Drivetrain Won't hold idle after work performed
Old Aug 8, 2015 | 06:58 PM
Lt. Dan's Avatar
Lt. Dan
Hey gang, I tried searching and couldn't find anybody that ran into the issue I'm having
Tonight, I tackled a split intercooler coupler, and a failed harmonic dampener.
Before the work, I had a check engine light, combined with a high idle.
After replacing the intercooler couplers, I started the vehicle, and it idled fine.
Replaced the harmonic dampener and installed a new belt. Now, the car will not hold an idle, and a quick drive around the block keeping the revs up shows that it's running VERY rich, with smoke coming out of the exhaust.
Computer is not showing any codes. I have pulled the intercooler back off to check for any noticeable lines loose or any other evidence I damaged something. no such luck.
What's my next step? Anybody run across something like this before?
Old Aug 10, 2015 | 07:13 AM
BlwnAway's Avatar
BlwnAway
I can't think of anything up front that would cause this kind of issue unless you somehow damaged our disconnected a sensor, (Cam sensor would be the only thing up front, but it almost sounds like the Map Sensor in the intake) or possibly idler or tensioner issue that isn't turning the SC properly. (But it should still idle properly) I'm wanting to say that something maybe got damaged our unplugged when using the belt tool.
Those are my only guesses.
Old Aug 10, 2015 | 07:21 AM
Lt. Dan's Avatar
Lt. Dan
You're actually correct!!!
Ended up finding that I probably whacked the purge solenoid valve with the serpentine belt tool. It was sticking open, causing the engine just to suck gas fumes straight from the tank, so it wouldn't idle... a quick search for the Delphi part number (delphi 1997278) online found a match for a Saturn Vue at the local store for 30 bucks!!!
Old Aug 10, 2015 | 08:15 AM
BlwnAway's Avatar
BlwnAway
Glad to hear it.
Also, do a couple of start and stops in case the ECU started to try and adapt for the issue.
Old Aug 10, 2015 | 08:23 AM
https://www.northamericanmotoring.co...-long-way.html
Just talked about here.
Emnotek
Aug 13, 2015 05:47 PM
minipopkart
Aug 13, 2015 05:22 AM
Aug 12, 2015 01:24 PM
DWooderson
Aug 10, 2015 09:12 AM
