Grinding sound when braking
Old Jan 7, 2010 | 12:15 PM
OPC's Avatar
OPC
RATTUS Deserticus
Need some help in figuring out what to look at.
In the front-end, passenger side, I'm hearing a grinding/metal-on-metal sound under firm braking, but only in the last few feet before coming to a stop. It's like something is shifting forward at the very end when the front suspension is under max compression/load.
  • Dealership took a look at the brakes and noted plenty of pad life left and that brakets were properly supported. These are OEM (original) pad and calipers. 30K miles on the MINI.
  • They thought it was coilover rubbing, but noise is still there after spacers were installed.
  • I checked all the suspension bolts I could reach/access including the set-screws on the ALTA PSRS I have.
  • No unusual noises going over bumps or when turning.
  • The grinding is present regardless of clutch in/out or in-gear/neutral
I plan to double-check the suspension. Especially the front swaybar bolts and endlinks.
Any thoughts where and what to check for?
Old Jan 9, 2010 | 10:20 AM
superc00per's Avatar
superc00per
Mine does this too. It's the rear brakes grabbing. They do most of their work from 10mph to 0mph. It usually happens for me when I first take the car out after it's been sitting 12 hours or more on a day that's really been cold.
A few hard stops and the pads/rotors get cleaned/heated and it goes away.
Old Jan 10, 2010 | 08:32 PM
OPC's Avatar
OPC
RATTUS Deserticus
Cool, thanks. My friend and I were under the MINI most of Saturday & during a test drive, he did just that and the suspicious noise did stop for a bit (until the brakes cooled off). May be time for new pads and rotors, anyway.
I really appreciate the tip.
rikaro
Aug 7, 2021 02:33 PM
khumpert
Nov 30, 2015 11:48 AM
theblackfalcon
Oct 11, 2015 09:49 AM
Flying Sq
Aug 31, 2015 06:42 AM
