PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36
  1. SES & Traction lights
  2. Clubman S oil leak @ 1800 miles!
  3. Window problem weird message
  4. TPS warning / Seat belt chime problem
  5. Don't know what this is called but it's plastic and it's cracked.
  6. Factory Roof Rack Disintegrates!
  7. Cylinder Head Problem
  8. new mini
  9. Strange Problem couldn't find related thread
  10. Automatic Trans Problems?
  11. Bonnet release broken - any DIY advice?
  12. Check engine light -> New catalytic converter
  13. Popping
  14. Cold Start Clatter/Oil Change!
  15. Normal to have some engine chatter?
  16. Gurgling coming from the gas tank while idle
  17. Cracked Windshield
  18. clackkk, when i shift
  19. Spurious Events
  20. R56 Spontaneous Sunroof Explosion
  21. Error code : CC-ID 000 ...??
  22. Front Suspension Squeak
  23. Grinding/pulsation from power steering...
  24. AIR FILTER QUESTION
  25. My MINI died on me
  26. Super Stiff shifter 3rd gear and higher...
  27. Seat Memory Problem
  28. feels like my engine died for an instance..
  29. Knocking/Pinging noise from engine?
  30. Vibration Rattle Is Driving Me Nuts...
  31. Key fob reset?
  32. Floormats From Hell - Keep Moving Around???
  33. High pitch whine
  34. Leatherette Seat Is Kinked/Puckered on Airbag Side...
  35. "Popped out" hood scoop...
  36. Keyless Remote Replacement$$$
  37. Frozen Radio?? Anyone?
  38. Airbox hits firewall on spirited driving: Loud noise
  39. Flat towd
  40. squeaking clutch when engine is on
  41. R56 (2007) Clacking noise
  42. Crevier BMW put 1 quart extra oil in my MINI
  43. Car is really sick...not in a good way.
  44. Very faint beeping
  45. How do u take off the HORN on the upgraded alarm on an 08
  46. no oil?
  47. Engine idle RPM fluctuation
  48. flickering light while accelerating
  49. 07 MCS auto would not start in 44 deg. F
  50. car trouble
  51. should I use timeslips as proof motor is hurting
  52. Exchange or Buy back in CA?
  53. Anti Rust Spray/Wax from under the hood
  54. My 07 MCS Died, No Power At All to Even Unlock the Door
  55. 1/4 mile trouble any thoughts
  56. Auto A/C - Changing Temperature In Increments of 1?
  57. Gas Gauge Problem!!!!!
  58. P0073 Error code?
  59. New transmission at 13,500 miles!!!!
  60. Wheel Spin or Clutch Slipping?
  61. I am beginning to hate my MINI: Crazy window going down
  62. The MINI Dings, Dings, Dings ... and stops for nothing!
  63. Anyone MCS owners in southern states experienced the cold start rattle?
  64. Heat In Driver's Footwell?
  65. The I've lost confidence in my R56S build quality looking to replace thread !
  66. Rear Fog Warning Icon
  67. Broken Hood Pull
  68. Weird "Damage" Issue
  69. Cold Start Issues Database
  70. Clutch noise upon release
  71. Oil Consumption
  72. Soft Rear Bumper
  73. Had a Clunking Sound...
  74. Ok, So Are My Brakes Shot or Not?
  75. Back Seat Rattle
  76. Trunk Light Doesn't Go Off
  77. Broken Key Fob
  78. LTCVEE
  79. Odd Warning on OBC
  80. Airbag light?
  81. Brake pedal noise
  82. Brake Dust
  83. Foglight cover?
  84. Front De-fog Problems with Auto AC
  85. Engine Whistle at idle??
  86. Driver Side Wind Noise & Vent Noise/Whistle
  87. Clutch Release noise
  88. Boot Opening by Itself
  89. Windshield Wiper Issues
  90. Passenger Air Bag Disabled
  91. MINI Service Shop
  92. 1-2 shift scraping noise - linkage?
  93. Car Wouldn't Start
  94. Auto Transmission
  95. Black Exhaust (soot or oil) Tips
  96. Any Problems With Tranny in 2007 MINI S?
  97. I think my hood scoop is melting...
  98. Lemon Law: Buyback vs. Replacement Vehicle
  99. Fuel Gauge Out of Touch?
  100. Dumb Door Not Unlocking
  101. Door Won't Close
  102. Paint Issue Around Fog Lights
  103. Question About Breaking in R56 and Turbo Buzz
  104. Interior whistle from heater/AC fan
  105. Question About Lemoning a MINI
  106. Possessed MINI
  107. Key Fob Waterproof?
  108. Seat Heater Wires?
  109. what fell from my car?
  110. R56: A Small Bump on My Front Tire!
  111. Key Fob Locking System Gremlins
  112. Haven't been to the dealer for awhile
  113. steering shaft and rust
  114. tire pressure monitor question
  115. Regular maintenance intervals.. some questions
  116. Another CEL thread...at only 250 miles :(
  117. service manual...
