View Full Version : Stock Problems/Issues
- AC Repaired-Tips
- Electrical Issue
- Footwell module fried from my mechanic jumping battery?
- Buzzing whining sound when engine shuts off
- 2011 Clubman s N18 quit on the wife again
- 2008 R56 S N14 Blue Fog From Exhaust
- Engine Knock, Need Ideas
- Car on Fire
- Action needed or not with Service light?
- 2009 R57S clock doesn't change time and radio stays on
- Upgrades??
- N18 Compression guidelines
- Unmetered air
- Hard Brake Line Broke - Fix or Replace
- 2009 mini cooper s performance engine replacement for blown motor
- 2009 Mini Cooper S r56 - Engine Whine - Oil Pump / Oil Pump Chain?
- Thermostat JCW R56
- R56 N14 Power loss, and P1338 code.
- Window not sealing r56
- Changed Clutch - Multiple issues...HELP
- Clutch Position Sensor
- R56 Starting Issues
- Alternator rebuild parts
- R56 N14 oil burning idea!?
- Blue smoke after hard use
- Relay ID R/H kick panel
- Axle stuck in hub.
- JCW BorgWarner turbo part numbers?
- Using Mini as a toad
- New HPFP didnt fix low fuel rail pressure
- P0088 and P1216 code causes?
- 6/12v tester
- Intake Boot Cracked - replacement?
- Piece of crap P1497 code....done so much with no fix...
- Service light reset
- Spark plug issues
- 2008 r56 hard top diy cat converter replacement questions
- 2011 Clubman S quit on me (HPFP?)
- [2012 Clubman] Turbo Whistle Issue?
- 2010 R55 Possessed!!!
- Front Sway bar bushings
- Belt tearing up, ac compressor not working, battery discharging, etc.
- MT missing sensor?
- MT crush washers?
- MAF or MAP
- Intermittent cyl 2 misfire after head rebuild
- Fresh air/Recirc not working
- In need of help
- Oil Leak - Advice
- Need help with wheel bearing.
- P0303 Has Me STUMPED!
- Engine harness routing on MCS for aux water pump, wastegate and secondary cat
- Mini Problems
- 2007 Cooper S stalling after it gets hot
- R56 Water Pump Relaced New Problem
- mini cooper s r56 koni special active rear noise
- Car will not turn over; battery good
- Water dripping through airbag cutout on C pillar
- Snapped HPFP fuel hose clip!!
- Newbie question
- Error code in Secret menu? Please help....
- Loud Clunking Shifting Into 1st Gear
- Red Low Oil Pressure Warning Light (Solved!)
- strong exhaust smell
- Mini Cooper S rough idle, P115C: carbon deposits? Harness?
- throttle body replacement, reset adaptation?
- catalyst lifespan
- brake lights and indicators stay on ?
- Need a compression check sanity check
- Fuel pump running after shutoff?
- N16 - Noisy friction pulley (video): fix without lowering engine?
- N18 boiling coolant
- Stock Satellite Radio NO CHANNEL
- R56 Coolant Crossover Pipe - Isnt there a better way
- Help!
- '09 MCS No Oil Pressure
- I have coolant in the oil & oil in the coolant but didn't overheat & compression fine
- Check Engine Light
- Intermittent A/C: fan, resistor, or ???
- 2011 Mini Cooper s N18 engine is toast
- Need help with sound.
- Misfire and out of town
- guide on how to check for vacuum leak?
- Coolant leak at pump end after rebuild
- N18 Cooper S Oil leak.
- Is a gap between the engine air filter box and lid normal?
- High Air Conditioning Discharge Temp (Solved!)
- 2012 Cooper S (N18) ticking/rattle at idle
- New key fob . Not recognizing
- Strange loss of power
- Rein harmonic balancer self destruction R56 Cooper S
- 2007 r56 cranks but won't start....
- Old style vs new style dv
- Mysterious P3007 engine code from 2010 Mini Cooper S (R56)
- Code 2065 + occasional "skips" under acceleration
- 2007 r56 won’t start
- 07 mcs died, possible dme failure?
- Can't open passenger door from inside or out
- Exhaust pipe clamp isn't sealing
- Orange Exclamation Point and Car Won't Start
- Trans noise and fluid question
- Do i need to replace the block?
- camshaft timing sensor replacement
- Engine hesitated under turbo boost
- Inconsistent idling
- camshaft exhaust stuck
- 2008 MCS No boost
- Help! No start, power good
- low oil pressure at idle
- FRM3 Resurrection
- Loose spark plugs
- 2013 R56 MCS Clutch issue
- Mini cooper P0015 trouble...
- water pump mystery
- 2012 Bayswater R56 experiencing Transmission Slipping
- CC ID 029... car seems fine?
- Oxygen Sensor problem
- Help diagnose coolant loss around thermostat
- AC/Vent issues
- N14 starting problem
- Trans issue?
- 2010 mcs need help!
- o2 sensors for cheap? P0141 and P115c fault codes
- 2013 R56 Oil Eater
- Replaced thermostat, still have code PO128
- Overboost/ reduced power mode?!?
- Can't Unbolt Crankshaft Pulley!
