View Full Version : Stock Problems/Issues
- Another remote/key question.
- Sunroof / water leak problems
- How to fix the sunroof screen?
- Stripped Sway Bar threads for Sway Bar Bushing
- Need some opinions, engine trouble
- New/Reman n14 Engine
- DSC & hill failure + sudden steering wheel alignment issue
- wet floor R50, 2003
- ABS Randomly Goes Off
- Cold start question
- speedo question? - no not the bathing suit!
- Recall
- 2008 MCS R56 - Trunk won't latch unless keyfob unlock twice
- Rust on wheel hubs
- 2012 Cooper - Battery Dead?
- Expansion Tank Connection Wierd Or Just Me
- Help- bolt snapped in half that holds shock in place
- Mini Cooper key wont start car.
- '08 R55 (Non-S) idle and stall problem
- Cooper S won't churn over
- MPH warning beep?????????
- Not too happy with MINI
- P0503 - p3202
- Would a bad Thermostat cause boost cutting and bad accel?
- throttle "stutter" under acceleration
- Idle issues - BMW/Mini software update
- Strange Pull to Right Below 18 MPH
- Key Removed but Radio Still On
- Issues with driveability when A/C is on.
- Plume of blue smoke when cold taking off
- Fuel gauge readings?
- brake groan on gentle stop
- Bentley Manual 2007-2011...... thoughts ?!?!
- Problem with windows today
- where to mount the bsh oil catch can
- 2009 MCS OBDII Code P0173??
- Seatbelt tensioner and airbag failure in first 6 months
- Engine temp always reads 285.
- Battery issues
- Suitable Grease for Sunroof Rails
- Engine Light and Misfire on 09 Clubman S
- Clicking sound, no start, and then.....
- Check engine light 2008 mcs
- sunroof warning lamp (how to initialize sunroof?)
- Pepper White Discoloration
- Crank Oil Leak
- Slow Boost at Low RPM and then 1/2 Engine Symbol
- Auto Transmission Rant
- Possible Rust Issue
- P0015 need help with this one!
- New ignition coil
- cc id 29 FIX half shaded engine sign/ code 2885
- side badge ruined
- Mini Cooper R56 Timing Chain Tensioner Replacement (Before/After Video)
- Exterior Lighting Warning Light On - exterior lights are all on
- Mini front shock warranty challenge
- $600 for front brakes? And do BMW dealers service MINI's?
- CC ID_275 problems
- Anyone with coolant that looks like this?
- Check engine light after smog test
- Think I have a camber issue, speedo/gps diff speed, new mini owner.
- When is a squeak not a squeak?
- 2010 MCS Spark Plug Replacement: Horrible experience
- Not another problem!
- A\C issue
- Final hurdle really need help with these codes
- justa starts rough
- Clutch engagement question - is this normal?
- Turbo oil banjo bolt & P28AE
- 12 Justa with screwed up directionals
- Possible Steering Problem with 2012 Mini
- What causes poor fuel economy?
- knocking after belt replacement on R56 Cooper
- Mini not starting
- Third Brake Light Bulb OUT...No Warning Light??!!
- Cc id 029
- Hard Start/Cooling Fan Runs Constantly
- A/C Line wear from Sway Bar
- Death Rattle Question!
- Water leaking in passenger seat from center console
- OEM Flywheel from different sources?
- screechy/squeeky noise, especially as engine powers off
- Is a mini reliable?
- low beam trouble indicator
- Autocrossing - throttle limited to 30% with DSC OFF - any ideas???
- Day 5- leaky windows and speakers stopped working
- Loss of power AND thermostat issue.
- My warranty is ending… seeking advice on some problems.
- New Car: Cosmetic Issues
- Upgraded Audio - CD Player Issue
- interior door handle
- Clutch is gone. Is this normal wear or is the dealer stickin it to me?
- audible alarm?
- Should I be concerned?
- New owner with possible 2 issues
- Exhaust sounds strange
- Two issues!
- Hatch won't stay closed
- Elusive Service Records - Help?
- ACC, fog lights and windows don't always work
- 2011 MCS Clutch Grinding Noise
- Yellow Mini on a lift error
- What does this warning mean?
- Punctured Tire... mow what?
- Tachometer warning symbol
- Rear Brake Pads
- correct head gasket for Cooper S
- Goo/slime running out from scoop/hood area down bumper
- Dual mass flywheel dimensions needed urgently
- Our 'Sealed' Automatic Transmissions
- Newish member, some questions about issues
- Battery Issues?
- Clutch slipping @ 37K Need advise
- "Check Engine" light came on
- New MINI w/ Airbag & Seatbelt light on
- Clutch Howl on my 2009 Clubman S with 53k Mileage
- Turbo oil feed lines
- Anyone know where to find this "EP6_GDI_Distribution_8_mars_0*002.wmv "
- getting a new car, one part at a time:)
- P115c P115d
- A bunch of electrical problems...