  118. gearbox loose?? :(
  119. Moodlight Dead
  120. Anyone have this issue witht heir OBC?
  121. iPod Nano not updating Recently Played with factory adapter
  122. Auto Tranny Bucking between 15-20 mph...
  123. Rattles Thread
  124. Two Weeks In Service, For Engine Misfire
  125. Steering Wheel Off Centre
  126. Oil Smoke at Start Up
  127. 2007 Headlights
  128. Automatic Headlight Sensors Are Not Sensing
  129. Smoking Clutch
  130. Occasional Rattle Under Acceleration
  131. Do I have DSC??
  132. Software Update
  133. Whine at High Speed, Normal?
  134. Wheel arches......Broken?
  135. Dead MINI
  136. Bad Ball Joint at 1400 miles?
  137. Tire Noise
  138. windshield washers don't work!
  139. 1st Flywheel, Now Clutch and Flywheel...
  140. BROKEN Navigation Software Fix!!
  141. Smudged glass inside tach?
  142. Dome Light Question
  143. Maintenance intervals ... but SERIOUSLY
  144. What should I do about this code?
  145. Brake light warning while driving
  146. Slightly bend wheel
  147. annoying trips to the dealer
  148. Yellow engine light - full engine power no longer available
  149. To Buy or Not to Buy
  150. moisture in headlight
  151. Anyone seen the ECU limit boost?
  152. Seeking Input on Transmision/Engine Problems
  153. Warning -- mirror caps fall off!
  154. Loose Suspension Bolt
  155. Head Gasket Blown at 5k miles??
  156. Thumping Noise After Shutdown
  157. Armrest Fix?
  158. E-brake hitting the arm rest problem
  159. Cup holder "From Hell"
  160. Missing Tranny Bolt?
  161. Error Codes
  162. tailight problems (plastic chipping)
  163. Jammed sunroof !! NOT good
  164. The 2007 "Grinding" Noise or "Rotating" Noise Upon Deceleration Thread
  165. Passenger rear floor SOAKING WET
  166. Problem With Paint on Hood
  167. Dealer screw up on wheels
  168. Can you patch a run flat?
  169. Front Strut Dust Boots
  170. Dash Creaking from Heat
  171. Check Engine Light & Code Display on OBC
  172. Cracked windsheld
  173. Dash rattle, Color line Bubble, Oil change at 20k?, brake noise, bad service Mtn View
  174. Windshield Delaminating?
  175. Crazy Horn Honking
  176. Thermostat Icon
  177. Loose Springs in Front Seat
  178. AC Condensation Leaking Into Passenger Footwell
  179. Cold Weather Package
  180. 07 MC Engine Replacement @ 5k miles
  181. R56 Engine Temp warning when car is not hot?
  182. Bluetooth Noise
  183. Knocking Sound From Engine Compartment When in Neutral
  184. Rattle help
  185. DSC and Brake Light
  186. DSC and brake light on???
  187. Bonnet Is Askew!
  188. Glitchy '07
  189. Another Dash Rattle Fix
  190. MINI won't go in the cold :(
  191. TPM Activated After Snow Fall
  192. Reasonably Priced Oil Filters
  193. Settings From Each Key Fob
  194. Xenon Failure
  195. Click noise When I Use Headlamp Washers
  196. Accelerating After Throttle Lift-off
  197. Water Swooshing Around In Roof?
  198. Hesitation When Floored
  199. I Have a Problem. GRI,GRI, Noise
  200. Tire Pressure Warning Indicator
  201. Cold start chatter
  202. Engine Knock During Cold Start
  203. Interior Mirror
  204. Paint Imperfection or Crease on Driver's Door
  205. Is Something Wrong With My Lock?
  206. Near Redline Shift Grind - Any Harm?
  207. MINI Shakes When Idle
  208. Engine Rattle After Sitting
  209. Tire pressure
  210. Help Dash Clicks 95% Of The Time
  211. P1515 Electric Current Circuit Malfunction
  212. Problems that developed last night Electrical
  213. Very Weak Glass (Doors)
  214. Walking Away From a Lease
  215. Grinding gears
  216. Rust After Washes
  217. Engine Start Up Odd
  218. New Water Pump
  219. Loose Boot/Have to Slam to Close Hatch
  220. Rear Main Seal Failure
  221. Very Stiff Brake Pedal After 1 Week Vacation
  222. My MINI Refuses to Motor! Engine Won't Start
  223. Sudden Power Loss Like No Turbo
  224. Fuse Trim Removal ???
  225. Possible Automatic Window/Sunroof Opening
  226. The Navigation System does NOT work!!!
  227. Dealer Trashed Her Car
  228. Turning DSC Off?
  229. OEM shift knob is a piece of...
  230. Is This Normal?
  231. Dismantling 07 Sport Seat
  232. Turbo Inlet Hose Will Not Stay On
  233. Please Rescue Me From "Babboon Butt"
  234. Cracked Fog Lights
  235. Umm... Should I Be Worried?
  236. Hot Hood / Bonnet
  237. Tailgate warning light - gate close??
  238. A Warning Tone... Then, Nothing.
  239. Noise/vibration @ 60+mph and strong crosswinds
  240. Clutch Goes To Floor and Does Not Come Back Up!
  241. Reading the Dipstick!!!
  242. Does anyone have Ants
  243. The Honeymoon's Over
  244. Rattle in rear sway bar link R56
  245. R56 S Software Issues
  246. How to Remove Air From Cooling System?
  247. "possible transmission or selector knob error?"
  248. Suggestions for body repairs?
  249. Water Leaks
  250. Glazed Clutch
