Turbo Noise
Old Aug 7, 2013 | 11:54 AM
an02rew's Avatar
an02rew
Turbo Noise
Hi folks,
Over the past few days i've noticed an increase in noise when my turbo kicks in.
The car is a bog standard fjcw with 25k on the clock, it almost sounds like it sucking in air, check for loose pipes but cant find anything.
Had the car for about 5-6 months now but its never been this loud when the turbo kicks in, its like a whining noise as if i had an aftermarket induction fitted which i dont, really opens up for having a standard intake. Almost like a creaking/griding noise.
No real loss of power. Plenty oil.
Any Ideas? :/
Old Aug 8, 2013 | 07:37 AM
an02rew's Avatar
an02rew
Bumping it up there :/ Anyone?
Picking up anti roll bar bushes from the dealer tomorrow so the service manager is going to have a quick look at it while I'm there.
Will let you know how it goes, any ideas before I go appreciated so I don't look like a complete n00b
Old Aug 8, 2013 | 09:08 AM
countryboyshane's Avatar
countryboyshane
Take the turbo compressor outlet and inlet tube off and look for metal shavings. Pray for none.
Old Aug 8, 2013 | 11:15 AM
05r50's Avatar
05r50
+1 on CountryBoy.
If it sounds like an air leak then you need to follow the path. Check the inlet tube from the airbox to the turbo. Just cause it is connected it doesn't have to be sealed.
Check from the turbo outlet down behind the radiator. It will have a connection to the intercooler muffler and then from the muffler to the intercooler.
Coming from the passenger side of the intercooler it comes up behind the radiator and connects to a hard tube that runs under the metal rail in the engine compartment from front to back.
After that, the hard tube connects to a elbow that goes down behind the motor and under the airbox to the intake.
Old Aug 8, 2013 | 08:08 PM
SD4US's Avatar
SD4US
Sounds like it could be the friction wheel of the belt tensioner, see SI M 11 03 09:
This Service Information bulletin supersedes SI M11 03 09 dated December 2009.
SUBJECT
Whistling Noise from the Water Pump Area
MODEL
R55, R56, R57 produced up to June 2009
SITUATION
A whistling or squealing noise is heard from the engine at idle and/or at higher engine speeds.
CAUSE
1. Noise is caused by the water pump.
2. Noise is caused by the friction wheel of the belt tensioner.
PROCEDURE
1. Run the engine up to the operating temperature. Confirm that the noise is coming from the area around the water pump during engine idle speed.
2. Increase the engine speed up to 1,000 rpm.
3. If a noise disappears at 1,000 rpm or higher, replace the water pump. Refer to Repair Instruction RA11 51 00, found in MINI TIS.
4. If a noise is still present at 1,000 rpm or higher, replace the friction wheel of the belt tensioner with the improved part, P/N 11 28 7 571 833. Refer to Repair Instruction RA11 28 035.
Old Aug 8, 2013 | 09:49 PM
Jandreu's Avatar
Jandreu
Originally Posted by an02rew
Hi folks,
Any Ideas? :/
What year is your mini?
Old Aug 9, 2013 | 04:30 AM
an02rew's Avatar
an02rew
Thanks for the info so far guys, going to BMW this afternoon so hopefully find something. It's a 2009 model,
So far its had a decoke, tensioner replaced and cam timing reset in the last 2 months.
Not fun :/
I'm thinking this issue is unrelated?
Old Aug 10, 2013 | 06:17 AM
SD4US's Avatar
SD4US
So what did the noise turn out to be / any fix offered by BMW?
Old Aug 10, 2013 | 06:26 AM
<05MINI>'s Avatar
<05MINI>
Originally Posted by sd4us
so what did the noise turn out to be / any fix offered by bmw?
+1
Old Aug 14, 2013 | 07:46 AM
SD4US's Avatar
SD4US
an02rew, please post an update so we can all learn from your experience!
They sure must have figured out something by now...
Thanks.
Old Dec 9, 2013 | 12:37 PM
an02rew's Avatar
an02rew
was just me being paranoid in the end, nothing else to report
lweaver
Sep 17, 2024 08:22 AM
Colt45Magnus
Aug 27, 2024 05:03 AM
Supertractor3
Apr 7, 2017 11:16 AM
Sailorlite
Sep 4, 2015 07:03 PM
Sep 3, 2015 01:45 PM
