PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36
  1. Screw down the front defroster!
  2. possible valve cover oil leak?
  3. Damaged roof, sun roof and spoiler
  4. Is a Software Update available?
  5. DIY Fuel Injector Replacement or Cleaning? (MCS/JCW)
  6. Check Control Message - Check OK
  7. how to kill a warning lamp??
  8. Dead Battery
  9. Idling problems
  10. Duplicating the cold-start chatter
  11. And another Clutch bites the dust....
  12. Pop sound after engine shut off - 2011 MCS
  13. Stereo wont turn on
  14. 07 Cooper S gets LOUDER the more I drive it...cold start or no?
  15. Engine Tapping noise
  16. Burble is nice, but dang this thing has gas...
  17. What is this?...
  18. Seat backrest shakes!!
  19. Cold Start - Low Oil - High Pressure - Dip Stick Pops Out - Timing Chain Rattle
  20. Temporary rattle and power loss under hard acceleration
  21. backfire/near stall when starting 2011 MCS
  22. Removing door panel = need to reprogram car's computer?
  23. Need a new radiator and radiator fan?
  24. 2008 Cooper Error Codes
  25. Electric Motor Noise after Shutdown
  26. Suddenly Noisy, Sounds Like a Diesel
  27. Door handles seem harder to open
  28. Any unresolved issues on 2011 MCS
  29. P0128 OBD CODE and 2F07 MINI Code
  30. Brake failure
  31. Cel B173b
  32. Blown turbo??
  33. N18 – Cold Start Exhaust Rattle Noise (Turbo Wastegate)
  34. Mini Death Rattle - Car at Dealer - Advise Please!
  35. broken shifter knob cap (manual)
  36. Burning Oil - may not pass smog
  37. Yellow Engine CEL & odd codes
  38. MPG Computer read out going crazy
  39. 2011 MCS sunroof is creaking.
  40. OEM Windshield defective (twice)
  41. Sticking Clutch Pedal?
  42. Blown clutch at a track day
  43. jump start by an idiot
  44. HELP!!! INPUT BEARING OR 25k Maintenance Plan?
  45. P0300 Random/Multiple Misfires
  46. HELP! Added Engine Restorer to car and now have Rough Idle
  47. Disturbing Sound When First Driving
  48. New MINI won't start
  49. Recuring thermostat gasket leak
  50. 2011 MCS Cold Start Noise
  51. Code PO 503
  52. Fix for scratch on a-pillar? roof?
  53. Timing chain issues
  54. Troulbleshooting- Thermostat or Water Pump
  55. After 440 miles of brand new Mini it is time to join YELLOW engine light club :(
  56. OEM Dunlop runflat tire wear
  57. Clutch squeak and soft clutch
  58. Have these problems?
  59. Dentist Drill noise at 2500RPM+
  60. Sputtering on start-up
  61. Auto up windows stopped...help
  62. Petrol/Gas issues
  63. "Clunk " coming from engine compartment.
  64. 2011 MCS Vibration
  65. Car stalls on start-up
  66. gasoline smell
  67. Hood Insulation from Mini Mania
  68. Rear brake service due in 900 miles
  69. BMW Induction cleaner
  70. Now it's the turbo...
  71. cold rattle problem
  72. Need Contact Info/emails For Mini Usa Corporate/legal
  73. Door is not flush to the body.
  74. Strange hesitation and tick noise today
  75. Common Problems
  76. Timing Chain issue
  77. hpfp issue?
  78. Brake Fluid service light
  79. Timing Chain/Electronics
  80. Weird electrical issue perhaps?
  81. I think I had the "Death Rattle" - now my Mini S is dead. :(
  82. 2011 MCSa / 300 miles / Oil around filler cap
  83. Seat Stiching
  84. sunroof thing opens on its own?
  85. Help! Check Engine Light
  86. steering wheel turning by itself
  87. Big trouble in little Mini
  88. Alarmed after purchase of CPO 2007mcs
  89. boot won't open!
  90. '07 Mini Cooper S won't start!
  91. R56 Issue
  92. Multiple issues days after purchase
  93. headlight adjustment
  94. New 2011 MCS Concern
  95. single knock new turbo
  96. Window squeal / squeak!!
  97. Oil smell
  98. R56'ers gather 'round . . . '11 MCS engine knock story
  99. Failed Piston - Break it in again?
  100. Car says passenger door Ajar, but it is Aclosed
  101. Amazing mess 2010mcs head gasket blown day after service: Advice?
  102. Clutch pedal arm hitting hard line from master cylinder making a click
  103. What does symbol :Yellow lightbulb w/exclamation point" mean?
  104. Squeaky Clutch Paddle Issue
  105. Cracked Xenon headlights
  106. 2011 washer nozzle weeping...
  107. Timing Chain Replacement and Frustration
  108. Buzzing/humming Sound While Driving (Justa)
  109. Possible climate/vent issue
  110. Dipstick will not go in
  111. In-tank fuel pump
  112. Yay, Clouds of White Smoke!
  113. CHeck Engine Light on 2011 w/ Black Smoke Ughh
  114. French Facebook Group: "Prince" (R56) Engine Petition
  115. Question on Remanufactured Engines
  116. *Help* My 2011 MCS "Sings" at 5k RPMS..
  117. Sound of the clutch engaging
  118. Fast blinkers
  119. Cold start rattle as 64k, Options?
  120. Check engine light, before ignition
  121. 2007 S Cel Issues
  122. timing chain tension bolt issue?
