Vague clutch pedal feel
Recently had a clutch job on my 2009 Clubman (everything changed out at an authorized dealer, flywheel pressure plate, friction plate, etc...with OEM kit). Now there is a strange issue with the clutch. The bite point is very vague and the feel of the clutch pedal is not right.
Hard to describe, but there is no "feel" to the pedal, so it's hard to know when I'm at the bite point. But the clutch holds firm. Absolutely not slipping. No strange clutch noises, can change gears no problem.
However, if I drop the car into first from a higher gear, there is no jerking as one would usually expect. Instead the clutch just engages with a smooth motion.
The lack of pedal feel makes it rather hard to drive the car and I've stalled it a few times already. It might be my imagination, but sometimes the pedal feels a tiny bit better when cold and is generally worse when the weather or engine is warm.
Have never come across such strangeness before. Help/advice would be highly appreciated.
think it could be air in the lines? If it were the pressure plate or disk, wouldn't it slip?
wildwestrider
Dec 27, 2015 08:20 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
wildwestrider
Sep 4, 2015 06:25 AM
