car is crazy
Old May 24, 2019 | 05:43 AM
Ludopo's Avatar
Ludopo
car is crazy
Hi all,
I have an issue : when putting key In the ignition, wipers turn on
i have no communication with any module ( ABS, steering etc.)
many errors throwing on my dash
rev counter doesn't show RPM ( stay at 0).
speedo doesn't work either.
Switch JBE but same issues
Old May 24, 2019 | 05:53 AM
Ludopo's Avatar
Ludopo
Old May 24, 2019 | 08:05 AM
Ludopo's Avatar
Ludopo
Old May 25, 2019 | 05:25 PM
mkov608's Avatar
mkov608
What repairs were recently performed?
Old May 26, 2019 | 07:36 AM
Ludopo's Avatar
Ludopo
Last repair performed was adding the koala manifold spacer. nothing to deal with electrical problems
Old May 27, 2019 | 01:12 AM
Scudder44's Avatar
Scudder44
You either have a wheel speed sensor broken or steering angle sensor not working or angle is wrong. The steering wheel picture and tirfecta lights are indicative of this fault, google that please. If it is none of these then perhaps water has entered your footwell module and wrecked it. Just re-read your post and you have a lot more faults than just steering going on there, my bad.
Old May 27, 2019 | 05:53 AM
Ludopo's Avatar
Ludopo
I don't think so, because RPM doesn't work, fuel gauge doesn't work either, electric power steering and even A/C doesn't work.
The trifecta is just the fact the ABS/DSC module doesn't work either
Old May 27, 2019 | 09:24 AM
oldbrokenwind's Avatar
oldbrokenwind
With all these different faults, I'd guess at a low battery problem. I've read that a low battery can cause all kinds of random problems.
Hopefully, during any recent engine bay work, all connectors were replaced correctly --- mated to the correct socket and not damaged anywhere on the harness (pinched, broken, or short circuited to chassis). Some of the small connectors can be plugged into the wrong mate --- their keys are very small and flimsy, making it easy to defeat their purpose.
Best of luck, I'm eager to see some current dyno results.
sndwave
Jun 11, 2006 06:29 PM
bruceink
Jun 1, 2006 08:05 PM
PittsburghMark
22
Nov 30, 2002 10:14 AM