- Engine cool down fan
- Coil packs
- Oxygen sensor issue
- Air conditioner troubleshooting help
- Vacuum line test fail
- Fixed Vibrating brake rotor issue for $10
- CRC 05319 GDI IVD Intake Valve & Turbo Cleaner
- 2008 Mini S boost solenoid
- 2008 mini S Boost solenoid (pressure converter)
- Car sputters when idling
- O2 sensor post Catalytic converter error on 09 Base Mini
- Possible DME replacement
- P0974, 2007 Cooper S
- Constant misfire with no explanation.
- MINI Cooper 2010 6th Gear Pop Out
- An oil leak you've never seen before
- Clutch help!
- P115c code changed MAF and gettign another code.
- Newbie owner needs help diagnosing idler, tensioner, or belt noise....
- Clutch and flywheel
- Generic replacement thermostat?
- Chemical smell / possible evaporator leak
- 2014 clubman s R55 N18 turbo problems
- Air in coolant system or a bad thermostat?
- Intermittent Light Show On My Dash!
- 2010 Justa overheating, code PO128, thermostat?
- Stalling Issues and Now Won't Start at All
- WARM idle issue on n18 mcs
- Need help finding replacement hardware for front bumper
- TOO MANY engine codes
- Any ideas on what this is? 07MCS MT
- 2013 R56 Cooling Fan replacement?
- Cold start fine, Warms up and Idles varies 500-700
- FRM Warranty Experiences
- R56 valve cover oil leak N14
- Mini Key Unlock Button
- Xenon turns on then off
- Using Lots of Oil
- Head Gasket Repair?
- Replace thermostat now P0128 code & old barrel temp sensor zip tied
- Hesitation at Around 1st Gear
- High pressure fuel pump R56 S (N18) - PSA alternative
- Gear engaging
- Replaced rear shock/strut mounts and still have board noise
- HELP!! Broken Rear Shock Mount Tower Bolt
- Help, anyone in the Charlotte area? Sirius troubeshooting
- My fix for code 93A8 Driver Side Airbag Stage 1
- car is crazy
- Please help
- 2010 R57, cant get Sat radio to acquire signal
- Best Extended Warranty?
- R56s (2012) - Transmission 6th gear
- Help. Coolant pressure and other problems
- MCS R56 N18 Pinging
- Update on mysterious cold start rough idle
- 100,000+ miles maintenance suggestions
- Loud "roaring" from 40-70mph?
- fixing a leaking vacuum pump
- Brake Booster Vacuum Pump Nipple
- Surging Idle, mind boggling help please!!!
- possible bad dme
- P1634 anyone see this code?
- 07 Cooper S BAD!! idle cold Stumpted!!
- Rear Brake Line
- Mini Engine noise
- Engine stumble in cold weather
- Another diverter valve thread
- R55 Terrible Misfire, Cylinder 2 not firing.
- Anyone replaced the AC expansion valve on an R56 Cooper?
- Replace Front Shocks?
- Looking at 2011 S with bad turbo to purchase. Advice?
- Brake pad wear sensor questions
- Timing chain issues in 2012 model?
- 2010 non-s multiple misfires (replaced plugs & coils) looking for pointers
- Intermittent charging issue/ battery light
- I'm back.. smh. I wish we never bought it lol
- Reaching op temperature gets engine light (R56 N12)
- R56 jcw boost cutting in 4th, 5th and 6th gears
- New motor in new (to me) car. 9E2C time-out Telegram and 9E2E time-out device status
- Error codes P0300, 0301,0302, 0303 & 0304
- R56 Fraying belts after alternator replacement
- 2007 cigarette lighter not working
- 2009 JCW timing chain
- 2008 non-S runs great but idles at 1500 after warm and stopped.
- Manual 2007 r56 Braking
- Possible "Death Rattle" Situation on a 2007 Mini Cooper R56 S
- 2011 Mini Cooper s n18 won’t start after engine failure
- VANOS and timing help
- Cannot get car to idle.( posting in couple spots)
- im posting this in couple spots, cant get car to idle.
- Engine won’t run n-18
- Any success with Warranty grandfathering? 2C57 code
- 2011 MCS N18 In Limp Home Mode
- Airbag/seat belt light and fast blinker
- Climate Control Issue
- Oxygen sensor replacement
- 2013 R56 low pressure light
- Knock code after washing engine
- Half engine light but car has full power
- Three honks on Startup.
- half power light on.
- Rear Main leak symptoms?
- OEM manufacturer for N12 timing chain? Bilstein?
- Vacuum pump failed?
- Won't idle upon starting until warmed up
- R56 JCW oil leak, P1497, rough idle
- Pressurized crankcase
- Low pressure light
- Timing chain tension question
- What does you clutch engagement feel like?
- 09 R55S frying coils.
- No Vacuum at Idle or Revs
- Very Sick Coolant System
- 2009 Clubman OEM Radio Not Working
- Rattle under throttle
- Misfire help
- Oxygen Sensor Problems w/ 2008 Mini Cooper
- R58 will not start
- Timing chain bolts getting loose help
- Burning oil!!!
- SZL: Recalibrate, Repair, or Replace?
- Factory center arm rest
- HPFP to fuel rail pipe
