- Window Seal when closing door
- Gas Tank Capacity & Mileage
- Something leaking out of the rear wiper assembly?
- Water in Fog Lamp... Common?
- Blown fuse
- Drivetrain noise with LSD?
- Noisy brake pedal?
- does it seem like there are very few problems with the R56, at least for a new car?
- auxiliary port
- Swapping o2 Sensors
- Groaning 2nd Gear and Other Assorted Issues
- Engine Light On and Car Sputter Problem Reports ONLY
- R56 S - engine noise
- Gearbox/shift linkage fighting me
- Tach & Speedo -- dead
- Limp home update
- multifunction wheel without multifunction?
- Loose rear tow hook hole flap/cover?
- 07 MINI limps home after 8 days.
- Car nearly flipping out
- 2007 Xenon headlight pattern
- Is Comfort Access Option worth it???
- 2005 Xenon behavior question
- How do you replace the polon filter???
- '07 R56 MC auto dead @ 4K miles in the UK
- R56 dead, no fix after days
- alternator bolt issue/recall (maybe)
- Rattle in R56 dash
- Consumer Reports Ranking: MINI Down
- Faint crackly sound
- cold air in foot well
- Reliability of Turbo Engines?
- R56 problems
- Blow off valve on the R56
- does the r56 suffer from **STRUT TOWER MUSHROOMING**?
- Strut towers in 07?
