R56 Auto A/C Issue
Old May 27, 2008 | 07:56 AM
Wolfshiem's Avatar
Wolfshiem
R56 Auto A/C Issue
This past weekend I was freeway driving when I noticed something unusual. I had started my MINI cold and was about five miles from that when I noticed only hot air circulating through the vents even though I had the auto A/C set at 60 degrees. I fiddled around with the temp, using manual override, A/C on and off, etc., but nothing worked to get a cooler temp or change the vents. Finally, I decided to turn the system completely off and pull over at the next available location to restart the MINI. During the next ten minutes, I tried turning the system back on with no luck, so I again turned it off. Finally, just as I was about pull over, I tried it one more time and it worked.
I drove plenty after that and it never happened again.
Has anyone had this happen? I think it was probably just a computer glitch, but maybe someone else had this happen too and can offer some insight.
Old May 27, 2008 | 09:57 AM
Defcon888's Avatar
Defcon888
It could be the blend motor/flaps. I think it affected some BMWs back then. Not sure about the MINIs.
Old May 27, 2008 | 01:55 PM
Wolfshiem's Avatar
Wolfshiem
Thanks for your input!
It could be that the flaps weren't functioning properly...but the entire time it was happening, it had the feeling of a computer glitch because both the temperature and vent designates wouldn't change--the only thing I could do was adjust fan speed.
Hopefully, it was just a fluke.
Old May 27, 2008 | 04:53 PM
Minidrivr's Avatar
Minidrivr
I had something similar. See this thread.
https://www.northamericanmotoring.co...d.php?t=137023
Mine was slightly different in that I could change the temperature, vent option, and fan speed, however only hot air would come out.
This only happened once and hasn't returned. Also the error code I had in the car's system cleared by itself.
Old May 29, 2008 | 07:56 AM
Wolfshiem's Avatar
Wolfshiem
Hmmm...
I think what happened to you is very similar to my experience. Ultimately, it was probably a simple computer glitch--but here's hoping that it doesn't happen again!
Old May 29, 2008 | 08:04 AM
steveng's Avatar
steveng
Take it back to the dealer. My auto ac has been perfect.
W0TM8
Dec 19, 2019 07:50 AM
Bennyboy
Aug 18, 2015 07:28 AM
damncajun
Aug 17, 2015 08:25 PM
Red Raven
Aug 11, 2015 04:48 AM
