Low oil pressure after new vacuum pump install????
2008 Mini Cooper S---After installing a new vacuum pump my low pressure oil light comes on and off on and off when the car warms up and the rpm sets in at idle. Goes away above 1100 rpm The oil and filter were changed 5 days earlier before the vacuum pump change and oil is full. At that time I had no problems. Thought it might be the low pressure sensor so I bought and installed a new one, which didn't stop it. I might put the old vacuum pump back on to see if the light stays off. First I'll check the oil feed hole on the new vacuum pump to see if there is any blockage and if the light stays off . Any suggestions? Light stays off above 900rpm
The new vacuum pump is working like it should and I had no problems with oil pressure until I installed it.
