
- Welding on MINI
- 09 clubman clutch not grabbing
- Unstable idle at cold start on cold weather
- R56 Lower Alternator Torx Botl removal
- Cold start accelerate take off from a stop.. problem
- Wallnut media Blast the intake
- Fuel injectors
- clutch sensor switch R56 cooper
- 2007 mini not shifting into 4th, 5th or 6th
- 2011 mini copper s Variable Valve Lift programing ?
- R56 No start after clutch replacement redux
- 2011 MCS rear brakes dragging?
- Is my cylinder head toast? Why?
- Generic Live Data values for a stock R56
- 2008 Mini Cooper won’t start, new battery
- Help! Timing chain saga continues!!!
- R56 N16 (2013 normally aspirated) Rough idle on cold start up
- 2010 Clubman S Sunroof--Where do the rear drains exit?
- Think I may have cracked my head / block :(
- automatic
- Limp mode - R57
- Mecaplast valve covers
- Coolant sensor fault woes
- thermostat replacement went wrong
- A huge cloud of white smoke!!!!
- P2b0b p2b07
- Need R56 N18 Help
- Car Resets when breaking traction
- Need help to start R56 :(
- 2012 S (R56) Engine codes - D115 (TPMS) and 2EFE(Electric fan)
- Weird Noise (Need Help)
- R56 garbage OEM front struts
- Bad JBE on 2010 R56S? Random shutdowns- second opinions wanted.
- Problems after Battery Change
- Strange sound from passenger side
- If I could park this car in a volcano I would
- FRM Warranty Replacement
- Smoke and Oil pouring out of engine, oil lamp on...fearing the worst!!
- Weird Sound (like grinding chain)
- Timing Confirmation needed
- So this happened!
- 2009 MC hatch - Transmission sluggish from a stop - flushed fluid
- 2009 MC hatch - BIG problems after timing job!
- Help.... Hood stuck
- N18 timing off after timing chain replacement
- need help finding a burnt bulb??
- Reprogram "DME" after throttle body replacement?
- ECU open loop values
- 2011 Mini cooper s oil and coolant is white
- I’m locked out and frustrated
- Spark Plug change miracles
- 2011 rough idle
- Lurker first post - Crank no Start r56
- [R56 MCS] Air escaping?...
- morning start rough idle
- 2008 Base Mini Cooper R56 trouble codes
- Blue smoke presists
- Deciphering Dealer Speak
- 2008/5 cooper 2BC4 internal fault
- Mini Cooper N18 High Pressure Fuel Pump Warranty Extension
- R56 not starting up
- P0597 engine codes
- 4E84 Solenoid Valve S1
- electrical gremlins
- 2007 Mini Cooper S: Help ID Part
- Need some insight PLEASE HELP
- Is my thermostat/housing leaking? (2009 R56 JCW)
- [2008 R56 MCS] Question about Thermostat Hosuing Wiring...
- P0328 - Knock Sensor code
- R56 2007 Mini Cooper AC compressor not getting power and radiator fan not turning on
- 07 R56 Cylinder 2 misfire
- Rear Brake Caliper
- Lower Tourque (engine mount) arm bolt
- Help. Stuck at Autozone. Trying to pull codes
- Blows humid yet cool air
- coolant leak followed by knock sensor code
- Shudder
- R56 rough starting idle
- R55 diesel glow oligs
- Replacing Ignition Coil...Bosch Performance Ignition Coil?
- Sport Mode not working
- P2188 Consistently thawting my every attempt
- beeping and won't start
- Help! Mini cooper s cranks but no start
- need replacement pcv valve
- A/C blower operating only at low speed
- Valve covers ebay vs oem
- Funny scratching noise coming from inside passenger fuse panel
- mini hell (yet another pcv/valve cover question)
- Low power engine fault
- Chasing low oil pressure light issue
- Guys, Need help with PO128, Please
- R56 misfire
- Scheduled Maintenance - Gen 2/R56.
- I do media blasting in pittsburgh, PA
- key bypass
- Lost FOB
- Air box intake tube
- Battery Choices revisted
- 2007 S, billowing white smoke, burning oil and leaking oil in engine bay.
- exhaust leak
- Misfires
- Mini Makes Chirping Noise upon Startup
- Whistling under acceleration, bad DV?
- Strange whistling under acceleration
- 08 Mini Clubman O2 sensor problem
- Check engine light
- updated tsb list for 2013 r56 LCI n16
- 2010 cooper bad electrical?
- O2 Sensor
- motor is toast
- bent rods/ stuck injectors?
- R57 speed sensor
- Oil Catch Can restrictions
- Acceptable Running Temp range?
