Replaced thermostat, still have code PO128
I recently replaced my thermostat due to an overheating problem. The overheat problem went away but I still have the yellow engine light. Do I need a code reader to make the code go away?
At a minimum you need to connect a scanner to the vehicle and see if a DTC is still locked in the DME memory. If it is, you'll need to clear it.
http://www.foxwellmall.com/
Be careful with that temp sensor plug, too. If you can get a realtime readout on that temperature, that's the best way to see what's wrong.
I had gone through 3 sensors on one MCS before, all the while, it's the sensor plug that has an issue, the prong got pushed off and couldn't be in contact with the sensor itself.
ammodave
Jun 8, 2019 05:42 AM
virexdeus
Jan 7, 2018 07:50 PM
dnelson
Feb 6, 2014 05:41 AM
SPRINTCARS
Jul 15, 2013 10:44 PM
