View Full Version : Stock Problems/Issues
- Engine Oil Leak
- Replaced coolant sensor. Now ac is not cold
- Has the part price for a HPFP jumped since 2yrs ago???
- AC blend door actuator?
- P0117/Limp Mode after Thermostat Replacement
- Questions RE VANOS / timing fault
- P0014
- Lower engine mount question.
- No Flow Radiator / Thermostat 2012 R56
- Timing chain replacement done, won't start now
- No Start Condition - Running out of options...
- No start P0974 after timing chain replacement and oil change.
- Rear Sunroof Panel right side stuck
- Limp mode 2009 MCS
- P0014, High Revving, Low Highway Speed
- Key Fob 'Lost' my story & Replacement
- Problems starting up
- Help diagnosed engine bay whistle 11' R56S Video included
- Need help with codes
- Torque settings, needed
- HPFP Failure Again or Something Else?
- Some Concerning Fault Codes
- 2009 bad cold idle
- Trans Fault - 4e84
- Newbie questions: timing chain and thermostat
- new potential MINI owner
- Noise at low Rpm
- Can I fix the valve cover pcv? air sound from valve cover and P1497 fault code
- Installing intake manifold need help
- Mini Cooper Clubman 2009 will not start
- Thermostat stupidity
- MAF problems or TPS?
- What is this going to cost?
- 2008 mini s misfire and occasionally hard start
- Help with code 2885 boost deviation
- O2 Sensor not fluctuating?
- R56 coolant ate thermostat housing...
- Lots of codes
- Tach error codes after rebuild and starter noise
- P0442 - Evap Line on top of gas tank - R56 Mk2
- Check Engine Light help
- AC compressor
- Sputtering when accelerating
- R56 Headlights??
- How to reset a Mini Cooper exterior light warning
- Yep, HPFP questions!
- Idle issue when waarm
- Walnut Blasting!
- R56 Justa engine cost
- Timing chain tensinioner rail bolt
- Full Engine power no longer available - Mini Cooper NON-S (07')
- R56s - P0507, P0171, loose intake tubes
- Cyl 3 misfire on cold start, disappears when engine warms.
- R56 2011 noise maker line has some oil
- Code P0974 Aisin 6 Speed
- Blue smoke after long drive.
- Sound diagnosing, any ideas?
- Mini Cooper Clutch
- Oil after intercooler!
- R56 N12 Engine 2008 Mini Cooper Oil Pan Gasket
- Turbo not working?
- Footwell module 2011 clubman
- New to MINI
- R56 timing chain
- Proper transmission service
- Non turbo clutch options
- False overheating indication
- Seafoam Fogger Attachment Device for N14 Engine
- Missfire / Rough Start
- Any experience or tips on cleaning throttle body and manifold
- Does this sound like hub bearing noise?
- 2010 MINI COOPER trouble with third gear
- R56 Auto Trans shifting issues
- 1/2 engine light on cluster...
- Any idea what this piece broke off of?
- How did I solve rough idle and stalling of my R56 N14 MCS
- Weird Blower Issue
- High Altitude Mini Issues
- Coolant leak, not from pump or thermostat
- Sunroof liner smell
- Help diagnosing oil leak
- Need Advice !!! Oil light after oil change
- Injection Pump
- 2011 MCS mystery - Oil and Coolant Mixing
- Bought a 2011 JCW with problems! Need a little advice
- what do you think about this engine noise please ?
- 2013 r56s leak near front center
- Installed OCC, it's dry all the time
- Indicator Switch
- 2008 Mini Cooper misfiring on descent
- Help a girl out!
- Problems securing coolant sensor
- Steering rack replacement?
- NEED HELP! 2007 Mini will not start!
- Orange key light (no strikethrough) and car won't start
- Could it be a fuel pump fauilre?
- R56 Starter Grinding
- R56 Mini Justa Poor Throttle Response and Oil Burning
- PO597/$07E Code
- R57 random misfire
- Any idea what's wrong?
- Engine Malfunction
- is my car covered under the timing chain recall
- R56 N14 Stage 0 Tune
- Mini Cooper S (R56) 09 won't start, just cranks
- electrical haywire
- Low oil pressure after new vacuum pump install????
- R56s oil psi light
- Leaking antifreeze
- Vacuum pump failure and engine damage.
- N12 automatic justa timing chain replacement
- R56 n12 1.6
- Weird Error Code
- Crankshaft pulley hub after timing chain
- Clubman 2009, no crank - (not the clutch switch)
- R56S Screeching after engine stop
- Need to replace my sunroof track/frame
- Before and after walnut intake valve cleaning on N18 with 89000 miles
- Vacuum pump wear
- Mini 09 R56 won't turn over
- 2011 mini cooper no spark
- 2007 R56 rear wheel bearing
- Fuel pump? Auxiliary water pump?
- Coolant tank fills to top (and more) then goes back down
- Timing chain replacement gone wrong
- Walnut blasting time!