- rough idle and P1497 code!!
- Timing Chain Replacement
- Dipstick pictures?
- Buying a MCS R56 2007-2009
- Sunroof shade issue
- Timing Chain Tensioner Bolt - Backed out!
- brakes: OEM to Aftermarket
- Quirk With Power Folding Mirrors
- Door Lock Actuator
- Would you say all is well with clutch install?
- Clutch noise/feel
- Mini of Baltimore County
- I took that thermostat housing and made it my B**CH
- Ping under low RPM acceleration
- 08 MCS with 20K Cold Start Rattle Mess
- No Fan No A/C ... related?
- timing change question again
- OBD codes
- Key FOB Dead. Fix or go to dealer for new one?
- blown turbo - clogged cat
- Timing Chain Check Procedure
- Oil filter cover exploded during oil change
- 08 MCS Clubbie wheel damage?
- Help… broken Thermostat bolt!
- Anybody here with size EE width feet?
- 2010 MiniS Idle dip when stopping
- I have searched till I am Blue
- Another spongy brake thread (after replacing pads/rotors)
- Are most of these issues posted related to just the MCS, not the Justa?
- Oil Dipstick
- Leak from over head reading lamp
- Check engine light - CC-ID 000
- Creases in driver's side window sill
- Noise from brakes
- Clutch replaced not going into gear when on?
- Exhaust smell in cabin
- Big Puddle - Yellow Light - Help
- Where do you get your replacement parts from?
- SES light on 06 mini s stays on
- Help, dtc code 2BD4
- Which direction does the clutch plate go?
- Clutch depress - won't start
- Half CEL, CC ID 029, but idles fine
- Timing chain tensioner oil leak..driveable?
- Can I clear a CEL without a scan tool?
- Alignment question
- reusing TTY bolts on flywheel
- steering rack noise
- Gen 2 MCS huge lack of power after recall
- Durability of Aftermarket Clutch (Survey)
- Codes from Scanguage
- 2009 MCS; cold start, engine wants to die [video]
- C.E.L. P0218 - also rough 'cold' start
- chances of good will repair
- Sunroof Wind Deflector Issue (stock)
- Extended Maintenance Contract Question - Spark Plugs
- Solution to oil consumption, vlv cover leak and more?
- '11 MCS Engine light on, Fan runs loud after turning car off
- All who have had TC Tensioner Replaced
- Please help! HOT Engine!!! Advice, Please
- Ziiing on Cold Startup
- Princely Noises
- ABS, TCS, and Brake lights on
- Timing Chain service covered by an extended warranty?
- rattling and oil leak
- 07 Mini Cooper S Passenger Seat Won't Budge
- How quick are they doing the recall once you drop off car?
- I got 'new' ticking...
- Screeching noise from rear wheel
- Scallop Wear on Rear Tire(s) AFTER Alignment
- 07 Cooper S - Blown Turbo Scored Cylinders
- 30k mile maintenance for Mini cooper
- What is making this sound?
- Is my clutch gone?
- P111b error code
- 2 years and I'm just noticing THIS!!!
- Wind Noise from this Vent
- Jerky Drive - Fixed
- Power loss under heavy load
- Where's my power gone?
- p2097 and car wont start.
- Carbon build up thought
- Dimming mirror
- vacuum line
- sticky sunroof
- Manual Transmission 4th Gear Whine
- engine rattle sound
- Dissapointed. Low power/high fuel consumption. 1 year and no fix found
- 2007 MCS Problem. Help! Please!!
- car jerking when let off the gas
- ...Dealer is a Killer...
- Vacuum pump seizure/cylinder head removal
- Justa Cooper Engine noise Question & wind noise fixed
- yet another thing...
- Almost laughable right now!
- Loss of Boost and Code.
- valve cover gasket replacement
- Just-a-Cooper Oil Consumption
- Transmission scrape sound 2nd gear
- Sluggish Mini
- Why seafoam and methanol won't clean caked on carbon build up
- Condensation in side markers
- DIY For Timing Chain Replaement
- transmission troubles
- Mini troubles
- TPMS Problem
- 2007 R56 - Zero Compression Cylinder 3 - Need Advice Badly
- Newbie with embarassing flashers
- Faulty Radio display on my 2008 MCSA
- Exhaust Help
- Help with loose hose in engine (see photo)
- Car Shakes, Cylinder 3 Misfire, Changed Spark Plugs...
- Brake whistle/air noise while light-braking at low speeds
- Oil residue on top of engine?
- Mysterious Chime with no warning light
- Urgent: Front end link snapped- is it dangerous to drive with?
- Sand under the Hood.
- Fuel Filler Cover Pot Flew Off Today!
- Shifting is "Notchy"?
- P0303 code/hesitation
- Does unmetered air = lean running?
- Strange warning light?exclamation point
- Warped flywheel...
- Oil leak R56
- What's going on here??
- Somthing inside my tire?
