PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36
  1. Airbag deployed, non-starting issue
  2. Rubber door gasket problem
  3. Weird issue: engine power loss
  4. Clutch return spring failure
  5. How to demonstrate Cold Start Chatter for dealer
  6. MINI corporate is blaming God for creating the sun therefore causing sunroof issue
  7. Burning plastic smell
  8. Left headlamp aimed down - loose and bouncing
  9. 09 Cooper S engine is quieter than my 07
  10. Engine revs when stopping
  11. Adjusting rain-sensing wipers?
  12. p0300 codes
  13. Odd engine squeak/squeal
  14. Anybody's MCS getting louder with age? Mine sounds like a diesel truck while driving!
  15. Just saying hi here from Sweden (with a little issue)
  16. Squeek from using clutch
  17. How difficult to remove and replace front wheel arches on the R56/R55?
  18. S-Winder wheel center missing?
  19. Windows opened during the night!?!?!
  20. Broken speedo
  21. Advice appreciated - Rough Idle
  22. Overfilled 1/2 quart engine oil will cause problem?
  23. Price of spark plugs
  24. Bad battery or bad sealer?
  25. Removed the LEFT APRON COVER & the WINDOW GASKET came out
  26. Car will not start
  27. It's finally over
  28. Warranty work.
  29. The heretical oil thread
  30. 1 year of ownership... list of repairs
  31. Running like a clunker
  32. Ticking sound at idle on an R56 MC (non-S)
  33. Tire Pressure Low light keeps turning on for no reason...
  34. MINI is a heavy oil drinker?
  35. Dreaded window gremlin won't stay away
  36. Check Engine Light - communication error?
  37. Excessive wind noise at sunroof/windshield
  38. Punch Leather Seats: Poor wear characteristics
  39. What would it cost to replace engine?
  40. Shattered rear window
  41. Front fog lights have moisture in the lens???
  42. Random stalling out/shutting off when coming to a stop
  43. Dual mass flywheel
  44. How hard to replace rear bumper fascia?
  45. Moisture on drivers side window?
  46. Cooling fan running after shutdown
  47. Spark plugs before 30,000?
  48. Tool kit
  49. Engine noise increasing, smoothness fading away
  50. Remote on FOB
  51. Low pitched whistle sound from engine at idle?
  52. Does shutoff fan run in cold weather?
  53. Windows acting up
  54. Passenger Front wheel
  55. Sun Roof Squeaks?
  56. Rear caliper pistons rotate but dont compress??
  57. The cold start clatter has caused a conundrum in my head
  58. High pressure pump
  59. Help to get radio station names to show
  60. Unpredictable throttle/bucking car
  61. MINI Car Cover Scratches?
  62. Wait time for having MINI Clubman fixed
  63. Shake, Rattle and Roll...
  64. Why I won't buy a MINI - yet
  65. Passenger auto-up
  66. How do you keep the turbo inlet pipe on?
  67. window seal
  68. Remote Stopped Working
  69. Does anyones car engine make noise when it cold?
  70. Washer jets not working
  71. Intermittent "Service Brakes" light
  72. Boost down 6 PSI since dealer repairs
  73. Low beam too low
  74. Wheel rub in hard right turns
  75. Center console backlighting problem
  76. Rear hatch auto open
  77. 1/2 inch of water...
  78. My sunroof has been violated more times than lindsey lohan!
  79. Uneven hood, squeaky brakes, pass side rattle, N to 1st/R howl...
  80. Incremental Fixes?
  81. Driver's Side Window - Help
  82. Burning rubber while sitting still?
  83. Dropped 5mpg this tank!
  84. Drivers window will not open in cold weather
  85. Rust
  86. Window won't roll up.
  87. 2008.5 Montreal MINI problem(s) (a lot of problems)...
  88. Transmission Problems (No one seems to want to fix it)
  89. CEL leads to Fried Engine Computer!!
  90. Headed to court: Me vs. BMW North America
  91. MINI accelerates on its own!
  92. CEL; rough idle
  93. Comfort access weirdness
  94. 2nd gen MINI reliability vs. other makes
  95. Horn Goes Off Randomly
  96. Brake and Clutch bleeding
  97. Acceleration hesitation/stall on left turn
  98. Punch-Black leather peeling issue
  99. Snowflake in a Triangle
  100. Wierd smell...
  101. Rattle behind Speedo?
  102. Cold Engine Start
  103. Bent Axel
  104. Corrosion Warranty Cut In Half?
  105. Mushrooming
  106. Am I in limp mode?
  107. CC - ID 029
  108. Stuck power folding mirrors
  109. 09 seat headrest issues / angle
  110. Just need to vent
  111. Problem with Tach when cold?
  112. Lost Ecu Screws
  113. Windows rolling down on their own(???)
  114. chirping sound like v-belt (but not sure)
  115. Excessive carbon build-up in engine
  116. Return of the Cold Weather Check Engine light
  117. Cold start misfire
  118. Right Door Panel Water Leakage
  119. door latch color different than rest of car.
