PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36
  1. Clubman Speakers
  2. R56 Strange noise after declutch
  3. What Does PUMA Mean?
  4. A BRAND NEW BIG PROBLEM WITH 08 CLUBMAN S
  5. Brand New Mini Cabrio and Need New Transmission
  6. 2007 Cooper standard shift "will NOT start" problem solved - Bulletin
  7. Is my passenger window crazy or me?
  8. Xenon Adjustment--Left to Right
  9. New Dipstick Design
  10. Problem: Xenons Wink @ Me with Malfunction Noises....
  11. Stupid TPMS Issue
  12. Steering fan cover?
  13. Another melting hoodscoop thread...*sigh*
  14. Clubman S Transmission Problem 2008
  15. OEM Armrest Draws Blood
  16. Weird Electronic Issue
  17. Somebody (Anybody) Put My Concience at Ease...
  18. What Makes Up For a Lemon?
  19. Another Fuel Gauge Issue
  20. Boot unlock/release while driving?
  21. Weird ticking coming from rear passenger side
  22. parking brake light?! mini on a lift image!?
  23. Check Engine Light.. AGAIN.
  24. Finally, a new transmission after 14 months of complaining
  25. R56 Oil / Service Reset - out of Maint window
  26. SES LIGHT ON OFF HELP
  27. cracked front axle wheel hub nut
  28. Creaking like a haunted house.
  29. 08 MCS knock/rattle from front driver side suspension area
  30. Shift Interlock and Air Scoop Issues
  31. So my Turbo Died.....
  32. How many days has your car spent in the shop?
  33. Car just stopped running!
  34. leaking rear window washer fluid...anyone ?
  35. Wet Passenger floors
  36. Anyone get the "Cat converter Efficiency" CEL resolved permanently?
  37. So has anyone confirmed this yet?
  38. HELP me fix my car.......
  39. Oil residue underneath hood?
  40. Coolant gurgles at 2000 rpm Please help!
  41. Engine Problems / Parts on Backorder (HELP)!
  42. 2008 MCS Honey Moon Cut Short >> Water Leak!
  43. Missing bottom door seal... and fix
  44. Wheel well lining deformation
  45. Paint issue
  46. Has anyone else had this gremlin?
  47. First Service on Mini coming due
  48. Inspection I
  49. Throttle Induction T Fitting Leak
  50. Chrome Bonnet Scoop - wrinkling
  51. Click, click, clack fluttering sound anyone?
  52. Hoodscoop melt after 5k miles... take out CAI and strut?
  53. Window squeaks when raining
  54. How long to give MINI of NA?
  55. No Paint for you
  56. I need roof rack mounting instructions
  57. Does anyone use the Pathway Lighting?
  58. UGH!! YAY!! ehhh hahahaha
  59. Rumor or not
  60. My Dealer uses Extended Warranty thru GE Finance ... Any Experience? Good/Bad?
  61. Question about the Urban/Pinstripe Floormats
  62. Clutch adjustment?
  63. Who trains MINI Parts personnel?
  64. Transmission Problems - Is It True?
  65. Master cylinder needed after routine pad replacement?
  66. Defective Battery Replaced
  67. Boot Opens While I Am Driving?
  68. Has Anyone Returned Their MINI to The Dealership
  69. Parking brake problem
  70. Sharp jolts when decelerating...why?
  71. Concerns/Issues with MY07 MCS
  72. Homelink Problem... HELP!!!
  73. Last Post as MINI owner
  74. Trouble @ 2100 miles.
  75. Clutch Burn-Out & Noise R56 Pre-Mature!
  76. rear wiper screw rusted solid, anybody else?!
