PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Stereo on but no sound , and no " gong " ?
  2. CEL came out yesterday with 2 error codes
  3. Carbon build up @ 13000 miles
  4. Need some help reading a code (2B53) for long term issues.
  5. Unspecified maintenance due?
  6. Clutch or trans issue, not sure need advice
  7. Transmission making light overlapping clunking noise while in idle and...
  8. Occillating Fan
  9. Purchased Scan Tool (Innova 3040a) to erase Check Engine Light but did not work
  10. New engine fJCW
  11. Whats left that can fail on my car???
  12. Mist on the turbo pipes
  13. Doors Locking Themselves
  14. 2011 Mini Cooper S suspension knocking noise in COLD weather
  15. Won't run in the cold
  16. Coolant Temperature Sensor
  17. Help !?! Cooper auto won't drive , rolls in park , steering doesn't lock
  18. Reacemwnt parts
  19. P0171 lean bank 1
  20. timing chain tensioner part number wierdness
  21. N18 Timing Chain Tensioner Replacement
  22. Low power, no lights or codes
  23. R56 with N18 motor - passenger side Oil leak
  24. Well, this seems a very serious problem...
  25. 2012 Lower Tail Lights Dead After Plugging In
  26. SoCal (OC) shops oil leak help
  27. Help Me ID this Clutch Related Noise
  28. Anyone out there no how to remove airbag light from new seat, please help
  29. Codes 300-301-303
  30. Flapping diaphragm vibrating tin like sound starting at 1800 rpm's?
  31. p0012 and oil leak?
  32. Air bag light
  33. Slow to warm up issue
  34. Fix for carboned up valves?
  35. Does new timing chain assy fix the problem long term?
  36. 2010 MCS CEL P0302, then p0300/p0304/p0303
  37. Major Oil Leak While Running
  38. Reading CEL Codes?
  39. odd oil pan bolt
  40. Vague clutch pedal feel
  41. Vacuum leak..probably
  42. 2007 S fault code 272a
  43. Radio problems
  44. Awkward Jerk Only at a Steady Speed ??
  45. 2009 Mini Cooper s transmission problems
  46. Bumper repair
  47. 2009 Mini Cooper Base is getting no electrical power to the engine. Please help
  48. clubman glovebox removal
  49. Moaning/groaning noise over 30mph
  50. Torque settings cylinder head
  51. Transmition problems
  52. Head Removal Questions please Help
  53. Oil overfill? Do I bug the SA about this?
  54. R55 CEL, No power, 2B64 & 2ACD
  55. p0301 & p1497 please help
  56. Are all Mini cars ****?
  57. Siezed Lug Nuts = New Rims?
  58. Engine Temperature
  59. Engine Light, No Code
  60. R56 new problems after thermostat housing change
  61. coolant expansion tank rises when engine's cold, falls when its hot
  62. Metallic Grinding Noise on Accel/Deceleration
  63. P2785/p2187 and 2F07
  64. Service_light_brake_light
  65. CEL P2188 - Caused By Software?
  66. Brake Rotor and Sensor Part #'s
  67. 07 Cooper S What TPMS System do I have?
  68. Coolant leak help
  69. 2418 & 1447 codes
  70. Replacing coolant/water pipe
  71. Body Control Module or ?
  72. Exposed rad hose?
  73. Mother F$(&ing code P115C
  74. Replacing valve cover. Red key?
  75. tailpipe smoking
  76. 2010 Non-Turbo with P0012 error code
  77. Strange clutch issue
  78. What would you do? Indy shop
  79. replace valve cover when pcv is clogged
  80. Boiling expansion tank?
  81. Oil leak between heat shield and block
  82. R56 '09 S only 128hp at dyno???
  83. New Jack Block style
  84. First post
  85. headlight female connector burnt
  86. Has anyone seen a new service bulletin SI M11 04 13?
  87. Mini R56 cranks but won't start
  88. My tranny "forgot"
  89. Check Engine Light - Misfire
  90. Multiple pinging/knocks on WOT occasionally???
  91. radiator fan not coming on r56s
  92. Noise like sucking a straw at the bottom of a soda coming from clutch pedal...
  93. Passenger Side Window Doesn't "Nudge Up" after Low Battery
  94. Recall Notice: Turbo Heat Shield (Oil Feed Line)
  95. Anybody ordered from MINICOOPERPARTSGIANT.COM?
  96. R56 with 130 K
  97. front pad not bedding in yet
  98. Car Shakes When Starting In First
  99. Many problem after alignment?
  100. Catch can or baffle?
  101. Oil leak.. what could it be?
  102. Leak down test requested but Pressure test done
  103. Water Pump Issue
  104. Passenger side Oil Leak
  105. Turn Signal Malfunction
  106. Replacing Pressure Converter/ "Kazoo" Sound Fix
  107. 2009 clubman sounds like a truck
  108. 2013 R56 wiper fix
  109. Clutch Transmission Chatter/Squeak/Whistle/Noise...
  110. Tire Pressure Warning
  111. Low speed Fan
  112. Front end steering/suspension clunk
  113. DIY: Replacing the sunroof seals
  114. Got flat tire today, but no warning lights indicating a flat?
  115. Triple turn signal activation not working
  116. Exhaust manifold oil leaking possibly and few others problems
  117. 08 r56 Limp Mode on/off??
  118. Strange clutch issue - looking for help
  119. Oil leak, what is this?
  120. Roof Rack Key Question
  121. trunk-boot Rubber exterior button cover.thing.
