P111b error code
Old Apr 2, 2012 | 06:38 AM
burgerdog's Avatar
burgerdog
P111b error code
Had a CEL come on in my R57 Cooper along with some unstable idling. The car drove normally and the idling problem was intermittent. The light went off by itself after 2 days and the next time when the idle speed dropped the light did not go on. I did a scan with Torque (Android), there was no error code stored.
I started the car and scanned again and got the P111b error code. The CEL is still off. Does anyone know what this means ? Can't find much info on this online.
Old Apr 3, 2012 | 12:22 PM
bluefox280's Avatar
bluefox280
Originally Posted by burgerdog
...got the P111b error code. The CEL is still off. Does anyone know what this means ?
Give me till tomorrow evening and I'll have more details on this.
- Erik
Old Apr 3, 2012 | 12:56 PM
alexs3d2's Avatar
alexs3d2
P111B: 0x2B68 Mass or Volume Air Flow via O2 Sensor Too Low (Bank 1).
You probably have a leakage somewhere, maybe a cracked or incorrectly plugged tube...
Old Apr 3, 2012 | 10:43 PM
burgerdog's Avatar
burgerdog
Thanks very much. I didn't see any vacuum tubes/ hoses when I looked under the hood but will check again. I have a K&N panel filter installed for about 10,000km if that means anything, but didn't have any issues until recently.
Old Apr 5, 2012 | 05:50 AM
bluefox280's Avatar
bluefox280
MINI DTC P111B (0x2B68) - Mass or Volume Air Flow via O2 (Oxygen) Sensor Too Low (Bank 1)
The ECU is seeing a too low of intake air through the reading of the pre-cat O2 sensor.
That either means the ECU is trying to adjust for a too rich of burn, or there's a downstream leak in the system.
Pressure check BOTH the intake and exhaust side of the system, making sure gaskets, and components are not venting any air to atmosphere.
- Erik
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
hamptup
R55 :: Clubman Talk (2008+)
18
Nov 29, 2016 05:04 PM
MiniSkoon
Sep 9, 2015 12:40 PM
MasterShaftner
Sep 4, 2015 03:52 PM
