Check engine light
Old Jul 8, 2012 | 06:00 PM
mini4mo's Avatar
mini4mo
Check engine light UPDATE
Well the check engine light came on today with about 8000 miles on the clock.
The strange thing is when scrolling through the display diagnostics,everything says OK!
Going to have my son scan it,but already have an appt. set up in a couple weeks.
This sucks!
Old Jul 8, 2012 | 06:36 PM
Llanrhaeadr_Cymru's Avatar
Llanrhaeadr_Cymru
If you have not already done so, make sure your gas cap and oil fill cap are on properly. I created a similar problem for myself with an improper installation of the oil fill cap.
Old Jul 9, 2012 | 05:54 AM
mini4mo's Avatar
mini4mo
Thanks for the tip.
Pretty sure its not those things.Already ran half a tank when the light came on.
Never heard of the oil cap setting a code and it has not been off since since 6000 miles ago.
Old Jul 9, 2012 | 07:04 PM
bluefox280's Avatar
bluefox280
Originally Posted by mini4mo
The strange thing is when scrolling through the display diagnostics, everything says OK!
What scanner were you using? A generic OBDII scanner? A iPhone app?
Or an approved MINI-protocol scanner like a Bavarian Technic?
- Erik
Old Jul 9, 2012 | 07:19 PM
Benibiker's Avatar
Benibiker
Happened to me with the gas cap but it was instantly not after several miles.
Old Jul 9, 2012 | 09:11 PM
theunclesam's Avatar
theunclesam
Same thing happened to me today. I pulled the code with my Garmin EcoRoute HD: P2402 Evaporative Emission System Leak Detection Pump Control Circuit High
Only thread I've seen about it is here:
https://www.northamericanmotoring.co...02-anyone.html
I checked the oil and gas cap. All seemed tight, so no idea what it could be.
Anyways, going to take it into the dealer this week when I get a chance.
BTW, this is a 2011 MCSa. No mods.
Old Jul 10, 2012 | 06:40 AM
mini4mo's Avatar
mini4mo
- Erik
Have not scanned yet.
Think my son has a OBD type.
Let me guess,only the mini approved will work?
Old Jul 10, 2012 | 06:57 AM
bluefox280's Avatar
bluefox280
Let me guess, only the mini approved will work?
No, a generic OBDII scanner will work, but it may not pick up the specific fault like a MINI-protocol unit.
Generic OBDII scanners are just that, 'generic'. They don't have the exact listing of faults from the manufacturer.
They only have the federal mandated P-codes which can steer your diagnosis in the wrong direction.
- Erik
Old Jul 10, 2012 | 06:59 AM
schatzy62's Avatar
schatzy62
The best is to use a MINI approved but many of ODBII generics will at least give you an idea of where to start. iPhone/Android apps can be sketchy as they can be very very very generic.
Old Jul 10, 2012 | 07:24 AM
mini4mo's Avatar
mini4mo
Just scanning to get a clue of whats wrong.Going to be taking it to the dealer next week.
Thanks.
Will it do any harm to drive with the light on?
Old Jul 10, 2012 | 03:36 PM
bluefox280's Avatar
bluefox280
A solid illuminated CEL won't ruin anything, a flashing CEL can damage emission components like a catalyst.
- Erik
Old Jul 10, 2012 | 05:28 PM
mini4mo's Avatar
mini4mo
Thanks Bluefox!
Old Jul 10, 2012 | 06:22 PM
mini4mo's Avatar
mini4mo
Well my son scanned it and got code P173B.Looks like it has something with the temp. sensor.
Old Jul 10, 2012 | 07:04 PM
bluefox280's Avatar
bluefox280
* MINI DTC P173D (0xCF2D) - CAN Engine Coolant Temperature Invalid
The ECU isn't seeing the proper engine coolant temperature, either because the Coolant Temperature Sensor (CTS) is failing, or there's a wiring issue.
It's a common trend recently that the CTS fails without warning causing problems with performance as the ECU doesn't know if the engine is up to running temp or not.
Start there, and replace the CTS and clear codes; see what that does for you.
- Erik
Old Jul 11, 2012 | 06:10 AM
mini4mo's Avatar
mini4mo
Does Mini replace with a revised part?
Have to drive it another week and a half before it goes in on the 21st.
Old Jul 11, 2012 | 08:40 AM
mini4mo's Avatar
mini4mo
Goofy light!
My wife drove the car to work today and the light did not come on.
Old Jul 11, 2012 | 01:19 PM
bluefox280's Avatar
bluefox280
I cannot confirm such yet, but there has been other CTS replacement cases under warranty with similar situtations.
- Erik
Old Jul 11, 2012 | 01:22 PM
sean5294's Avatar
sean5294
The check engine light is the most reliable part of my car lol
Old Jul 11, 2012 | 02:04 PM
theunclesam
Got mine back from the dealer today. Was throwing P2402. Gas, oil caps were tight. They replaced the fuel tank breather.
Part #: 1 13-90-7-624-542
All seems to be well now.
Old Jul 11, 2012 | 05:54 PM
mini4mo's Avatar
mini4mo
Well my wife just called me,the check engine light is off but a low battery warning came on!
Old Jul 28, 2012 | 07:42 AM
mini4mo's Avatar
mini4mo
Update
The dealer had to replace the thermostat/coolant temperature sensor.That was also draining the battery by leaving the fan running longer.
They also replaced the oil pump solenoid and wiring harness due to oil intrusion.
Along with that they replaced both sun visors.
Old Jul 29, 2012 | 08:14 AM
CA94960's Avatar
CA94960
What was wrong with the sun visors?
Old Jul 29, 2012 | 04:39 PM
mini4mo's Avatar
mini4mo
The hinges on the flip up mirrors would pop out.
Old Aug 31, 2012 | 10:36 AM
MiniAJ's Avatar
MiniAJ
I had to replace both of my sun visor for the same reason and my gf's broke as well. It seem s that the plastic that they used on the hinge is not strong enough or faulty.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