  122. 07 MC starts then immediately dies
  123. Random "spark" noise under bonnet
  124. I think I need a second water pump - Cooper S
  125. Metal rattling from suspension/undercarriage
  126. Chicagoland MINI Cooper Walnut Blasting: A-Spec Tuning
  127. sunroof won't open
  128. Misfire Code .. Disappeared?
  129. 2009 MCS Idle Rattle & Shut Off Noise (with Video)
  130. No cold air from a/c
  131. Is My Turbo Failing??
  132. 07 "S" with P115c Code
  133. Timing Chain Issue? Opinions appreciated.
  134. Windshield washer only squirts small amount
  135. R56 burned/broken exhaust valve - need to set cam timing
  136. Abusrd oil use; half a quart in < 200 miles
  137. Unkown mist on discharge pipe
  138. R57 Radio-show song title/artist always
  139. Clicking noise when reversing.
  140. Charging problem
  141. Weird Noise In Cabin
  142. Sunroof Seal Question
  143. Paint question?
  144. head light wiring.....
  145. Mini Cooper S squeaking problem?
  146. Parking Brake Question
  147. Radio / Computer Controls Freeze
  148. 2013 with Slight Hesitation / Loss of Power
  149. Engine Coolant Hose Failure - New Engine
  150. Coolant leak under HPFP/vacuum pump?
  151. Window problem
  152. Engine Malfunction Fault : Help Decoding Codes
  153. Radio screen goes blank
  154. R56 Engine Malfunction Fault: Help Decoding Codes
  155. clock spring lroblems
  156. Airbag light on dash 93d7 error and c241
  157. Mini Cooper Justa misfires
  158. R56 misfiring, codes P0300 and P0304
  159. Sea Foam problem
  160. MINI has issued campaign/recall to replace timing chains!
  161. When did you have to replace your battery?
  162. misfire on #2 plugs and coils ok
  163. Quick buzz on shut down
  164. Left front turn signals don't blink, stays on indefinitely throughout the night?
  165. '08 R55 "Clunk" in front end
  166. Noise from transmission while maintaining speed.
  167. Turn Signals/Indicators Blink Fast - All Working - Bulb Out Warning Light
  168. Turn Signal/Indicators Blink Fast - All Working - Bulb Out Warning Light
  169. head gasket or...
  170. p2884? charging pressure max.. PLEASE HELP!
  171. Houston or Austin Mechanic Recommendations
  172. Sunroof Excessive Wind Noise
  173. TPMS Light - DSC Undervoltage
  174. Considering GETRAG 2010 Auto Tran
  175. Time to let it go...
  176. AC Problems with Mini cooper 2007 hissing noise
  177. Rear hatch just keeps opening
  178. Sticking Throttle
  179. 1 Qt. Oil/1000 Miles: PCV System?
  180. Dipstick not seating all the way in. Chain guide issue?
  181. Fan issue????
  182. Oil collected bottom of intake hose
  183. Question on Gen 2 Auto Trans maintainability and reliability
  184. Did I put in too much fluid? Headlamp lights won't raise
  185. Another CC-ID-029 problem... HELP
  186. 2010 cooper s window trouble
  187. engine ticking noise at idle
  188. Stuck in reverse... R56s mt
  189. R56 Won't start, died on road
  190. 2005 mini- key wont unlock/battery dead how to replace
  191. Why the heck would this happen ?!?!
  192. My MINI experience - Not so good
  193. who had the HPFP replaced?
  194. A Lemon???
  195. Error P0444 After Carbon Build Up Cleaning
  196. Scratched Paint - help!
  197. Current fuel consumption - random numbers
  198. Water Pump
  199. Clicking from front drivers side and clutch
  200. 2011 electrical malfunction light
  201. bad oil leak - automatic cooper S 09!
  202. Water In Gas?
  203. Alaska Mini
  204. Cruise Control Speed Setting
  205. 09 mc base speedometer issue
  206. P2187 error, what is it?
  207. pcv gas leak: engine cover or seal?
  208. Turbo Noise
  209. Check Engine Light - P15DF and Misfire on Cylinder 2
  210. Loud 'clank' noise from drivetrain when accelerating.
  211. Timing chain? Need advice please
  212. Battery issue? Need advice!
  213. 09 ECU Replacement?
  214. awkward noises
  215. Steering wheel squeak
  216. The case of the melting tail lights...
  217. Help - Project '08 MCS
  218. leaky turbo line alternatives?
  219. Yellow engine light in the speedo cluster
  220. 07 S Idle and stall problems
  221. Vacuum OBDII Questions N14 vs N18
  222. hit the $20000 mark in repairs with 90000 miles
  223. Coolant leak/burning smell
  224. Front End Service Mode Tools
  225. chain timing problem.
  226. R56 fJCW woes
  227. Help please! Dropped something into the engine!
  228. Should I replace the tranny fluid?
  229. air leak somewhere
  230. 2013 MCS check engine light at 4100 miles.
  231. Leaking mainseal
  232. Ok, so i had no idea.. Windows down with remote..
  233. N18 Engine - How are they holding up?
  234. Sounds like timing chain rattle, but apparently is not...
  235. Timing chain rattle?
  236. Aircon issues
  237. Thermostat Questions
  238. 2004 Mini has #1 cylinder misfire
  239. Who's changed the m.a.p. sensors?
  240. Engine starts but all warning lights remain on and wipers run on their own
  241. OEM Glovebox Organizer
  242. Engine Rev at idle
  243. Thermostat issue...maybe
  244. Question on Stock Airbox
  245. what goes here
  246. Entire Sunroof Replacement?
  247. A/C not cold on passenger side
  248. Dealer can't get wheel locks off!
  249. Oil leak
  250. Frustrated: Exterior bulb warning
