PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36
  1. Boot latch only opens via fob
  2. 2010 JCW Engine noise
  3. Chirp, chirp??? WTF??
  4. Rear (Drivers side) Brake Caliper Removal????
  5. moving driver's seat(back part)
  6. Yellow engine light after NM Charge pipe?!
  7. Water pump and friction wheel
  8. Metal sound from rear
  9. Glove Box Lock Cylinder removal?
  10. HELP!! Replacement of tranny, they seem to have forgotten to add motor oil?!#%*!!wtf?
  11. 4th time's the charm? (Another death rattle horror story)
  12. Dunlop DSST weather cracks dry rot
  13. Morning hesitation
  14. CEL Issue - Dealer Diagnosis and Questions
  15. CEL at 70 mph and misfire
  16. Passenger window rattle
  17. So, I was driving on the highway to work today...
  18. temperature sensor and check engine light
  19. Rubber tubing behind/below intercooler sagging 2008
  20. Rev Limiter
  21. doors on the R56...WTF...crap design that will barely stay open!??!?!
  22. Bavarian Technic vs. AutoEnginuity Scan Tool
  23. How can I trigger symptoms on a possible failing fuel pump?
  24. Radiator System Smashed to Bits by Phantom Object?!?
  25. drive train rumble?
  26. Armrest - anyone removed it?
  27. malfunction of MPG reading
  28. Headrest angle of evil...
  29. Hatch wiring harness wearing away paint
  30. LO sign on AC indicator
  31. Multiple Component Failures
  32. Rough engine note?
  33. miniusa refuses to replace my warped hood scoop!
  34. "Squeak" noise when engaging first gear on an uphill
  35. just bought 2007 mini s and yellow half engine light is on
  36. Inaccurate gas gauge got me
  37. Hole in my Radiator?! HELP!
  38. timing chain tensioner....AGAIN
  39. Burnt secondary thermostat
  40. Disturbing outcome to noise on '10 JCW...
  41. Headliner rattle
  42. car is jerking slightly while hard acceleration until engine warms up.
  43. Dramatic Oil Loss - Oil Leak
  44. Engine knock -- but not the kind that you think it is.
  45. Intake Valves - how to check for carbon?
  46. HR rear speaker FUBAR
  47. A tapping noise on the left rear suspension?
  48. Weird Noise
  49. Gas Gauge Problem
  50. MINI Canada offers MINI NEXT protection
  51. Shift Mechanism Failure - 2007 MCS
  52. Pop sound from drivers side front wheel well
  53. My mini smells like a tractor trailor truck overheating its brakes....
  54. misfire caused by too much alcholol in fuel ?
  55. Screeching from dash
  56. MCS - No boost
  57. Let's figure out how many people have had HPFP and Cold Start Issues
  58. Getting CEL, Throwing Code U3FFF
  59. Steering Lock Warning Light Question
  60. Clutch failure on non-S models
  61. Bizzare Incident
  62. fault code - 2884 Charge air pressure control deviation, plausibility
  63. Rear wheel alignment
  64. High Press Fuel pump, bad gas or Seafoam?
  65. computer/power problems
  66. internal cracks in the foglight
  67. Chrome belt line doesn't line up
  68. How to Test Control Arm Bushing
  69. They replaced the valve timing motor today
  70. I asked Mini a question! Follow along! Timing Chain Issue
  71. Anyone Had This Problem
  72. MCS Centre Consol Very Hot And Trunk Problems
  73. Power Loss and engine light
  74. The Saga of the High Pressure Fuel Pump
  75. 12v socket not working, Fuse?
  76. Possessed Pass Side Window = Complete Reprogram
  77. Scangauge problem
  78. Turbo Smell?
  79. Question - dash panel to right of HVAC temp controller
  80. Rear body rattle, please test
  81. illuminated sun visor cover broke...
  82. Drivers side door handle cover.
  83. Rear interior door panel keeps popping off.
  84. Ticking from radio speakers
  85. 2010 Cooper S 2 weeks old and dies
  86. 2010 MCS
  87. Convert top from day 1
  88. Does anyone has an auto trans R to D issue?
  89. Battery Issue with 07 MCS
  90. cc-id 139
  91. AC not very cool..?
  92. My R56 jerks!!!
  93. Identifying an oil leak
  94. OBD Settings Randomly Changed?
  95. CEL P0112 & P0238
  96. D-Can Car?
  97. random intermittent misfire
  98. Clubman water leak!!
  99. Clubman Dies at Random!!!
  100. Great Service, New Problem - Cruise Control
  101. Mini service-First Oil Change
  102. Plastic burning smell from under the hood..
  103. Airbag Problem 938A Fault Code
  104. What are the cylinder numbers?
  105. Battery already dying on brand new '10, also running very hot - Cooper S R56
  106. Scoop Color
  107. Audio source selection weirdness
  108. Stereo weirdness.
  109. R57 boot not staying latched
  110. Clutch
  111. 2010 Cooper S Mayfair Oil Bottom of Tail Pipe
  112. Brand New MCS Odd whistle/squeak
  113. Creaking noise behind plastic hatch cover
  114. 2009 MCS - clicks, then acceleration
  115. Any real fix for the Sunroof Sticking Issue
  116. stitching needs repair on my sport seats already?