- Rough idle/stall after replacing valve cover gasket
- Mini R56 code "2786" Additional mixture adaptation
- CEL and 2EF2 / 289D on R56 Cooper S
- Door Stuck Closed - Not a Stretched Cable
- 5 codes and no start condition- 2013 R57
- MINI won’t start!
- Air pushed out intake?!?!?
- Mini Mania Brake Kit - Good?
- Gremlins! P2188, temp, lights questions
- Misfires after replacing plugs and coils
- Torque spec for hood hinges
- Need diverter screws
- GREMLINS and P2188, Temp, lug nut questions
- Roll Call N18 timing chain replacement miles
- Valve cover bolt hole inserts?
- comical horn sound
- R56 LCI Tails lights electrical schema
- N14 coolant bleeder screw not tightening
- Loss of Power 2013 Mini Cooper S Turbo
- Door won't close sometimes R56
- Radiator Fan Issue
- 2008 R56 Update gone wrong
- Mini R56 code 2885
- Which timing chain tensioner to use
- 2012 MCS Clubmen - Tstat htr always on
- N12 Cooling System Schematic (with flow)
- P0015 B Camshaft Position Timing Over-Retarded? Bank 1
- Hesitation Under Hard Acceleration
- 2009 Cooper Toggle Replacement
- Leaking at Schrader valve on fuel rail at idle
- 2010 R56 Justa Many Issues - No AC, stalling after adding oil
- 2010 R56 Many Issues - No AC, sudden stalling after adding oil
- Code po128 and po597 HELP
- Taillight Problem
- Communication icon missing in 2008 mini cooper
- r56 crankshaft holder tool dimensions or schematic
- Fuel pump not priming before start
- R56 Leaking Sunroof leading to starting problems?
- Yellow Check Engine Light After Thermostat Replacement
- R56 hatch 2009 heater fan replacement
- Parasitic Draw Test (0.00)
- Misfire codes again!!
- Overheating Nightmare!
- Sign indicator
- Mini Code P2885
- HPFP Replaced for free!
- MAP Sensor Location
- "Stuck" rear brake caliper bolt...how to remove?
- car turns over but won't start
- Reverse gate - resistance adjustment?
- 2011 Clubman S intermittent fans
- Engine cranks one but won't start. Urgent!
- start/stop button
- Thermostat replaced error P0118
- Mini Smoking
- Serpentine Belt Squeal
- Mystery MINI Connector
- where is the vvt solonoid part number 917-243 located on a 2009 mini cooper?
- 2010 clubman manual NA. issues.....can't find paired CEL match
- Throwing codes but no noticeable issues?
- Sunroof screen - replace material?
- How to reset Adaptations?
- misfire codes (was: Extended Maintenance Warranty ending soon.)
- 2010 Clubman S DTC P0036 (2A53) - Downstream O2 Sensor - Heater Circuit Act. Code
- Clutch line not pressurizing. HELP!
- Ambient temperature sensor
- 2007 R56 Justa E brake IP
- Help with fuel level sensor.
- Air vent control not working properly
- Manifold pressure too low.
- 2008 Cooper S PCV hose replaced with heater hose—hose collapsing?
- Replaced timing chain guides and now no spark?
- Vanos solenoid
- is he worth fixing? 2010 clubby s
- Replacement key for a mini 2013 clubman S
- High-pitched engine noise and smoke from under the hood
- Help!
- R56 Poor Mileage
- R56 Oil Leak
- Codes P022F, P202F, O1E56
- 2007 MCS Temp Sensor Signal Error
- What is this part?
- 2008 Mini Cooper S Rough Idle (110,000 miles)
- Antenna base weatherstripping
- Changing spark plugs
- 2007 R56 gremlins
- 2013 Mini Cooper S Oil Filter (missing) and coolant leak
- Electrical info/ questions on my hatch
- Electrical info/ questions.
- 2010 cooper base model no spark in all cylinders
- 2007 S start issues...
- Sudden loss of all electronics
- 2009 cooper S issue
- timing chain replacement
- 2011 MCS Auto jerking at standstill but not in sport
- Timing over retard code. Why is it pulling timing?
- Stuttering acceleration
- Mini Relay Clicking
- Throttle housing removal/reinstall requires coding?
- P3112 - Cylinder 4 High Pressure Injector Low Side Circuit Open
- 2008 cooper s engine reduced power light
- New Member, MINI having issues (CEL, loss of power, etc!)
- O2 sensor operation
- Torque spec for upper timing chain guide and valve cover?
- Turbo / Vacuum / Wastegate / Pressure Converter issues