  123. Just got the Timing Chain Replaced - Yay Mini Nashville
  124. It pays to visit your dealer
  125. Gen 2 Technical Service Bulletins (TSB) Database
  126. Oil Starvation says the dealer! HELP.
  127. Just a Mini engine light on 2 codes P0113, P0342 any ideas?
  128. Waterpump issue
  129. Dead Pedal cracked
  130. Metal shavings in the intake...fun...
  131. blown engine
  132. Help! 48K...Decision Time
  133. Is this normal
  134. Noobie in need of help - corolla for MCS - reliability issues
  135. Melted hood scoop after two years - is there a TSB about this?
  136. AC compresser filled with Rocks??
  137. Rattle/Tinning Noise in engine (hot)
  138. Stiff Power Steering???
  139. AM Radio Lost Signal
  140. Driving home and this happens....
  141. Odd rattle or cackle coming from the front
  142. warning light
  143. Sunroof problems
  144. Missed a shift and hit about 6500 rpm in my JCW 09 mini!! HELP
  145. Oil leak help
  146. Tensioner 11-31-7-607-551
  147. water pump and oil filter canister replaced
  148. Our MINI just puked all it's vital brown fluid on the ground...
  149. Clunk in boot area.
  150. What can cause squeaky noise?
  151. 1.6 Justa Cooper?
  152. Removing fuel line from HPFP
  153. Add me to the List of my Wife called me with and oil Leak
  154. Mirrors folding in when it rains
  155. No start problems
  156. Mini Warranty
  157. 09 Justa Mini 6 speed Intermittent No Start
  158. Timing chain failure
  159. Unhappy soon to be ex-owner 2008 MCS
  160. Removing Head
  161. Door handles stiff (comfort access if matters)
  162. Chirping serpentine belt???
  163. Clutch replacement by independent shop?
  164. 2011 MSCa thump/clunk in Sport Mode
  165. What does the Brake light and vehicle check icon mean
  166. Clutch survey. How many miles on your Mini/other clutch.
  167. Oil on plastic skidplate????
  168. SOOO Frustrated with Mini's Promotional Programs
  169. Another victim of the Timing Chain Tensioner
  170. Turbocharger failure - Compressor nut
  171. Fault Codes 2DCC, 2880 and 2D52 ???
  172. Windows going down, 1 blink instead of 3X
  173. Long story from an Armed Service Member
  174. Slipping out of third gear
  175. Rear washer with wipers parked
  176. Post-accident starting problems in 07 MCS hatchback
  177. '07 MCS auto has a cricket... or something.
  178. Clutch Groan: How to talk with dealer?
  179. Locking crank
  180. Rear cupping and clacking noise
  181. Sell or Not to Sell over Turbo issues?
  182. Cam timing
  183. DTC, brake, seatbelt & Airbag lights all on, help. :(
  184. So my wife calls me about an oil leak....
  185. Level Sensor (I think)
  186. 2007 S hatch door won't unlock
  187. vacume pump engine failure/servo motor Help!!
  188. Another "Wierd Battery Problem"??
  189. Idle issues - hunting after startup.
  190. Question about dealer oil change
  191. What did I kill?
  192. Code P2418, P2400. Where is canister?
  193. Oil leak
  194. IHKA Faceplate
  195. timing tension bolt and...
  196. Check engine light
  197. leaking resonator?? non-s clubman
  198. Blinking lights and the Sunroof
  199. Whining Noise coming from valve cover!!
  200. Red "Oil Can"
  201. R56 hard start, rough cold idle
  202. Auto tranny won't engage
  203. ABS Unit Faulty Just After Warranty Expired
  204. Water Pump Issues and other goodies
  205. My car was repaired and now smells like @#!%
  206. 1st Dealer 15K Mile Service Due - Questions
  207. 2011 MCS in the shop, question about loaner car
  208. Death rattle, carbon buildup, and tensioner question
  209. Minor oil leak - pictures - where is it coming from?
  210. 2010 Convertible Bluetooth Issue
  211. 2011 Vibration ????
  212. Key fob opening locks but not switching on ignition
  213. Tire Pressure Monitor TPM not Resetting
  214. carbon blaster
  215. Increased Battery Discharge - multiple times in two weeks
  216. Noisy Turnover. Loss of Power. HPFP?
  217. Great car - worst armrest ever
  218. Coolant leak, engine damaged?
  219. Hi There! My 1st post and its (potentially) not good.
  220. warranty question
  221. cylinder head removal HELP!!!
  222. Turbo failure on my 07 MCS
  223. Can I prevent valve build up?
  224. windshield creaking
  225. Howto retrieve Check Control messages
  226. 2011 Satellite Radio Stuck in Aquiring
  227. Fuel filler cap wind noise?
  228. rough idol
  229. Question about cold start engine noise
  230. Please help me with my JCW
  231. 15 days old, 5 days broke
  232. Water Pump Replacement at 18K Miles???
  233. New Glove Box New tail light...Feels like new
  234. Help me diagnose this clutch/trans sound
  235. Window won't go up
  236. Help me diagnose - belt slapping?
  237. Power window and boot door question
  238. CEL Code P1497 & engine stuttering at idle
  239. 5000 miles- Noisy engine, and the other morning a little rattle at idle.
  240. After dealer visit, turn signal behaves differently & car feels less torquey
  241. powerfold mirror.....issue
  242. having to reset time of day on 07 mcs weekly
  243. Death rattle, fuel pump, carbon problems, Talked to Dealer.
  244. Oil Filter Housing Gasket Leak
  245. Missing Splash tray/under tray / guard?
  246. 2008 Clubman S with big problems from cold start noise
  247. Summary of Problems in 3 Years.
  248. Really displeasing noise from the engine
  249. HELP I need a new MAF sensor!!!!!!!!!
  250. Poor Idle - Carbon Cleaning Connection?