  117. Run Flat Tires
  118. New 2010 Cooper has loud radiator fan noise
  119. 2009 Cooper S spontaneous fire
  120. I've only had my Mini for a week and it's already stalling
  121. ABS issue
  122. Low speed stalling
  123. Clutch squeak from engine bay.
  124. Death rattle fixed, but new CEL and missing parts?
  125. Bad Gas
  126. Mini wont start
  127. TSB or known fix for this rattle?
  128. How smooth is your MINI at idle?
  129. 08 MCS rolls back when parked on a hill with 1st gear engaged
  130. the end of the road...
  131. iPod not charging... is it just me?
  132. Metallic clatter (not cold start) - need advise
  133. misfire?
  134. Weird boost issue
  135. Windshield on my 09 Factory JCW finally cracked
  136. Door Won't Open When Hot -What's Up?
  137. Air Conditioning
  138. 2007 mini overheating
  139. Rear Light Replacement
  140. dealerships terrible gasket install *pics*
  141. Bentley Publications - Mini Service Manual
  142. Charcoal Canister
  143. CEL 3&4 cylinder misfire detected
  144. Power Window issue
  145. Metallic buzz at 5k RPM?
  146. Vacuum Leak?
  147. Key Fob Rattle
  148. Radio snafu
  149. Funny engine noise - Really need HELP
  150. Gremlins in my Clubman
  151. Anyone knows what "2F37" fault code means?
  152. burnt oil odor
  153. Tear in driver leatherette seat...will warranty cover?
  154. How to remove or adjust the spring that holds up the trunk/boot lid?
  155. Whoops! My thingy popped off!
  156. AC leak, dealer blames me!!!
  157. 07 Cooper S horrible handling??
  158. MINI-less just for a day.
  159. Bad cat?
  160. ? Clutch Problems 2009 S Cabrio
  161. Half shaft?
  162. Seafoam on 93K engine and ... hardly any smoke
  163. WOOOHOOOO... I FIXED IT!!!!
  164. I'm leaking coolent
  165. MINI Canada rejected my warped hood scoop claim
  166. Is the Mini Extended Service Plan worth it?
  167. How to clean/maintain?
  168. Squeaks and Creaks
  169. Positive camber from hitting curb?
  170. So many little problems in 2010 model...
  171. Won't start
  172. Transmission Noise
  173. driver side door lock??
  174. Best Repair Manual
  175. Baddd engine noise...please listen and help!!
  176. Recurring Engine Carbon Buildup Problem
  177. Radio gone silent
  178. Horn not working, what to check/where to look?
  179. R56 Exterior door handle sticks?
  180. Timing Chain Tensioner Replacement COST??
  181. HPFP again! replaced twice in 10 months
  182. Timing Chain Tensioner Replaced?
  183. Auto Transmission slips out of gear @
  184. Here we go agaaaaain.....
  185. Nock type noise from rear when turning off
  186. 07 auto jumps out of gear!!!
  187. Got '07 Cooper S, vibration and noise questions
  188. 08 mini cooper ac compressor wont come on.
  189. Starting issue
  190. Defective Electrical Harness
  191. 2009 MCS Check Engine light many times
  192. What comes with a remanufactured motor?
  193. Timing belt "just fell off" ('07 Cooper S)
  194. Please HELP! Dealer left PCV hose unhooked
  195. "Factory / OEM" Scan Tool Equipment
  196. code 2885
  197. Clicking Sound With CEL CC ID 029
  198. Rear Ended in my 2010 Camden edition
  199. repairs starting to annoy me
  200. 48000Km vehicle service?
  201. HELP: Spontaneous engine bay fire
  202. Paint flaking off on my brand new MINI Cooper
  203. Replacing Cylinder Head Cover - Twice a year?!
  204. CONDENSATION?!!?
  205. Fuel injection?
  206. Bluetooth problem? and ipod resume play problem?
  207. r56 power steering assistance loss
  208. Normal or Abbie Normal?
  209. Noise when turning A/C on?
  210. 09' Justa Clubman
  211. Broken Headlight Bracket?
  212. Clarification - Timing Chain Tensioner Noise
  213. Grabby Clutch on 07' JAC
  214. Add fuel system cleaner only right before oil change?
  215. Start up issues
  216. Picture Of My Valves......Before SeaFoam
  217. Check Engine Light.....
  218. 2008 MCS with gas smell from air vents
  219. Service Engine Warning Light
  220. Transmission replaced and then came loose under warranty!
  221. 2007 Cooper S problems, sulphur smell, etc.
  222. things my clubman have so far.
  223. Noisy Driver's Side Window Under warranty?
  224. Engine Buzz??
  225. Door Lock won't open from inside
  226. Transmission Replacement
  227. Clear bra and stripes
  228. Is the black trim on your wheel arches even?
  229. Covenience Access Problem
  230. Dead......maybe not......oh yea, dead
  231. Water in Doors
  232. Wisconsin Crashed Yellow 09 MCS?
  233. Roof problem already!
  234. new mini owner-some insight on auto shifting?
  235. Odd Turbo Sounds
  236. Stuck in Reverse
  237. Thermostat replacement
  238. Strange Coolant Leak...
  239. > 25K miles and never had Rattle?
  240. Need advise - VIN Mystery...
  241. Fried Turbo
  242. Thought you guys might like this....lol
  243. Black Star Bullet metal/finish question
  244. '09 Mini S, Injector Problem
  245. Warm restart - smell gas
  246. Mini R56 S 2007 error codes
  247. NEED HELP OR OPINIONS
  248. Hit a pothole, throw your headlight aim off...Possible?
  249. FUEL PUMP
  250. Steering wheel lock warning
