View Full Version : Stock Problems/Issues
- Cold start rattle quick remedy.
- HPFP?
- Clunk in front end-looked everywhere
- Starting issue – Not the rattle
- My turn
- half power light on.
- Wipers with Rain Sensor Stop Wiping
- 2010 gremlins? Boot rattle, frozen door locks?
- Flatbed Sandwich - Car Dies
- any suggestions?
- Getting New Engine in my 07 Mini - Crazy!
- "can't continue journey" true/false and if false, how long?
- Mono-chromatic mirror gone bad!?!
- Sunroof wind noise. Any actual fix?
- Warranty help
- Sirius Receiver Help Please!!!
- 09 Clubman Transmission Problems
- Car going into ds mode while driving?
- Battery Light on - After Tranny replace
- Steering going out!!!
- Air Conditioner Bracket Broke on JCW R56
- Yellow Car on Lift signal popped up. Any ideas?
- Reading and Sun Visor lamps not working
- squeak/clicking in clutch 2009 MCS
- Question for Just-a-Cooper Owners Only
- Strange sucking sound during revving of engine
- ipod connector covered
- New Mini owner and a few questions/problems?
- 7600K. Shrieking noise. New Flywheel!
- Can I get from the radio to some ear plugs?
- Burning oil smell?
- Buzzing noise from engine causes battery to die.
- weird window - driver side won't stay closed
- Flying Scuttle
- Help. CEL again.... with dealer diagnostic screenshot
- headlight alignment help!!
- View from the cheap seats
- Excessive Battery Discharge?
- Odd engine sound
- Clear Bra Issues
- Bad Gas - Dirty Fuel System Issue
- Engine light came on!
- Need info. on Head gasket change
- CEL 2845
- Any Ideas On the Problem
- Low Compression in one cylinder
- noise at 3k rpm...
- Need Help, Driving Lights
- Personal Profile Help
- MCS automatic engine revs up when coming to a stop
- R55 S clunking with jcw brembo brakes
- List the problems you have had with your Mini.
- Did I just make things worse?
- 2007 MCS power loss after 3500rpm
- 2007 Base Mini w/ tranny GRIND!!! :-(
- Squeeky brakes are driving me crazy! Need advice
- Loud Clutch Squeling noise on my 09 R56. Help.
- Odd noise/Question
- Auto Shifting Problem
- rear knocking sound video: any guesses?
- yellow engine light indicator
- Steering Issues
- Cylinder 3 Misfire
- brake light on, abs and service light flicker.....
- Stop the DING!ing (not the usual topic)
- What is this noise?
- Are these repairs normal?
- R56 Front Driving Light - Replacement How To?
- Engine problems --> Not use top tier gas
- Control Module
- Looking for a service bulletin
- Seat belt in a twist
- Sunroof shade keeps opening!!
- Has MINI fixed any of these issues?
- Intermittent Wipers
- help with passenger seat belt alarm
- CEL "increased emissions" and mystery chime problem
- ticking noise @ idle
- Idle...anyone else?
- Aircon Problem
- Break in or not?
- Anyone had trouble with their seat being hard to move?
- Headlight Warning......reset?
- Front bumper
- Check engine light
- CD Keeps Popping Out of Player
- im going crazy
- Video of timing chain clatter....
- Turbo Sound Boost?
- Camshaft/Valvetrain Noise
- HPFP,CEL,Clutchs problem.
- Vacuum Pump Location
- Liquid on the ground
- Scratched glass from wipers, covered by warranty?
- Gear Shift Indicator Light
- Timing chain rattle cured or not?
- How to fix squeaky roof?
- Yellow CEL and Alta Air Intake
- 11k miles and 16qts of oil later...
- Coolant level seems to be lower often
- brake pedal makes knocking noise in park only-auto trans.
- Changed the fuel filter, and now no start?
- MINI shocks longevity?
- Don't despair, it could be worse....
- Popping sound from rear
- OBDII Reader will not Link to 08 Mini
- After Spraying Washer Fluid - No wipe
- 2010 mini, Knocking noise from boot?
- Fraying seatbelt... anyone else??
- clutch grinding noise
- Rattles from Panaromic Roof
- Metallic scraping/rattling noise?
- sunroof adjustment?
- Sulfur smell...
- need help with intermittant horn working
- really quick question, suspension squeak, WD-40 safe for components down there?
- Random Stalling
- Camshaft Noise "Not Death Rattle"
- Help Identify R56/R57 Engine Part
- Boot hard to open using latch
- Noise when depress clutch
- Clutch Warranty Help
- R56 cold start zip pull noise?
- Is my CD player broken?
- Problem with my mini
- Potholes and alignment question
- Melting Hood Scoop Finally Solved
- Engine Rattle at Shutdown
- Autolock feature turned off? another other things..
