Replaced rear shock/strut mounts and still have board noise
Old May 30, 2019 | 06:10 AM
Visionary44's Avatar
Visionary44
Hello all,
I recently replaced my rear shock/struts and honestly I think I have more "board" noise than I had with the OEM's... I ensured that everything is tight, and torqued to specs, but I still get it on both sides, more on the passenger though. The shocks/struts are standard replacements (nothing performance), but I thought for sure they would be better than the OEM's!
I'm running the Bridgestone RFT Driveguards and know RFT's don't have the smoothest or quietest ride, but the board noise is another thing.....
Any thoughts, suggestions?
Thank you!
Old May 30, 2019 | 06:28 AM
I like mini clubman's's Avatar
Check your sway bar links. I'm in the process of changing mine and i think that's where I'm getting my noise from. Rockauto.com hurry up!
Old Jun 5, 2019 | 06:50 AM
Visionary44
Hey @Ilikeminiclubmans, did the change in the sway bar links help your cause? I will be taking a looking at mine this weekend and was just curious.
Thanks!
Old Jun 5, 2019 | 07:38 AM
cooper48's Avatar
cooper48
You should also check your rear sway bar bushings and brackets.
Old Jun 5, 2019 | 08:02 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
"Board noise"?
Old Jun 11, 2019 | 09:55 AM
cargusjoh's Avatar
cargusjoh
Just had my sway bar links and bushings replaced to successfully remove a clunk
Old Jun 13, 2019 | 07:31 AM
+1 check the sway bar bushings and end links, also make sure nothing is loose back there and retorque the bolts, the rear suspension bolts can get loose easy if not torqued to spec.
Old Jun 16, 2019 | 11:21 AM
mellocooper's Avatar
mellocooper
Another vote for sway bar links. Easy and fixes annoying noises. Amazing how loose the ball joints were in mine whenI took them out.
JAB 67
Jan 18, 2017 05:49 PM
_aj_
General Discussion
Jan 12, 2017 11:51 AM
whrisk
Oct 1, 2014 07:35 AM
IQRaceworks
17
Feb 16, 2012 09:40 AM
Maaij
Suspension
Nov 30, 2005 01:31 PM
