Has anyone seen a new service bulletin SI M11 04 13?
Old Oct 23, 2013 | 02:33 PM
mbaisley's Avatar
mbaisley
I can't find it online. Any info would be appreciated.
Old Oct 23, 2013 | 09:02 PM
Gubi's Avatar
Gubi
Here's a few details. Really wish BMW/Mini would make these publicly accessible like nearly every other manufacturer, though.
https://www.northamericanmotoring.co...1-01-13-a.html
Old Oct 23, 2013 | 10:58 PM
3lusive's Avatar
3lusive
Actually this is not the same SIB I almost posted this one after doing a quick google search of the number, but the one in that thread is SI M11 01 13 and not SI M11 04 13...small difference but it makes me think this is a new one.
Old Oct 31, 2013 | 03:20 PM
sgscomps's Avatar
sgscomps
situation
The timing chain tensioner applies pre-tension to the timing chain guide rail mechanism. In some cases, the tensioner spring force may be too low. Depending on the severity of the wear, it may lead to a rattling noise when starting the engine cold or when the engine is idling.
cause
The timing chain tensioner internal tolerances are not consistent.
affected vehicles
This Service Action affects certain MINI models equipped with the N14 engine, produced from 11/2006 to 5/2009.
In order to determine whether a specific vehicle has had this Service Action completed or is affected by this Service Action, first check the B-pillar label for code number 61. If code number 61 has been punched out, the campaign has already been performed. If code number 61 has not been punched out, it will be necessary to utilize the "Service Menu" of DCSnet (Dealer Communication System) or the Key Reader. Based on the response of the system, either proceed with the corrective action or take no further action.
  1. The timing chain tensioner will need to be inspected before removal. The timing chain tensioner is visible from above, inside the engine compartment, between the intake tube and air filter housing. One of the following timing chain tensioners may be installed. Do not remove the timing chain tensioner for the inspection.
  2. If the engine is fitted with a timing chain tensioner that has a drilled head (item 2) or has a machined head (item 3), do not replace the timing chain tensioner. No further repairs are needed. If the chain tensioner has a flat head, proceed to step 3, replace tensioner.
Old Nov 5, 2013 | 01:01 PM
ghiocs's Avatar
ghiocs
Originally Posted by sgscomps
situation
cause
Do you have the full TSB in a PDF?
Sep 10, 2015 03:36 PM
Sep 10, 2015 10:52 AM
Sep 8, 2015 11:37 AM
Sep 4, 2015 08:25 AM
Sep 3, 2015 02:06 PM
