Windshield washer only squirts small amount
Old Sep 16, 2013 | 09:17 PM
Like-A-Go-Kart's Avatar
Like-A-Go-Kart
I have an '07 Cooper S, and the windshield washer doesn't squirt a whole lot of fluid onto the glass. This started on my first cold weather trip, so originally I thought the fluid froze in the line, but the issue has continued ever since (even in warm Southern California).
I have not found any leaks, and the reservoir has plenty of fluid. Where is the washer pump located, and can it be seen/inspected without taking half the car apart?
Old Sep 29, 2013 | 05:29 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Could be there is detailing wax buildup in the washer nozzles.
Use a fine sewing needle and see if clearing them out helps...
Old Sep 29, 2013 | 06:29 AM
ZippyNH's Avatar
ZippyNH
You could re-name your car little-squirt!!!
Lol. I'd bet 5$ there might be wax or a piece of junk in the nozele....a needle to try to poke it out is a great first step in trouble shooting....then look at the hoses on the back side of the hood...look for kinks....heck even unplug the sprayer and check for volume/leake /psi....
All else fails...you are down to a new pump....
Pretty simple diy stuff to look at/check! Good luck!
R3411y
Nov 23, 2015 01:10 PM
Hobine
Oct 7, 2015 04:52 PM
MiniChick82
Sep 16, 2015 02:56 PM
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
