R56 Lower Alternator Torx Botl removal
Old Oct 4, 2018 | 05:42 PM
400mphpc's Avatar
400mphpc
Looking for some advice. In the middle of replacing the alternator on my 09 MCS. The bottom E10 Torx bolt, is in a position where you can’t get a socket on it because of the hard AC line. I have tried a thin deep socket and short one with a thin extension, but no luck. Any suggestions on how to remove this PITA ? ( just realized I can’t spell “bolt”) .....
Thanks,
Chris
Old Oct 4, 2018 | 08:15 PM
MiniToBe's Avatar
MiniToBe
You could either take down the ac compressor or bend the line just a hair to pass the socket
Old Oct 4, 2018 | 09:58 PM
Yupetc's Avatar
Yupetc
Look over to the crankshaft pulley side, there is a bracket holding the ac line. Use 10 mm socket to remove the bracket bolt then back on the alternator side you can push that line down a tad bit as you try to remove the Torx bolt. Good luck buddy.
Old Oct 6, 2018 | 12:43 PM
400mphpc's Avatar
400mphpc
I used your advise and just pushed down on the tube gently until I got enough room for the thin deepwell socket. Worked like a charm. Thanks again, I’m back on the road and all is well.
Old Oct 8, 2018 | 06:21 AM
MiniToBe's Avatar
MiniToBe
Nothing better than a clean engine bay
Old Nov 10, 2018 | 07:29 PM
N12's Avatar
N12
After removing the top 2 bolts and with an E10 socket, I removed the T20 screw and support bracket that held the flexible AC fill hose to give myself more room. The bottom E10 bolt came out easily with an 8mm (or 5/16) offset box wrench from my Harbor Freight (#32042) set. Leave the lower bolt in the alternator until you've pried it free of the engine block.
wsalopek
Sep 24, 2014 07:14 AM
jmoser
Oct 21, 2011 09:50 PM
owl
Apr 8, 2009 05:06 PM
ED955S
Electrical
Jul 5, 2007 12:08 PM
Bobbyn
Oct 21, 2006 12:17 PM
