Wiper Blade Replacments.?!?!?
Old Jun 16, 2008 | 07:40 AM
Bhatch's Avatar
Bhatch
I tried to go get wiper blade replacements for my 07 MCS. They are hardened , so now do not work so well and screech. They were great all winter and spring.
BMW/MINI here tells me they no longer sell the replacements blades i need to buy the whole arm and the blade....for 80 bucks!!!!!!!!
i know Canada is a complete price dissociation from the US sometimes..but they said i can not ever get them....Outmotoring sells them.
Can you get them at a US dealer or can you only get the arm?
Also what Size is the PIAA replacement for the rear?
Old Jun 16, 2008 | 11:31 AM
torobud's Avatar
torobud
Dealer replaced mine for free while I was in for waurantee work (less than 6 months old)
Too bad they did - the new ones suck!
Old Jun 16, 2008 | 03:29 PM
Capt_bj's Avatar
Capt_bj
replacement blades
if you've decided to drop the 'oem' blades - which are replaced under pre-pay maintenance.... in my experience you need to swap the blade the first time cuz there isn't a 'refill' that fits the factory blade
there's nothing fancy about the front blades; and replacement from an autopart store is not $$. The mounts are very generic and you can replace the factory blade with PIAA, ANCO, Bosch....you just need 1 18" and 1 19" cuz they are different sizes..left and right size. I used PIAA for a while but find the ANCO I have on now seems to work just as good and last as long. (you do loose the wind deflector if that will keep you up at night)
The rear is a different story however....very unique assembly but some have had luck buying a generic refill and cutting it down to size. I bought the entire blade, but only once since 2002....I don't use it much.
Old Jun 16, 2008 | 03:56 PM
miniclubman's Avatar
miniclubman
I find it hard to believe that MINI does not stock or sell a simple item like replacement blade refills. It's always been a stock BMW item, and also very inexpensive, about $5 a piece on my old BMW wagon. Is it possible your dealer is wrong? I just looked at the MINI wiper arms, and they sure look like a standard setup to me, with a standard rubber insert with the metal ribs and that "squeeze together" clip on one end to keep the blades locked-in.
Old Jun 16, 2008 | 05:02 PM
Bhatch's Avatar
Bhatch
I got the refills today. Turns out they are being discontinued for all BMW/MINI they will only sell new arms and blades together.
So i bought all they dealer had in stock :P
Old Jun 16, 2008 | 05:06 PM
rrcaniglia's Avatar
rrcaniglia
I thought there was some kind of law in the US that mandated a supply of spare parts for ten years. No?
Old Jun 16, 2008 | 06:02 PM
miniclubman
Yes, and Bhatch just bought them all!
Old Jun 16, 2008 | 06:26 PM
mellowmcs's Avatar
mellowmcs
yes, but it doesn't say they have to supply each individual pieces. that is my guess, as bmw has been doing this for the past 2 decades now.
I did find suitable replacement refills at the local auto parts for my bmws. $4.99 with breakaway notches so you can cut to size.
Old Jun 16, 2008 | 06:28 PM
GP0256's Avatar
GP0256
Use an alcohol swab (like a 2 dollar box from a pharmacy) and wipe your blades weekly to keep them conditioned, rubberized and clean and they will last much longer.
Old Jun 17, 2008 | 04:40 PM
r56mini's Avatar
r56mini
I am pretty sure you can do a little modding to make a refill blade to fit on the rear.
Old Jun 17, 2008 | 06:06 PM
rwkeating's Avatar
rwkeating
Alcohol will clean them, but won't it also dry them out?
Old Jun 18, 2008 | 07:16 AM
kenatminimania's Avatar
kenatminimania
Here are some replacements if you can't find it locally.
Ken
Old Jun 18, 2008 | 08:16 AM
Bhatch's Avatar
Bhatch
Ken
That is the whole arm. not just the blade.
Old Jun 18, 2008 | 08:55 AM
kenatminimania
Sorry, I pictured the 'whole arm' a little differently.
k
Old Jun 18, 2008 | 09:49 AM
mellowmcs's Avatar
mellowmcs
I use 303 protectant to clean and refresh the rubber. 303 also sells these little wipes that contain a more concentrated formula for use with wiper blades.
Old Jun 18, 2008 | 10:04 AM
lacning74's Avatar
lacning74
I got tired of my oem blades despite treatment with 303 and the availability of free replacements by the dealer. I replaced my front oem wiper arms/blades with Valeo 900 Ultimates. It's the new flat blade design that other manufacturers have now. $10 each at Amazon.com. Easy to install. Much better than my oem ones even when new. Lasted through the winter and is still streak free and smooth. Only problem with these kind of blades is the coverage of the last few inches of the passenger side window as in the video below.
Old Jun 18, 2008 | 10:20 AM
mellowmcs's Avatar
mellowmcs
I agree. my audi came with those from the factory and they do wipe well. i replaced my friends wiper blades with those on his 323i and he loves them.
Old Aug 18, 2008 | 12:57 AM
Lumberlog's Avatar
Lumberlog
All replacement blades are what you call the "whole arm". I don't know any car parts store where you can buy just the rubber part of the blade anymore and insert it into the blade arm.
I just bought some low profile Tricor blades at Kragen. They cost less than they PIAA, which they don't carry, but they don't look as good. They are supposed to be quiet though and they, well, clean the windshield.
Cheers
Old Aug 18, 2008 | 07:04 AM
pilotart's Avatar
pilotart
Never had much luck with "Whole Arm" replacements.
Advance Auto Parts had just the rubber inserts that you slid into the blade slot of original wiper blade.
Old Aug 18, 2008 | 10:15 AM
djam43's Avatar
djam43
I guess we have a mixup in wiper terminology. There is the WIPER ARM, the WIPER BLADE and the WIPER REFILL.
Doc Pain
Mar 10, 2021 04:50 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
Scm68
Jan 27, 2016 12:33 PM
Samhillrocks
Sep 29, 2015 12:55 PM
Sep 3, 2015 12:24 PM