- Engine Warning Light orange - Safe Mode - Rough Engine
- Mini Cooper S 2008 R56 too many errors
- Trouble Code p115D Plus random misfires
- 2010 mini cooper (non s) coolant problem
- Possible HPFP failure
- P0302 Misfire - Now engine won't start after compression test
- Horrid Engine Knocking
- MINI Cooper '08 Vacuum Pump seals
- How to check engine compression on R56 Cooper
- R56 - help me identify this sound (contains video)
- confusing fuel problem !
- PCV Hose Leak? P2188
- Help.. Charged battery and car wont start now
- intercooler filled with coolant....
- Acceleration issues/Chugging
- Warm air blows, even with the temp dial turned all the way down
- Valve crankcase membrane/ventilation replacement. How?
- R55 Exhaust Flex-Joint
- 2012 mini Cooper s cranks but no start
- lean conditions
- OEM Flashing center brake light?
- O2 sensor fault P0141 still
- essitation , knock around 2000-3000rpm vs OCC
- 2010 low boost loud exhaust noise help
- For the love of God, please help! No spark on cylinders 1 & 4
- HPFP Again Again?
- Ebay Replacement Turbochargers for R56? Good idea, or terrible idea?
- P2885 Boost Pressure
- Vacuum Pump Carnage
- Will 2012 Clubman A/C Controls work in a 2008 Clubman?
- Wastegate Issue?
- 07 MCS ran hot now hard cold start & rough idle
- Hard Cold Starts ... Think my HPFP is going out??
- How to confirm R56 timing chain and tensioner were replaced?
- R56 Stalled, Now Won't turn over
- Spending one quart of oil per month
- Need Opinions about codes P0012 P1497 valve job
- Turbo flutter = failed BOV/Diverter?
- Cyl head rebuild and much better idle...
- Mini clubman F54 mirror cap removal
- Lights?!?!?!
- Windows Up Down concurrently question.
- Help in identifying these bad sounds
- What to look for before buying '09 JCW
- 2008 clubman s timing nightmare
- Rear Stabilizer Bar bushing question
- Electronic Parking Brake Malfunction
- Reservoir hose rubbing
- Clicking While Accelerating....
- Random loss of power at STOP light.
- Removing the blocks at rear license plate
- Timing Chain Tensioner - Question
- Severe Knocking noise coming from engine
- Fixing brake light
- Filter housing HELP!
- Airbag Warning Light
- Changing spark plugs on N18 engine?
- Just Another Oil Consumption Problem (HELP) n14 r55
- Coolant Leak - transaxle oil cooler?
- Thermostat housing OEM vs aftermarket
- Clutch Blew in my Clubbie S
- PCV and Oil Catch Can recommendations
- 2010 MCS "normal" oil burn?
- Shift feel '11 R55 S manual 23k miles
- Foam Energy Absorber
- P0301 code 2007 mini cooper S. R56
- Advice
- Valve question?
- 2011 R56 Cooper S clutch issues
- VANOS ??? on 2010 R56 Mini Cooper Base???
- Timing chain guide rail replacement question
- A/T stuck in neutral help please
- Hole in crankcase.......
- Flared shifts 6 Speed auto
- charged 2007 coupe now no power
- bi xenon issues
- 2013 r56 vanos locations.
- Oil Stain Help
- Keeps on running
- 2009 R56s Cylinder Misfire and low Compression
- 2009 weird stumble, no codes
- R56 Hazard Lights not working
- New software changed rev-counter display after airbag controller replaced!?
- Spark Plug Socket
- We Need a New Motor?!
- headlights have washers but no hoses going to them
- Do new headlight bulbs really make a difference (halogen)?
- Bad Coils, Carbon Build Up and More - 2009 Cooper S
- PCV Valve
- Unknown Vacuum Port
- Identify a Part
- Help! Bad stuttering/rough idle/reduced engine power
- Trading in With CEL?
- What's the fuction of this hose?
- Oil Pressure Woes
- Heating A/C errors
- P0302 Error Code - 2012 Countryman S ALL 4
- GGGGrrrr......HPFP
- R56 Overheated & Shut Down... Help Me Make A Tough Decision
- Code 002C01
- Driver's door stuck closed, and it's not frozen
- Cryo Treat the Timing Chain?
- Thermostat leak vs water pump leak. Possibly covered by lawsuit settlement?
- Rear Bumper is Flimsy
- Another cooling fan question
- How can I tell?
- 2C01 and 2BDD faults, errors, any help on that?
- Vacuum Issue
- Oil Seepage
- R55 No Start
- Bad Coolent leak
- Possible coolant leak
- Help adjusting height of driver's window
- Diagnostic Help - Check Engine Light - P0128 - Thermostat Replaced
- the faulty timing chain tensioner
- Problem opening the glass door does not come down
- Help diagnos my HID problem
- Turning Noise/Squeaking
- Bulb warning problem
- valve cover smoke test
