OEM Flywheel from different sources?
OK here is the question/opportunity. I have a 2009 Clubman S with 54000 miles. The clutch is starting to go and I have a MINI extended maintenance agreement. The maintenance agreement will pay for the clutch replacement but NOT for the flywheel. I got the P/N from the dealer and did a google search. The results that came back yielded many sites that carried the flywheel for significantly less than what the dealer wanted. The dealer wants around $1000 while the on line parts houses are anywhere from $539 to $800. And they all say that the part is new. The dealer said that I could buy the flywheel from someone else and that they would install it during the clutch change. From what I have read, the flywheel should probably be changed out during the clutch replacement. Is SACHS the OEM manufacturer? Is it risky to buy from these sites? Links below:
Book #: 21 20 7 575 069
Description: Dual-Mass Flywheel 228 mm
Manufacturer: SACHS
Part Type: OEM
http://www.rmeuropean.com/Part-Numbe..._6BF6755E.aspx
http://www.koperformance.com/part-nu...9/GENUINE-MINI
http://www.openroadautoparts.com/sto...%20575%20069/3
Thanks in advance for your thoughts!
Manufacturer: SACHS
Part Type: OEM
First, you may not have to replace the flywheel if you catch the clutch soon enough. Mine was fine and I just had it done.
Sachs, Luk and Valeo I believe are all suppliers for MINI. I found the Luk flywheel on (dual mass) on Parts Geek for a great price.
http://www.partsgeek.com/catalog/200.../flywheel.html
I have ordered from them before and they have never let me down. I bought my clutch kit off of them for 100 USD.
andrewjg1994
Jan 29, 2021 07:45 PM
blackie
Oct 2, 2015 07:41 PM
Aug 19, 2015 12:51 PM