  120. Posted on Front Page of NHTSA Site!!!!
  121. Clutch Issue-Honking-Howling Noise during Downshift
  122. Auto A/C always hot??
  123. Driver side window problem...
  124. Having Problems with TPMS
  125. Warning indicator light help
  126. Incorrect Diagnosis by Service Technician
  127. Will one TPM valve on the car satisfy the monitor?
  128. Drivers Side Wind Noise coming from Mirror!
  129. Lights for Heater/AC controls
  130. Increased Emissions
  131. "Thunk" Noise
  132. coolant low
  133. Heat shield mats for the hood.
  134. R56 stalling on startup.
  135. MINI not run for a month
  136. Service light - State required emissions inspection
  137. Ticking time bomb noise
  138. MINI customer support - should I buy?
  139. Brand new 2009 MCS with problems already!
  140. Front fog light full of water.
  141. Resetting Tire Pressure Monitor
  142. Speedo, Tach and Computer Dead
  143. Idle Vibration/Coolant Leak...
  144. Service when not near a dealer
  145. Drivers door window dipper
  146. whelping noise from ft axle area low speed?
  147. I'm starting to think these cars are pieces of crap
  148. steering wheel leather cracking.
  149. My MCS hasn't logo on the engine
  150. MINI USA is buying back my 2008 MCS!!
  151. High RPM power loss.
  152. NEED ADVICE!!! My brand new MINI gets in trouble
  153. We can start a class action suit!!
  154. ...Need Cylinder Head
  155. SES Light and Diagnostic Code 1477
  156. Engine is making weird sound...im sick of this
  157. 2009 tail light wanted - where to buy?
  158. Airbag reliability?
  159. helicoil tang removal help
  160. tachometer display
  161. No help from MINI USA so now filing for Florida Lemon Law
  162. Fuel gauge
  163. 2009 MCS clutch replacement
  164. Auto Trans downshifting at odd times
  165. 2008 MC Heater Problem
  166. Help! New tire vibration!
  167. About Your 2nd Gen MINI Videos
  168. Changing License Plate Bulbs
  169. Service Indicator at Startup
  170. aux and cigarette lighter jack not working
  171. Help, windows down and car unlocked...
  172. Cold start issue, what's the status?
  173. OBC (on-board computer) Activation R56
  174. Exhaust smoke, burning smell
  175. Exhaust smoke, burning smell
  176. Coolant discolored
  177. Clubman steering failing
  178. Not all MINIs are problematic
  179. Excessive wind noise from closed sunroof
  180. Intermittent Blue Line In Navigation Screen
  181. My 2007 Cooper S Needs a New Engine!!!
  182. Throttle by wire
  183. Gages and lights going berzerk
  184. Tailpipe recall
  185. Dealer swapped out my stock hood scoop for JCW scoop (plus cash)
  186. How can I tell if I have a metal or rubber valve stem?
  187. I've Blown A Fuse
  188. FYI: 2009 MCS automatic transmission
  189. Engine noise amplifier.
  190. My MINI woes....
  191. Clubman S '08 shut down noise
  192. Clubman Rear Door Latch Clicking Open After a Wash???
  193. Tire Noise
  194. Help! 12 Volt / Cig Light. Center Cons. Not working!
  195. Sun roof gasket problem.
  196. CEL after AGS-R Install
  197. Leaking windshield??
  198. THANKS NAMily!!!
  199. Loss of 3-click and broken keys
  200. Make sure your shipping spacers are removed!
  201. Buzzing sound by driver's ear
  202. Engine "stutter"
  203. Pulsating Hum at 3k to 3.2k rpm
  204. Heated Seats Turning Off... Anyone else?
  205. TROUBLE WITH HESITATION
  206. Just when I thought I found one.
  207. Spontaneous opening of doors and sunroof
  208. Cold Blooded?
  209. Key Fobs Not Working
  210. Buuuuzzzz. Buzzzzzz. Click. click
  211. Catalytic Converter
  212. Clicking/Creaking From a Stop
  213. Brake Groaning Noise When Depressed
  214. 2nd generation MCS overall reliability?
  215. About to order 09 MCS, better to wait a few months?
  216. Another Melting Hood Scoop Story...
  217. Fan Rattle/Tapping Noise
  218. Rubbing Tire sound >50 mph
  219. Door trim lifting off
  220. Left Rear Camber Changes
  221. Mini door lock actuator
  222. Possible cure for melting hood scoop!!!
  223. Low oil sets off engine light not oil light?
  224. Water Pump... brand new after 2 week ...on a 08 mini (non-s)
  225. Wind shield wiper noise
  226. My Nightmare is finally over (for now)
  227. Update on sunroof not opening when hot...
  228. REar wiper: on but won't wokr after car shut off
  229. Car starts, then dies immediately
  230. Airbag Light
  231. Fun with Tire Pressure
  232. Knocking / Thumping Sound From Back...
  233. headlight woes
  234. Rattles
  235. Scraping bottom...what's this????
  236. oil changes by dealer
  237. R56 MC rattle under the dash -- I see it, but now what?
  238. Yellow "half engine" light came on and..
  239. Overheating Help
  240. Has anyone had melting lubricant 08 MCS
  241. Poletergeist Got My MINI Clubman--wild windows abound
  242. Oil filters for 08 r56
  243. Paint on fuel door??
  244. little fan under car making noise..
  245. These wiper blades SUCK!
  246. Paint Blemish On Door...What To Do?
  247. Seat Belt Warning Chime Problem
  248. Engine Whine Between 1800 2500 RPM
  249. One touch up windows started when?
  250. Mini Service in Texas
