Help! Mini cooper s cranks but no start
Old Sep 2, 2018 | 08:38 PM
Phillz's Avatar
Phillz
So i have a 2007 mini cooper s turbo. It cranks but won't start. Checked the plugs/coils and they're not sparking. Replaced to cam and crank position sensor, and the coils and it made no difference. Spark plugs are a bit black but other than that they seem fine. What else can it be? Tried using some starter fluid and got it to try to start (engine sounded like it was gonna start for half a second) but after that nothing. I'm confused as to what else it can be. Any helps/thoughts?
Old Sep 2, 2018 | 10:30 PM
oldbrokenwind's Avatar
oldbrokenwind
This is the symptom of a bad HPFP. An '07 probably had it replaced already, but also probably long ago and the replacement is now failing --- they're only good for 50K miles or so.
Old Sep 3, 2018 | 03:56 AM
MiniToBe's Avatar
MiniToBe
Read the codes first.
Old Sep 3, 2018 | 07:28 AM
Phillz's Avatar
Phillz
codes are showing a random misfire
Old Sep 3, 2018 | 07:30 AM
Phillz's Avatar
Phillz
a bad hpfp can cause no spark? After cranking the engine i pulled out the plugs and they look wet and smell like gasoline, so i know it's getting fuel.
Old Sep 3, 2018 | 09:20 AM
MiniToBe's Avatar
MiniToBe
Check the spark plugs coil packs ground wires. It is the ligh green screw with the valve cover bolts.
Also, you could take the valve cover out to inspect the chain condition and timing.
Old Sep 3, 2018 | 09:58 AM
Phillz's Avatar
Phillz
Already have done that. Haven't checked it in depth, but the chain itself looks fine, no metal shavings anywhere. How can i tell if the timing is off? Any noises to listen for?
Old Sep 3, 2018 | 10:27 AM
MiniToBe's Avatar
MiniToBe
With the cover off, rotate the engine clockwise and look for the writing on both cams to face up. Then place two long straws in cyl 1 and 2. They have to be levelled. Also use an 1.5" screw to at least make sure you can lock the crankshaft.
the other thing is probably grounding as i mentioned before. If that wire isn't making a good contact, the car wont start.
Old Sep 4, 2018 | 08:58 PM
SkyWriter
Just for grins, check the battery. I have heard that while it may have enough energy to crank, the software sees a value that is too low and will not allow spark. If you have already tried that, ignore the suggestion. Good luck.
Old Mar 13, 2021 | 07:50 AM
Patmac8654321's Avatar
Patmac8654321
.....meaning it needs to be registered so the battery can be updated thru the computer to give the battery correct charging info?? This is what I understand. I havent done it yet, but when i do, ill check back in.
Old Dec 23, 2021 | 09:20 AM
dhart2074's Avatar
dhart2074
Any updates on this? Did you fix the no-start condition? I have the same issue right now...
Old Aug 16, 2022 | 05:49 PM
ilcapo's Avatar
ilcapo
Same issue here…..
Checked all the items above are there any fuses/relay that could cause us
08minicooper
Dec 29, 2022 10:24 AM
Roberto Gonzales
Apr 22, 2019 03:11 AM
RussMorris
May 31, 2016 07:11 AM
Mini Cooper r56 Pr
Jun 6, 2015 05:27 AM
Mini SUV
Dec 3, 2012 05:07 AM
