Generic replacement thermostat?
Old Jun 8, 2019 | 02:25 PM
ammodave's Avatar
ammodave
I need to replace my thermostat. Generic T-stats seem to sell for around $50; the oem part is around $130. Given the poor reliability of the oem T-stat, is there any good reason to buy oem? Recommendations for an aftermarket replacement?
Old Jun 8, 2019 | 03:12 PM
mkov608's Avatar
mkov608
I've gone through 2 OEM stats (the original and one from the BMW dealership), and one Gates stat. The Gates stat lasted less than 1 year, but I got a warranty replacement from Rock Auto. So far, the 2d Gates stat is working well.
If I ever have to buy another one, I'll get it from FCPEuro since they have a lifetime warranty.
https://www.fcpeuro.com/products?utf...ds=11537534521
Old Jun 10, 2019 | 12:29 PM
ammodave's Avatar
ammodave
I see a Gates thermostat (#34713) with a lifetime warranty available but it says an oe adapter is required. What's the adapter?
Old Jun 10, 2019 | 12:50 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I would recommend going with an original MINI one as I've had several aftermarket ones fail lately. And MINI will do the labor on the original one if it fails as that is their policy.
https://www.waymotorworks.com/thermo...5-r56-r57.html
Old Jun 10, 2019 | 07:06 PM
dmath's Avatar
dmath
Another vote for OEM. I've seen several threads here recently with stories of using a non-OEM thermostat housing that didn't work properly. Then an OEM part fixed the problem. You don't want to have to go through the procedure multiple times over a few dollars.
Old Jun 11, 2019 | 05:34 PM
mkov608's Avatar
mkov608
Who is the original equipment supplier for MINI?
Old Jun 13, 2019 | 07:24 AM
On the N18 newer thermostat its Behr now, on the older one it used to be Behr or Facet for a short time. Mark IV industries, aka dayco/dayco Europe is for the earlier engine. Last time i talked to them they were not selling into aftersales. They have OEM contracts they dictate that for some time. Much like when I met with Mecaplast for valve covers as Ebay fake Genuine Mecaplast valve covers were showing up all over the place with there logo. Mecaplast does not sell into the aftermarket on that cover. just genuine MINI.
Old Jun 13, 2019 | 07:23 PM
Richieb0y28's Avatar
Richieb0y28
Make sure you check www.mini-rp.com to see if the thermo is covered. MINI reimbursed me for mine last yr.
rough68fish
MTH Discussion (Archive)
Oct 12, 2006 04:53 AM
DSA
Aug 2, 2004 09:56 AM
yymc
Mar 20, 2004 02:29 AM
