leaky turbo line alternatives?
I have leaky turbo in line. Unfortunately I dont have the time or the money at the moment to fix it. All the forums I have been reading say just to replace it but is there a reason why no ones patched with like a cold weld or rtv or something; is that even possible?
The source of the leaks in the lines are failing rubber o-rings inside the coupling. I'm not even sure how one would go about trying to fix that. Considering replacement lines run between $50 and $100, most folks probably see it as cheaper to replace rather than repair.
Just to save an attempt and time, but do you know an approximate pressure. J&b cold weld has pressure up to 3960 PSI.
Do you know what happens when a fragment breaks off and gets lodged inside the bearing at 100,000 rpm?
I've seen my fair share of JB Weld hacks.. I've also seen people ruin things because they thought it could fix everything.
Fair enough. I just wanted to explore all my options first.
Scratching my head on this. Are you referring to the Oil lines on you turbo? Or the coolant lines? or neither?
You don't say in your post. I think that is what you meant but you left out what type of line.
Replacing the lines isn't too difficult and they are relatively inexpensive.
Now if you pay a dealer to do it then it is quite a bit more.
Colt45Magnus
Aug 27, 2024 05:03 AM
molala
Oct 2, 2015 01:53 PM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
