low beam trouble indicator
Old Jun 25, 2012 | 03:34 PM
Sabini's Avatar
Sabini
The manual says , check low beam bulb or fog lights. I don't have fog lights and both headlight bulbs are fine. anyone else have this warning light come on?
Old Jun 25, 2012 | 06:38 PM
bluefox280's Avatar
bluefox280
Actually, the light indicator means to check ALL EXTERIOR bulbs; rear, front, side, license plate area... everywhere.
The ECU see a bulb burned out; find and replace and the warning will be removed.
- Erik
Old Jul 16, 2012 | 06:51 AM
Sabini's Avatar
Sabini
All the bulbs are working. I had a different warning light come on when a bulb did go out in the past.
I did some research and found this problem is a service bulletin recorded as 'TSB SIM630110:Check Control Message but Lights are Operating Normally.'
However I was unable to find the solution to this service bulletin, anyone have this experience with the fix?
Old Jul 16, 2012 | 10:46 AM
bluefox280's Avatar
bluefox280
Have you contacted the dealer to see what the TSB involves?
Sounds like it could be as easy as a module reflash / reprogramming.
- Erik
Old Jul 17, 2012 | 05:30 AM
schatzy62's Avatar
schatzy62
The TSB paper work states:
Refer to the KSD2 to code the repair performed as prescribed by ISTA diagnosis results and the Warranty
Policy and Procedures Manual for specific warranty coverage.
So it definitely sounds like a programming issue if they are telling them to code the repair.
Old Aug 20, 2012 | 10:14 AM
jamadeus's Avatar
jamadeus
Hello, I just got this warning light. I checked all the lights are working fine. Has anyone have a resolution for this? Should I call the dealer?
TIA
Old Jan 9, 2013 | 09:38 AM
HarlequinAuthor's Avatar
HarlequinAuthor
I just got this light myself. Anyone have any resolutions?
Old Jan 9, 2013 | 09:49 AM
jamadeus's Avatar
jamadeus
For me, I took it to the dealer and they said it's the computer system fault since mine doesn't have any fog lights. They updated it to the latest and the warning light was gone. Mine was little shy to 50k and they did it free with warranty. They said it would cost $300 if out of warranty. Is it true?
Old Jan 9, 2013 | 07:56 PM
HarlequinAuthor
I have 46,000 on it, no fog lights either. I made an appt with the dealer after checking each and every bulb outside and in. Road trip since the nearest dealer is 3 hours away.
Old Jan 26, 2013 | 08:37 AM
HarlequinAuthor
I finally made it to MINI Copper. LONG DRIVE! Turns out there is a service bulletin on the R56 causing the low beam indicator light to come on. On the way down a new indicator came on - yellow window with exclamation point and the windows stopped working. Then they wouldn't go back up that last fraction of an inch when I opened the door. All a part of that service bulletin. Reprogramming car now...which apparently takes a few hours. At least I got in right under the warranty expiration.
Old Jun 26, 2013 | 05:24 AM
abonn
Well this makes sense - computer reprogramming. Thanks to everyone on this post since I was pulling my hair out trying to understand how to fix this problem. Since I'm way out of warranty, I'll defer the reprogramming and just continue to clear the error. I'm sure it will appear in time for my annual inspection though. :-)
Old Sep 24, 2015 | 07:24 AM
ultrakill's Avatar
ultrakill
Hello, I know this is an old thread, but how exactly are you "clearing" this error? Both my OBD2 scanners are not picking it up. Granted they are both budget readers. If you unplug battery for an hour will this warning light reset?
Any help solving this issue would be helpful. I used the stalk control and eventually got it to give me CC-ID 138 as the error code.
Old Nov 20, 2019 | 06:37 PM
ZRXChris's Avatar
ZRXChris
new 2010 mini clubman owner here and I’ve got the same warming light, no warranty. Is there a way to fix it?
CardinalsRule
Jun 11, 2016 04:34 PM
Burkee52
Electrical
Sep 18, 2015 11:12 AM
OdzBodkinz
Sep 11, 2015 07:20 PM