- Door unlocking issue
- Cracked Thermostat Housing
- Don't do this!
- Cracked turbo inlet hose
- Inner fender liners scrubbing? Anyone?
- Navigator playing up
- First Problem - Service Visit
- Stock radio won't stay in AUX setting
- Chrome trim broke off key, warranty?
- My Mini SMELLS!
- ANNOYING rattle from hatch
- Front brake pads and rotors replaced 19,000 miles
- DETERMINED
- 2nd High Pressure fuel pump replaced - 1 week?
- Audio Tuner disappears
- Turbo water pump failed
- Dealer Warranty Work = Car running like ass
- My new MINI is junk: yet ANOTHER problem, now with the steering.
- Tapping noise in rear
- Noise Question!
- rattle sound with video.
- what is this steering noise i'm experiencing?
- REAR WASH WIPE
- MINI Engine Rattling Humming Loudly- New Part
- Clutch/engining clicking noise
- Passenger Side Window is SLOW..
- Clutch Squeak
- Blue smoke upon startup?
- a British thing or what?
- Multiple ticks on acceleration (sounds like a metronome)
- "Death Rattle"
- Engine Malfunction Light = Turbo, not covered under Warranty
- hatchback rattle
- Reduced Engine Power When Full Throttle
- 08 Cooper S cold start engine light and reving
- Radio: what is the AUX connection used for?
- Does your A/C make a loud whirring noise when it starts up?
- Smoke inside cabin upon starup
- Engine Malfunction Indicator
- 8k on front stock run flats and almost bald!?!?
- Grinding sound when braking
- Clutch rattle? Throw out bearing? Flywheel?
- Power steering going out?
- Dying battery?
- Engine won't start after fueling?? HELP?
- Door rattles found
- Yellow check engine light and below zero temps
- Why are Mini Coopers still junk?
- Rear Seat Removal?
- Clutch issue that doesn't match the others.
- Clutch Pedal
- I am hearing a rattle in my heater.....
- Sound of water in the dash, and stiff doors
- URGENT! Check your seatbelt fastener!
- 2007 Mini Cooper S startup issue
- Rattles Galor
- Does Anyone Know how to Reset the Pinch Protection Feature in 2009 Mini Cooper S
- 09 justa cooper stops on freeway..brand new!!
- Rubbing noise after car sat for 5 days
- 07 cooper rear end clunking
- 09 Oil Consumption
- Mini Engine Light on w/ 5k miles?
- Pop pop poppin' off shifter...
- When slowing for a stop....
- Broken or Design Flaw?
- Need insight...
- R56 Diagnotic Code P0012 - Cam Shaft Position Actuator
- random water temperature increase in traffic
- Clutch Issues........Smells like burnt rubber!
- TERRIBLE SMELL..........Clutch?
- Intermittent bulb out?
- engine wrning light...brrrrrrrr...safe to drive?
- My MINI in the cold.
- High pressure fuel pump/injector reliability
- 2010 Recall?
- Run Flat Tires: Second Question
- ClubBeast is Dead
- Leaking Water Pump
- 2010 Mini backup problem
- Passenger door will not open from inside
- Dreyer & Reinbold
- 17" Run Flat Tires
- Dealer advise needed
- Window Problem/ No suction
- Cold start in ALASKA
- power steering fan on R56?
- Bad Brake Master?
- Gas light on even though tank is full
- 2010 MCS - Factory Alarm Goes Off Randomly
- CEL/Increased Emissions warning & failure to start, at 120 miles!
- Exterior A-Pillar gap problem....
- Dashboard Rattle
- 2010 MCS Auto EML Light in Extreme Cold Weather
- Motor Dies Immediately After Initial Cold-Weather Startup
- Same Performance--Sudden Drop in MPG
- New tranny at 1100 miles!?
- lost interior lighting...along with high beams and fogs???
- Red brake light & DSC light sporadically going on
- Clutch squeak/screech
- Unbelievable - Atl dealer forgot to remove shipping blocks on suspension on delivery
- 2008 Mini S USB doesn't charge my iPod
- fuel pump noise?
- Speedo Indicator lights
- Parts Parts Parts needed
- Bad Oil Leak
- Car pauses when shifting to fifth at high speed
- Chain Tensioner Rattle: SIM 11-02-07
- Help - Automatic Transmission
- Parking light lens
- Windows are possessed
- Car "charging" while braked at stop?
- Clutch not covered under warranty???
- ATF Fluid - Partial drain/fill
- My Mini Gets Morning Sickness
- Another Gear Shifter question
- High Pressure Fuel Pump
- Brake problem after Disc/Pad Change
- '08 MCS: Heat blower gone...
- Tire Pressure Monitor Light won't turn off!
- Dead on the offramp