  77. HELP!... I think my car is a lemon!
  78. It Feels Like Its Gonna Stall Off The Line w/o Sport Button On
  79. Resetting windows?
  80. Xenon lights not auto-adjusting
  81. Speaker ring deterioration
  82. HELP! trunk won't open
  83. R55 ENGINE MISFIRE ALL CYLS @ IDLE
  84. Check Engine Light - Air Mass Sensor
  85. Can Car Wash Rails Change Camber
  86. Power Steering Failure on Start
  87. Blinkers
  88. Airbag Warning Light Problems
  89. Difficult to Cold Start
  90. Squeaky Door Rubber Seal
  91. Tried to steal my car!!!
  92. Rough start up idle/stall...
  93. Euro Armrest and Phone Cradle?
  94. High pitched whine from engine at idle?
  95. Hot Bonnet & Bonnet Stripes
  96. Armrest adjustment
  97. Loud squeak in left rear when getting out of car
  98. Possible door adjustment?
  99. Clunk Noise From the Rear
  100. thermostat or cooling fan
  101. Stock Ignition coils + No hood Scoop grill = no warranty
  102. Service Engine Light - MINI of Mountainview
  103. Auto up windows quirk.
  104. Engine Not smooth?
  105. Bad Treatment by MINI/BMW & Dealer II - Hassel is a Hassle
  106. Rust on the New Mini Cooper!!
  107. Check engine light (MAP) sensor?
  108. Suspenion Problem - Photo Attached
  109. Heads-Up On The Carpet Floormats
  110. Parking indicator light stays on
  111. Suspension Trouble
  112. High Pitch Whining Noise
  113. Dealer oil change data?
  114. Can someone please measure...
  115. iPod connector issues
  116. Roundabout causes many warning lights. Sound like a fault?
  117. Hazzard light indicator?
  118. Drivetrain Woes
  119. Automatic Transmission Problems - 07 MCS
  120. OEM Dunlop Sport 01 DSST
  121. Don't lose your Comfort Access Key Battery Cover
  122. ELM 327 problems??
  123. What's Been Your Most Expensive Repair?
  124. Knocking Left Front Over Bumps and Sagging Felt
  125. Wiper Blade Replacments.?!?!?
  126. Water Leak 08 Clubman
  127. Engine will shut down in gear
  128. Ugh... Sunroof Gasket Issues
  129. Great Gas Mileage Possible with "Cooper S"
  130. Has anyone had to have their OBC completely replaced?
  131. Air Filter Replacement DIY?
  132. Clunking
  133. Speedometer inop? Check.Fuel gauge not working? Check
  134. Bleeding the R56 cooling system
  135. Some warranty work done on my new '08 MCS
  136. electrical anomaly
  137. Catalytic Converter DOA @ 9800 miles
  138. Loose hatch latch rattle
  139. DANG -- cracked my front parking light
  140. Disappointed with R56 steering.
  141. Official Thread for 2nd Gen Software Updates
  142. Bluetooth Malfunction
  143. Bad Treatment by MINI/BMW & Dealer
  144. Amber gear icon showing... sometimes
  145. Alarm set off by using comfort access button on door handle
  146. Squeeky window.
  147. clutch_noise
  148. LSD questions/testing
  149. Software problem question?
  150. Empy Gas Tank Makes MCS run better?
  151. Humidity & Air Pressure Affecting Cold Start?
  152. Check engine light on 15k miles
  153. Self-closing AC vents
  154. Disabling Door Bong Bong Bong?
  155. Windows...Why Won't You Work?!
  156. Well Water
  157. R56 Auto A/C Issue
  158. Auto up window broken?
  159. Hatch impacting bumper cover
  160. Very poor response on parts order from MiniUSA
  161. Hood Release Problem
  162. Reduced power in hard acceleration or down shifts
  163. the clunker
  164. EXCESSIVE VERY EXCESSIVE TORQUE STEER TO RIGHT
  165. How to Fix intermedate Rear wiper operation....
  166. Rear window washer nozzle??
  167. Lumbar support in sports seat broken?
  168. Valve Stem Cap PROBLEM!
  169. Non-iPOD Aux Input Connection Loose
  170. Window won't roll up.
  171. 2008 MCS passenger's side auto-up window issue
  172. Clunk
  173. run flats
  174. Oil Change Using Mityvac Extractor
  175. Rear Wiper Stopped Mid Stroke
  176. Alignment opinions??
  177. ABS and Braking / Driving warning?
  178. How do I get NAM discount on a part from
  179. Replacing 'C' Column Covers
  180. Pulled speedo needle off, now I'm having trouble keeping it zeroed! Please help!!!
  181. How do you install the hood scoop?
  182. Roof Drain Holes
  183. Coolant problem??
  184. Metal Bracket--What is it?
  185. Hatch will not close/latch
  186. Mirror in the way
  187. Hiccup and A Puff of Smoke Under Acceleration
  188. How to fix sunroof rattle
  189. Hood Grease
  190. Dislocated Shifter Knob
  191. Scottsdale MINI Overfilled My Oil Today
  192. Leaky Clubman 08
  193. Lost Aux Channel
  194. Dash Vibration/Buzz
  195. Oil filter question
  196. Bonnet Does Not Close
  197. Various Noises
  198. OBD Codes - Temp Sensor - Body Repairs
  199. Funny Light Above My Big Dial !
  200. Yellow CEL: Increased Emissions
  201. Tire Pressure Monitor - Help!?
  202. Peeling Stripes
  203. Oxygen Sensor Bad
  204. Fuel gauge doing the wierdest thing
  205. Request - please help
  206. 23,669 service
  207. 3 Electrical Gremlins Popped up at ONCE!
  208. Do ALL new cars have these problems???
  209. Who sells parts from wrecked minis?
  210. Sunroof does not open when it's warm out
  211. Missing Chrome line interior parts
  212. p1152 ECU code
  213. Clicking while in idle??
  214. Clicking while in idle
  215. Cold Start Whine
  216. OK, I Am Officially Leaking Oil!
  217. SOUNDS LIKE A BEACH!!
  218. Windshield pitting
  219. Remove and Replace Power Steering Pump
  220. Claiming my hood 'MINI' badge under warranty
  221. Horn Blows When Turning Right
  222. Passenger Restraint System Malfunction?
  223. Hood Scoop flew off!
  224. Twisted Strut boots & plastic spacers
  225. car makes loud click when i hit the gas in reverse.
  226. Water Leak!!!
  227. clicking noise in reverse. could it be from washer dropped in engine bay?
  228. Battery dead!
  229. Climate Control Malfunction
  230. Broken Brake Booster on my 07 MCS
  231. If you got a flat, did your run flat tires work for you?
  232. Locking steering wheel
  233. Fog light replacement
  234. Major oil leak
  235. Growling Transmission...
  236. Slight Grinding Feel Under Light Braking
  237. Stalling After Cold Start
  238. Strange Noise From Clutch When Slowing Down
  239. Reverse transmision rattle
  240. Help! W/ Rear License plate light Covers
  241. Wind Noise
  242. R56 service / brake lights etc reset procedure
  243. Tapping/clatter noise
  244. Vibration Through Clutch Pedal
  245. Loaner Cars
  246. Shaking mirrors - has anyone noticed?
  247. Inspection II
  248. Dash crack, creak and tick over bumps
  249. Shift quality degrading?
  250. Condensation in fog light/parking light lenses
